Restarting the panel with a launcher
#1 Post by richb »
In XFCE on MX all versions, sometimes the panel needs to be refreshed for various reasons. I created a panel launcher to reload the panel. The command is:
xfce4-panel -r &
1. Left click on the panel and choose Panel>Add New Items>Launcher.
2. Right click on the new icon in the panel which brings up a dialog.
3. Click on the fourth icon down on the right side, "Add a new empty item".
4. Put the command xfce4-panel -r & in the Command box and fill the other boxes as desired.
5. You can choose an icon for the launcher by clicking on the icon in this dialog.
You can then move the icon to a location of your choice in the panel.
Note that the command xfce4-panel -r & can also be run in a terminal.
EDIT: per d_o's comment the & is not needed.
Re: Restarting the panel with a launcher
#2 Post by dolphin_oracle »
nice tip. I don't think you need the '&' though. In this case you are not starting the app, you are telling it via an internal function to restart.
#3 Post by richb »
dolphin_oracle wrote:nice tip. I don't think you need the '&' though. In this case you are not starting the app, you are telling it via an internal function to restart.
Thanks and thanks for the clarification. I will suggest removing it.
