Tutorial(s): Thunar Custom Actions--- simplify what you do
Since I have been putting a bunch of hours into creating/building my own Thunar Custom Actions, I thought I'd solicit comments from our Forums Community about what you have created/ use & like.
I posted a couple of my more recent creations here:
viewtopic.php?f=23&t=48279
I have a few more that I'll add once, I document their creation, for any who may benefit from these.
Re: Thunar Custom Actions--- what do you use & like
In case someone reading this topic hasn't yet discovered the Thunar Custom Actions feature,
here's a link to the xfce.org docs page: custom-actions (that xfce.org page is also linked from the MX Wiki)
Ubuntu wiki ThunarCustomActions page provides 30 examples
PCLinuxOS magazine (PDF, Jan 2015) "Xfce Tips And Tricks" describes several Thunar Custom Actions (dozens)
a nice collection here (not mine), with screenshots: https://gitlab.com/nobodyinperson/thunar-custom-actions
I only make one change. I edit the Symlink Custom Action to:
Thanks to kmathern!
This makes it much easier to create my 20-odd data symlinks on installation.
ln -s %f $(yad --width=640 --height=480 --center --file --directory --filename=%f --save --confirm-overwrite=oops)
@skidoo: put the Ubu link in that Wiki entry--which really needs to be filled out one of these days...
Thunar Custom Actions--- Image Conversion Function(s)
The following Thunar Custom Actions require that you have imagemagick installed (easy to do with mxpi).
Here are the commands for each:
To Convert jpg to png; the action command is:
To Convert png to jpg; the action command is:
I have the Appearance conditions set for both identically, see the image below:
Thunar Custom Actions--- a better looking menu
Making a better looking Custom Action Menu
Because I have a lot of custom actions, and I like them organized here are a couple of 'tricks' to allow for grouping & sorting.
To create a separator with a label, simply mimic the following image; set the Appearance Conditions to all check marks. The lines is actually the dash from your keyboard. When you're done you will be able to do something nicer that I have.
As for the icons I use, I have a folder (collection) and they are simply set from the Custom Action editor screen. Keep them somewhere so you'll remember!!!!
- Buck Fankers
Just want to say how I like all the Custom Actions in Thunar that already comes with MX!
But yours @manyroads (and icons) looks great, I love it, it would be huge improvement if they would come already with MX Thunar. I bet there would be users pointing this out, how MX Thunar is so much better than in other distros.
@Buck Fankers I certainly am happy if people want to use what I create. It's all there for the taking.Buck Fankers wrote: ↑Sun Feb 03, 2019 9:00 pm Just want to say how I like all the Custom Actions in Thunar that already comes with MX!
Thunar Custom Action--- anti-virus Action
Folder/File Virus scan
If you have clamav/clamtk installed (anti-virus available thru mxpi stable repo) you can create a custom action in thunar and make it invokeable on either single files or folders/ dirs. I find this especially useful for download of things such as Books, maps, images (pdf, png/jpg, etc.)
clamtk %F
Thunar Custom Action--- Bulk Rename
If you wish to invoke the Bulk Rename functions for files/ folders via right-click make certain you first install:
Also, in order to be able to batch rename multiple audio files based on their tags, also install the Thunar Media Tags plugin:
Edit the Thunar Custom actions as follows:
sudo apt-get install --no-install-recommends thunar
sudo apt-get install thunar-media-tags-plugin
