stamattina dopo aver effettuato degli aggiornamenti il sistema è andato in tilt.
Vado con ordine sperando di darvi tutte le informazioni del caso.
Queste sono le info del mio portatile:
$ inxi -F
System: Host: mx1 Kernel: 3.16.0-4-586 i686 bits: 32 Desktop: Xfce 4.12.2
Distro: MX-15_386 Fusion 24 December 2015
Machine: Type: Laptop System: IBM product: 2653PG8 v: N/A serial: <root required>
Mobo: IBM model: 2653PG8 serial: <root required> BIOS: IBM v: 1NET10WW (1.04 ) date: 05/15/2003
Battery: ID-1: BAT0 charge: 11.9 Wh condition: 12.4/43.2 Wh (29%)
CPU: Topology: Single Core model: Mobile Intel Pentium 4 - M bits: 32 type: UP L2 cache: 512 KiB
Speed: 1900 MHz min/max: 1200/1900 MHz Core speed (MHz): 1: 1900
Graphics: Card-1: AMD RV200/M7 [Mobility Radeon 7500] driver: radeon v: kernel
Display: server: X.Org 1.16.4 driver: ati,radeon unloaded: fbdev,modesetting,vesa
resolution: 1024x768~60Hz
OpenGL: renderer: Mesa DRI R100 (RV200 4C57) x86/MMX/SSE2 DRI2 v: 1.3 Mesa 10.3.2
Audio: Card-1: Intel 82801CA/CAM AC97 Audio driver: snd_intel8x0
Sound Server: ALSA v: k3.16.0-4-586
Network: Card-1: Intel 82801CAM PRO/100 VE Ethernet driver: e100
IF: eth0 state: up speed: 100 Mbps duplex: full mac: 00:02:8a:a5:4a:74
IF-ID-1: irda0 state: down mac: 00:00:00:00
Drives: HDD Total Size: 149.05 GiB used: 118.20 GiB (79.3%)
ID-1: /dev/sda vendor: Samsung model: HM160HC size: 149.05 GiB
Partition: ID-1: / size: 82.38 GiB used: 66.99 GiB (81.3%) fs: ext4 dev: /dev/sda3
ID-2: swap-1 size: 1.65 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda4
Sensors: System Temperatures: cpu: 56.0 C mobo: 28.0 C
Fan Speeds (RPM): cpu: 3410
Info: Processes: 150 Uptime: 26m Memory: 1.48 GiB used: 397.7 MiB (26.2%) Shell: bash inxi: 3.0.10
(synaptic:3673): GLib-CRITICAL **: g_child_watch_add_full: assertion 'pid > 0' failed
Estrazione dei template dai pacchetti: 100%
Preconfigurazione dei pacchetti in corso
(Lettura del database... 199862 file e directory attualmente installati.)
Preparativi per estrarre .../libxml2_2.9.1+dfsg1-5+deb8u7_i386.deb...
Estrazione di libxml2:i386 (2.9.1+dfsg1-5+deb8u7) su (2.9.1+dfsg1-5+deb8u6)...
Preparativi per estrarre .../liblcms2-2_2.6-3+deb8u2_i386.deb...
Estrazione di liblcms2-2:i386 (2.6-3+deb8u2) su (2.6-3+deb8u1)...
Preparativi per estrarre .../libmagickwand-6.q16-2_8%3a6.8.9.9-5+deb8u14_i386.deb...
Estrazione di libmagickwand-6.q16-2:i386 (8:6.8.9.9-5+deb8u14) su (8:6.8.9.9-5+deb8u13)...
Preparativi per estrarre .../libmagickcore-6.q16-2_8%3a6.8.9.9-5+deb8u14_i386.deb...
Estrazione di libmagickcore-6.q16-2:i386 (8:6.8.9.9-5+deb8u14) su (8:6.8.9.9-5+deb8u13)...
Preparativi per estrarre .../imagemagick-common_8%3a6.8.9.9-5+deb8u14_all.deb...
Estrazione di imagemagick-common (8:6.8.9.9-5+deb8u14) su (8:6.8.9.9-5+deb8u13)...
Preparativi per estrarre .../curl_7.38.0-4+deb8u12_i386.deb...
Estrazione di curl (7.38.0-4+deb8u12) su (7.38.0-4+deb8u11)...
Preparativi per estrarre .../libcurl3_7.38.0-4+deb8u12_i386.deb...
Estrazione di libcurl3:i386 (7.38.0-4+deb8u12) su (7.38.0-4+deb8u11)...
Preparativi per estrarre .../libcurl3-gnutls_7.38.0-4+deb8u12_i386.deb...
Estrazione di libcurl3-gnutls:i386 (7.38.0-4+deb8u12) su (7.38.0-4+deb8u11)...
Preparativi per estrarre .../python2.7-dev_2.7.9-2+deb8u2_i386.deb...
Estrazione di python2.7-dev (2.7.9-2+deb8u2) su (2.7.9-2+deb8u1)...
Preparativi per estrarre .../libpython2.7-dev_2.7.9-2+deb8u2_i386.deb...
