Updating Testrepo Installed software using cli
I am hunting for the correct cli to use in updating all my upgradeable installed test software (from mxpi testrepo). I can do it with lots of little check marks (ticks for non-US folks) in mxpi, but that's pretty painful. :lipsrsealed:
I have hunted around for the terminal command... without success. Thanks in advance!
Re: Updating Testrepo Installed software using cli
Have a look heremanyroads wrote: ↑Fri Feb 08, 2019 5:25 pm I am hunting for the correct cli to use in updating all my upgradeable installed test software (from mxpi testrepo). I can do it with lots of little check marks (ticks for non-US folks) in mxpi, but that's pretty painful. :lipsrsealed:
Vielen dank @fehlix!!!
[redacted]
(fehlix' post, below, cleared my confusion)
Yes, it is possible. If there's an update to the app in MX test.
Also, newer versions of installed apps could be seen as an upgrade to a normally installed app.
That's why the recommendation is to not leave MX Test repo active.
As manyroads mentioned updating from the mx test is fastidious. Actually, the normal pattern is that apps are moved to the main MX repo for normal upgrading, but it is for testing, so if MX test is active, you are beta testing.
Thanks for the clarification Richard! I do understand the procedure better now.
Hi kids (btw. I include me in that mix)!
I just posted this in another thread... it seems to work pretty well
viewtopic.php?f=94&t=48299&start=30#p484767
Cool.
Another script to play with.
What do you use from mx test that doesn't get moved to the main mx repo?
If you would manually enable mx testrepo within mx.list, you would see exactly the same after apt update.skidoo wrote: ↑Fri Feb 08, 2019 6:21 pm fehlix, this screenshot depicts a post in the linked topic. I was (still am) alarmed at noting the "126 upgradable" .. "ok done" result.
Suppose that I have, via past packageinstaller usage, chosen to install 2 apps from "mx testing" repo.
When running this script, I probably would not wish to have ALL my currently installed packages upgraded to testing versions.
The only difference with running my script "apttestrepo" is: 1. you cannot forget to disable the testrepo again, a it is only overlay-enabled on the fly. 2nd you only need run apttestrepo update, to update "only" the testrepp package list, if you already had run "apt update" before. and 3rd you don't need re-update apt again after using apttestrepo , as the overlay-enabled will be ignored by running only apt.
BTW: Did you know that I hate posting text-output from the CLI as images,
EDIT: just use as you would use "apt", e.g. for upgrade one package:
Example:
Check first: apttestrepo --simulate install xfce4-whiskermenu-plugin
sudo apttestrepo --simulate install xfce4-whiskermenu-plugin
## /etc/apt/sources.list.d/mx.list
## mx-testrepo
deb http://ftp.halifax.rwth-aachen.de/mxlinux/packages/mx/testrepo/ stretch test
sudo apt -o Dir::Etc::sourcelist=/tmp/mx-testrepo-apt-sources.list.d-temp.fehlix.23620.193933841/temp_source.list --simulate install xfce4-whiskermenu-plugin
Reading package lists... Done
Building dependency tree
The following packages were automatically installed and are no longer required:
libva-wayland1 nvidia-egl-wayland-common
Use 'sudo apt autoremove' to remove them.
1 upgraded, 0 newly installed, 0 to remove and 153 not upgraded.
Inst xfce4-whiskermenu-plugin [2.1.5-0mx17] (2.3.1-0.1~mx17+1 MX repository:17.0/mx [amd64])
Conf xfce4-whiskermenu-plugin (2.3.1-0.1~mx17+1 MX repository:17.0/mx [amd64])
sudo apttestrepo install xfce4-whiskermenu-plugin
apttestrepo list --upgradable | grep virtualbox
Check:
LANG=en_US.UTF-8 apttestrepo --simulate install virtualbox virtualbox-dkms virtualbox-ext-pack virtualbox-guest-additions-iso virtualbox-qt
## mx-testrepo
sudo apt -o Dir::Etc::sourcelist=/tmp/mx-testrepo-apt-sources.list.d-temp.fehlix.24279.29243926/temp_source.list --simulate install virtualbox virtualbox-dkms virtualbox-ext-pack virtualbox-guest-additions-iso virtualbox-qt
Suggested packages:
vde2
5 upgraded, 0 newly installed, 0 to remove and 149 not upgraded.
Inst virtualbox-ext-pack [5.2.24-1~mx17+1] (6.0.4-1~mx17+1 MX repository:17.0/mx [all]) []
Inst virtualbox [5.2.24-dfsg-4~mx17+1] (6.0.4-dfsg-1~mx17+1 MX repository:17.0/mx [amd64]) [virtualbox-qt:amd64 ]
Inst virtualbox-qt [5.2.24-dfsg-4~mx17+1] (6.0.4-dfsg-1~mx17+1 MX repository:17.0/mx [amd64])
Inst virtualbox-dkms [5.2.24-dfsg-4~mx17+1] (6.0.4-dfsg-1~mx17+1 MX repository:17.0/mx [all])
Inst virtualbox-guest-additions-iso [5.2.24-1~mx17+1] (6.0.4-1~mx17+1 MX repository:17.0/mx [all])
Conf virtualbox-ext-pack (6.0.4-1~mx17+1 MX repository:17.0/mx [all])
Conf virtualbox (6.0.4-dfsg-1~mx17+1 MX repository:17.0/mx [amd64])
Conf virtualbox-qt (6.0.4-dfsg-1~mx17+1 MX repository:17.0/mx [amd64])
Conf virtualbox-dkms (6.0.4-dfsg-1~mx17+1 MX repository:17.0/mx [all])
Conf virtualbox-guest-additions-iso (6.0.4-1~mx17+1 MX repository:17.0/mx [all])
