Whenever I get web pages not loading or at best very slowly, I notice in the lower left corner that the holdup usually has to do with waiting for fonts.googleapis.com. It got so annoying this morning that I finally did a web search on it, and found this very helpful document:
http://www.webnots.com/fix-slow-page-lo ... eapis-com/
I tried switching to from Iceweasel to Chromium just now for the page that was not loading, and that connected instantly. Not sure how I am going to handle this problem in the future, but am glad to know what is going on and some of the possible solutions.
Re: fonts.googleapis.com
Jerry,
At the bottom of the page link, Sandra commented: "It was driving me crazy and now I got an idea of whats happening. Changed to static DNS and now the pages are loading super fast."
I looked in the manual (section 3.4), but can't find a reference performing this change. I also did a search, as I have seen this info posted several times over the years. Can you or someone with better skills than myself, point me in the correct direction for changing this in MX-14.4. I am wired connected in all my systems.
JR
$ inxi -F
System: Host: green263 Kernel: 3.14-0.bpo.2-686-pae i686 (32 bit) Desktop: Xfce 4.12.2
Distro: MX-14.4-pae Symbiosis 22 March 2015
Machine: Mobo: ASUSTeK model: C60M1-I v: Rev X.0x Bios: American Megatrends v: 0205 date: 04/06/2012
CPU: Dual core AMD C-60 APU with Radeon HD Graphics (-MCP-) cache: 1024 KB
clock speeds: max: 1000 MHz 1: 800 MHz 2: 1000 MHz
Graphics: Card: Advanced Micro Devices [AMD] ATI Wrestler [Radeon HD 6290]
Display Server: X.Org 1.12.4 drivers: ati,radeon (unloaded: fbdev,vesa) Resolution: 1920x1080@60.0hz
GLX Renderer: Gallium 0.4 on AMD PALM GLX Version: 2.1 Mesa 8.0.5
Audio: Card Advanced Micro Devices [AMD] ATI SBx00 Azalia (Intel HDA) driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k3.14-0.bpo.2-686-pae
Network: Card: Realtek RTL8111/8168B PCI Express Gigabit Ethernet controller driver: r8169
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 30:85:a9:3e:10:b6
Drives: HDD Total Size: 74.4GB (26.6% used) ID-1: /dev/sda model: WDC_WD740HLFS size: 74.4GB
Partition: ID-1: / size: 9.8G used: 3.6G (39%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 51G used: 7.3G (16%) fs: ext4 dev: /dev/sda3
ID-3: swap-1 size: 8.60GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 65.0C mobo: N/A gpu: 64.0
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 156 Uptime: 23:54 Memory: 648.4/7709.6MB Client: Shell (bash) inxi: 2.2.19
green263@green263:~/Desktop
