qpaeq system-wide equalizer
#1 Post by Jerry3904 »
[this how-to was taken from a post from new user plzd--thanks!]
The procedure I found that has worked for me in different distros:
wget http://cgit.freedesktop.org/pulseaudio/ ... tils/qpaeq -O /tmp/qpaeq
sudo install /tmp/qpaeq /usr/local/bin/
To be able to use the equalizer, you'll need to install some extra dependencies:
sudo apt-get install python-dbus python-qt4 python-qt4-dbus pulseaudio-utils
Now restart Pulseaudio. Open a terminal and copy/paste the following commands:
pulseaudio -k
pulseaudio &
Everything is ready now, but the equalizer needs two modules to be loaded to work, so open a terminal and copy/paste these two commands:
pactl load-module module-equalizer-sink
pactl load-module module-dbus-protocol
Now iff you get an error and the module(s) can't be loaded, try the following commands, then restart Pulseaudio as explained under step 3:
rm -rf ~/.config/pulse
rm -rf ~/.pulse
The modules loaded under aren't automatically loaded on system start. So if you want to be able to use the equalizer after a restart without having to run those two commands, you'll have to add those modules either to ~/.pulse/ for your user or /etc/pulse/default.pa for all users. Below, I'm going to add them to /etc/pulse/default.pa and for this, you'll need to open the file as root with a text editor:
gksu leafpad /etc/pulse/default.pa
And at the bottom of the file, add this to load the integrated pulseaudio equalizer and dbus modules
Save file, and reboot.
Execute by typing
qpaeq
in terminal, or manually make icon launcher (executable qpaeq found in user/local/bin)
