Ciao a tutti,
Ho installato MX Linux sul mio Dell Vostro-3500.
Funziona tutto alla perfezione tranne il Bluetooth, quando tento di aggiungere un dispositivo mi segnala l'errore 'Nessun adattatore trovato'
Riporto di seguito lo stato attuale:
- inxi
System: Host: Vostro-3500 Kernel: 4.19.0-1-amd64 x86_64 bits: 64 Desktop: Xfce 4.12.3
Distro: MX-18.2_x64 Continuum Apr 7 2019
Machine: Type: Portable System: Dell product: Vostro 3500 v: N/A serial: 4HCM7L1
Mobo: Dell model: 0NVXFV v: A00 serial: .4HCM7L1.CN7016604O005M. BIOS: Dell v: A01 date: 02/10/2010
Battery: ID-1: BAT0 charge: 15.5 Wh condition: 15.8/57.7 Wh (27%)
CPU: Topology: Dual Core model: Intel Core i5 M 520 bits: 64 type: MT MCP L2 cache: 3072 KiB
Speed: 2296 MHz min/max: 1197/2395 MHz Core speeds (MHz): 1: 2320 2: 2392 3: 2214 4: 2294
Graphics: Device-1: NVIDIA GT218M [GeForce 310M] driver: nouveau v: kernel
Display: x11 server: X.Org 1.19.2 driver: nouveau unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: NVA8 v: 3.3 Mesa 18.2.6
Audio: Device-1: Intel 5 Series/3400 Series High Definition Audio driver: snd_hda_intel
Device-2: NVIDIA High Definition Audio driver: snd_hda_intel
Network: Device-1: Broadcom Limited BCM43224 802.11a/b/g/n driver: wl
IF: wlan0 state: up mac: f0:7b:cb:7f:e8:46
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet driver: r8169
IF: eth0 state: down mac: a4:ba:db:b5:80:f4
Drives: Local Storage: total: 111.79 GiB used: 8.40 GiB (7.5%)
ID-1: /dev/sda vendor: Kingston model: SA400S37120G size: 111.79 GiB
Partition: ID-1: / size: 107.53 GiB used: 8.40 GiB (7.8%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 62.0 C mobo: N/A gpu: nouveau temp: 61 C
Fan Speeds (RPM): fan-1: 4120
Info: Processes: 205 Uptime: 26m Memory: 5.75 GiB used: 1.06 GiB (18.4%) Shell: bash inxi: 3.0.33
- lsusb
Bus 002 Device 004: ID 0c45:6421 Microdia
Bus 002 Device 003: ID 093a:2510 Pixart Imaging, Inc. Optical Mouse
Bus 002 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
Bus 002 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 004: ID 138a:0008 Validity Sensors, Inc. VFS300 Fingerprint Reader
Bus 001 Device 006: ID 413c:8162 Dell Computer Corp. Integrated Touchpad [Synaptics]
Bus 001 Device 005: ID 413c:8161 Dell Computer Corp. Integrated Keyboard
Bus 001 Device 003: ID 0a5c:4500 Broadcom Corp. BCM2046B1 USB 2.0 Hub (part of BCM2046 Bluetooth)
Bus 001 Device 002: ID 8087:0020 Intel Corp. Integrated Rate Matching Hub
- lspci
00:00.0 Host bridge: Intel Corporation Core Processor DRAM Controller (rev 12)
00:01.0 PCI bridge: Intel Corporation Core Processor PCI Express x16 Root Port (rev 12)
00:16.0 Communication controller: Intel Corporation 5 Series/3400 Series Chipset HECI Controller (rev 06)
00:1a.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1b.0 Audio device: Intel Corporation 5 Series/3400 Series Chipset High Definition Audio (rev 06)
00:1c.0 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 1 (rev 06)
00:1c.1 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 2 (rev 06)
00:1c.2 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 3 (rev 06)
00:1c.4 PCI bridge: Intel Corporation 5 Series/3400 Series Chipset PCI Express Root Port 5 (rev 06)
00:1d.0 USB controller: Intel Corporation 5 Series/3400 Series Chipset USB2 Enhanced Host Controller (rev 06)
00:1e.0 PCI bridge: Intel Corporation 82801 Mobile PCI Bridge (rev a6)
00:1f.0 ISA bridge: Intel Corporation HM57 Chipset LPC Interface Controller (rev 06)
00:1f.2 SATA controller: Intel Corporation 5 Series/3400 Series Chipset 6 port SATA AHCI Controller (rev 06)
00:1f.3 SMBus: Intel Corporation 5 Series/3400 Series Chipset SMBus Controller (rev 06)
00:1f.6 Signal processing controller: Intel Corporation 5 Series/3400 Series Chipset Thermal Subsystem (rev 06)
01:00.0 VGA compatible controller: NVIDIA Corporation GT218M [GeForce 310M] (rev a2)
01:00.1 Audio device: NVIDIA Corporation High Definition Audio Controller (rev a1)
12:00.0 Network controller: Broadcom Limited BCM43224 802.11a/b/g/n (rev 01)
13:00.0 Ethernet controller: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller (rev 03)
ff:00.0 Host bridge: Intel Corporation Core Processor QuickPath Architecture Generic Non-core Registers (rev 02)
ff:00.1 Host bridge: Intel Corporation Core Processor QuickPath Architecture System Address Decoder (rev 02)
ff:02.0 Host bridge: Intel Corporation Core Processor QPI Link 0 (rev 02)
ff:02.1 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor QPI Physical 0 (rev 02)
ff:02.2 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
ff:02.3 Host bridge: Intel Corporation 1st Generation Core i3/5/7 Processor Reserved (rev 02)
- dmesg | grep Blue
[ 10.325632] Bluetooth: Core ver 2.22
[ 10.325651] Bluetooth: HCI device and connection manager initialized
[ 10.325656] Bluetooth: HCI socket layer initialized
[ 10.325659] Bluetooth: L2CAP socket layer initialized
[ 10.325667] Bluetooth: SCO socket layer initialized
[ 10.348224] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 10.348226] Bluetooth: BNEP filters: protocol multicast
[ 10.348232] Bluetooth: BNEP socket layer initialized
Grazie mille
Enrico
mod note Eadwine: shouting from topic title removed
Bluetooth nessun adattote trovato su notebook Dell Vostro 3500
Re: BLUETOOTH NESSUN ADATTATORE TROVATO SU NOTEBOOK DELL VOSTRO 3500
Uscita di questo comando?:
hcitool dev
- Eadwine Rose
- Administrator
Nota del moderatore: Per favore, non urlare nei titoli dei forum, grazie.
MX-23.2_x64 July 31 2023 * 6.1.0-18-amd64 ext4 Xfce 4.18.1 * 8core AMD Ryzen 7 2700
Re: Bluetooth nessun adattote trovato su notebook Dell Vostro 3500
Chiedo scusa, pensavo che nei titoli si potesse scrivere in maiusculo, scusatemi
(inglese)
I see many problems posted in a web search on "bcm2046 bluetooth linux" with many marked SOLVED. I am unable to test any of those so can't help you, sorry.
Si è vero ma non essendo riuscito a risolvere ho pensato di aprire il topic, grazie mille in ogni caso
Enrico
Enrico
Alcune persone (la mia ricerca su google) hanno semplicemente comprato un adattatore diverso
