A little trick to find out exactly when you installed a Linux OS
#1 Post by Stevo »
Assume that /dev/sda1 is your root partition, change it in the command if necessary:
sudo dumpe2fs /dev/sda1 | grep 'Filesystem created:'
Voila! Also works on separate home partitions--mine dates back to 2012.
dyfi
Re: A little trick to find out exactly when you installed a Linux OS
#2 Post by dyfi »
Code:- tune2fs -l /dev/sda1
Is also very informative.
