Screen Tearing for nvidia FIX
To stop screen tearing Nvidia
This must be done with the command line from su = Root
enter super user mode
$ su + password then type nvidia-settings
Open: NVIDIA X Server Settings -> X Server Display Configuration go to Advanced... ->
Select Force Full Composition Pipeline set-> ViewPortOut -> 1920x1080+0+0 <<<< what ever your display resolution is >>>>>>
click apply
Save to X configuration File Done!
I have tried this and it works for me..
click apply
Main : MX 19.1-AHS (i3) 5.4.13-1~mx19+1, Asus B450-i AMD 5 3600 , 32gb Hyper-X 3200 , GTX970 .
- Eadwine Rose
- Administrator
Re: Screen Tearing for nvidia FIX
There have been posts about this before.
When the settings cannot be saved to X (due to absence of an xorg.conf file) the solution is to add this line to sessions and startup:
This code is also not dependent on the resolution of the monitor, nor the port it is connected to.
nvidia-settings --assign CurrentMetaMode="nvidia-auto-select +0+0 { ForceFullCompositionPipeline = On }"
Just to check ER: you mean set up an autostart in Session and Startup with that as the command, right?
- Eadwine Rose
- Administrator
yep
I have that exact line in an entry in there.
Ehm.. yeah.. usually when you clicked on it it would become big enough so it could be READ.
Anyway.. that is the code and I put SceenTearingFix in the name field.
I have tried the above with no resolution to my screen tearing issue. Is there something else that I could possibly try?
Thanks,
WyCKyD
Thanks,
WyCKyD
The thing with Linux is that the developers themselves are actually customers too: that has always been an important part of Linux. - Linus Torvalds
You can try changing your compositor from xfwm4 (assuming you are using xfwm4) to compton or compiz or kwin one of them might work.
Can you give us the output of
inxi -G
Graphics: Device-1: NVIDIA GP107 [GeForce GTX 1050 Ti] driver: nvidia v: 390.87
Display: x11 server: X.Org 1.19.2 driver: nvidia resolution: 1920x1080~60Hz
OpenGL: renderer: GeForce GTX 1050 Ti/PCIe/SSE2 v: 4.6.0 NVIDIA 390.87
I'm not certain what the problem is; what I see looks like you have Dock Shadows set "On" I have attached settings that might fix the problem. See attached:
I tried the changes and turned the dock shadows off. Unfortunately, it didn't solve the issue. I did notice that when exiting the game of WoW that the menus and everything else besides the gameplay looks great, it is just when you select a character and are in the open world that the artifacts are there (really bad, that it is unplayable. I do appreciate all of the suggestions and am trying everything that is thought of.
Thanks,
WyCKyD
Thanks,
WyCKyD
