- Have you found a PDF file that is not digitally searchable, and you really wish it was?
- Do you wish you could easily convert monstrously huge pdf files to more compact djvu files, without a significant loss in functionality?
Here's the tutorial (on my eirenicon llc site):
http://eirenicon.org/2019/01/31/searchi ... documents/
Once the above tutorial functions are implemented, you will be able to:
- Convert PDF documents To DJVU via Thunar Custom Action. (Note: The resultant DJVU documents will be searchable even if the original PDF was not... this only works for English, so far as I know.)
- Make a non-searchable PDF 'searchable" via Thunar Custom Action. (Note: This only works for English, so far as I know.)
