Trick: simple server
#1 Post by Adrian »
If you need to share something quickly over the internet you can start a quick http server by running:
python -m SimpleHTTPServer 8000
(use instead of 8000 whatever port you want to use)
This should start a server and share whatever you have in the folder you run it from (so be careful where you run it)
It's accessible on http://localhost:8000 to test, and on your http://enter_your_ip:8000
The alternative python3 command is:
python3 -m http.server 8000
PhantomTramp
Re: Trick: simple server
#2 Post by PhantomTramp »
Might have to create port forward in my router but this is awesome!
Many thanks,
The Tramp
#3 Post by Jerry3904 »
How do you stop it?
#4 Post by Adrian »
Jerry3904 wrote:How do you stop it?
CTRL-C in that terminal or in different terminal you can use pkill python (if you don't have any other python script running, because it will kill all the processes named like that).
m_pav
#5 Post by m_pav »
Nice !!
Mike P
Regd Linux User #472293
#6 Post by Adrian »
One potential use, a quick way to share something to and from a virtual machine without having to enable folder sharing (some are a bit more complicated to set up, for example in KVM, especially after you started the VM)
Oh, and it even works in Windows 10 (if you have Linux services installed, or probably if you have only Python installed -- yep, just tried, that works)
