You can access your Nextcloud files, as though they were a Windows SMB network share. Thunar doesn’t make it obvious, but it can use DAV to talk to Nextcloud. In this way, you’ll have no need to install the Nextcloud client for Linux, to upload and download files from your Nextcloud server...
https://help.nextcloud.com/t/in-mx-linu ... -mgt/49698
In Thunar, connect to Nextcloud (WebDAV works for file mgt)
Re: In Thunar, connect to Nextcloud (WebDAV works for file mgt)
i had no idea about this. thanks, it is very convenient
Thanks, it's a great tip !
the link says we need first to install davfs2. It worked here without installing it...
edit
used it with disroot cloud, which uses nextcloud
edit
