For MX-14x, from a post on the Xfce forum:
Ctrl+Alt+d
keystroke to minimize all windows to show desktop
Re: keystroke to minimize all windows to show desktop
I wish I knew how to do that in Mepis 12.
According to this here: http://community.linuxmint.com/tutorial/view/47 it looks like it's the same shortcut for KDE4.eemaestro wrote:I wish I knew how to do that in Mepis 12.
- Gordon Cooper
That shortcut does nothing in Kubuntu 14.04
Actually, I just realized that it's a toggle, so hit it once to drop them, hit it again to raise them all back up again. Quite cool.
Cool...like the toggle
Samsung 860 500GB SSDs (2)
Still doesn't work in 64-bit Mepis 12 (KDE 4.8.4)kmathern wrote:According to this here: http://community.linuxmint.com/tutorial/view/47 it looks like it's the same shortcut for KDE4.eemaestro wrote:I wish I knew how to do that in Mepis 12.
In the panel should be a Show Desktop Widget, ( if not add it)
right click on Show Desktop > Show Desktop Settings, then add the keyboard shortcut,
Hold down Ctrl, then Alt and hold it down then d, then release them, Apply and the shortcut will be set.
Desktop.
Zalman Z11 Plus ATX PC Tower, AMD FX 8350 Black Edition Vishera, 8 Core 4.4 GHz, Kingston HyperX FURY Red 16GB, Nvidia GT740 Graphics, Pioneer BDR-209EBK Writer, 2 x Seagate 1TB SSHD SATA Hybrid Hard Drives. ASUS VS278Q 27 inch HD Monitor
Thank you, Danum. That worked splendidly.