Estrazione di libpython2.7-dev:i386 (2.7.9-2+deb8u2) su (2.7.9-2+deb8u1)...
Preparativi per estrarre .../python2.7_2.7.9-2+deb8u2_i386.deb...
Estrazione di python2.7 (2.7.9-2+deb8u2) su (2.7.9-2+deb8u1)...
Preparativi per estrarre .../libpython2.7_2.7.9-2+deb8u2_i386.deb...
Estrazione di libpython2.7:i386 (2.7.9-2+deb8u2) su (2.7.9-2+deb8u1)...
Preparativi per estrarre .../libpython2.7-stdlib_2.7.9-2+deb8u2_i386.deb...
Estrazione di libpython2.7-stdlib:i386 (2.7.9-2+deb8u2) su (2.7.9-2+deb8u1)...
Preparativi per estrarre .../python2.7-minimal_2.7.9-2+deb8u2_i386.deb...
Estrazione di python2.7-minimal (2.7.9-2+deb8u2) su (2.7.9-2+deb8u1)...
Preparativi per estrarre .../libpython2.7-minimal_2.7.9-2+deb8u2_i386.deb...
Estrazione di libpython2.7-minimal:i386 (2.7.9-2+deb8u2) su (2.7.9-2+deb8u1)...
Preparativi per estrarre .../python3.4_3.4.2-1+deb8u1_i386.deb...
Estrazione di python3.4 (3.4.2-1+deb8u1) su (3.4.2-1)...
Preparativi per estrarre .../python3.4-minimal_3.4.2-1+deb8u1_i386.deb...
Estrazione di python3.4-minimal (3.4.2-1+deb8u1) su (3.4.2-1)...
Preparativi per estrarre .../libpython3.4_3.4.2-1+deb8u1_i386.deb...
Estrazione di libpython3.4:i386 (3.4.2-1+deb8u1) su (3.4.2-1)...
Preparativi per estrarre .../libpython3.4-stdlib_3.4.2-1+deb8u1_i386.deb...
Estrazione di libpython3.4-stdlib:i386 (3.4.2-1+deb8u1) su (3.4.2-1)...
Preparativi per estrarre .../libpython3.4-minimal_3.4.2-1+deb8u1_i386.deb...
Estrazione di libpython3.4-minimal:i386 (3.4.2-1+deb8u1) su (3.4.2-1)...
Selezionato il pacchetto libseccomp2:i386 non precedentemente selezionato.
Preparativi per estrarre .../libseccomp2_2.1.1-1_i386.deb...
Estrazione di libseccomp2:i386 (2.1.1-1)...
Preparativi per estrarre .../openssh-sftp-server_1%3a6.7p1-5+deb8u7_i386.deb...
Estrazione di openssh-sftp-server (1:6.7p1-5+deb8u7) su (1:6.7p1-5+deb8u5)...
Preparativi per estrarre .../openssh-server_1%3a6.7p1-5+deb8u7_i386.deb...
Estrazione di openssh-server (1:6.7p1-5+deb8u7) su (1:6.7p1-5+deb8u5)...
Preparativi per estrarre .../openssh-client_1%3a6.7p1-5+deb8u7_i386.deb...
Estrazione di openssh-client (1:6.7p1-5+deb8u7) su (1:6.7p1-5+deb8u5)...
Preparativi per estrarre .../smplayer_18.9.0-0.1~mx15+1_i386.deb...
Estrazione di smplayer (18.9.0-0.1~mx15+1) su (18.6.0-0.1~mx15+1)...
Preparativi per estrarre .../smtube_18.9.0+2.1_i386.deb...
Estrazione di smtube (18.9.0+2.1) su (18.3.0-1~mx15+1)...
Selezionato il pacchetto bubblewrap non precedentemente selezionato.
Preparativi per estrarre .../bubblewrap_0.1.7-1mx15+1_i386.deb...
Estrazione di bubblewrap (0.1.7-1mx15+1)...
Preparativi per estrarre .../dnsmasq-base_2.72-3+deb8u4_i386.deb...
Estrazione di dnsmasq-base (2.72-3+deb8u4) su (2.72-3+deb8u3)...
Preparativi per estrarre .../firefox_62.0.3~mozillabinaries-1mx15+1_i386.deb...
Estrazione di firefox (62.0.3~mozillabinaries-1mx15+1) su (61.0.2~mozillabinaries-1mx15+1)...
Preparativi per estrarre .../firefox-l10n-xpi-it_62.0.3~mozillabinaries-1mx15+1_i386.deb...
Estrazione di firefox-l10n-xpi-it (62.0.3~mozillabinaries-1mx15+1) su (61.0.2~mozillabinaries-1mx15+1)...
Selezionato il pacchetto libostree-1-1:i386 non precedentemente selezionato.
Preparativi per estrarre .../libostree-1-1_2016.15-3mx15+1_i386.deb...
Estrazione di libostree-1-1:i386 (2016.15-3mx15+1)...
Selezionato il pacchetto flatpak non precedentemente selezionato.
Preparativi per estrarre .../flatpak_0.8.9-0.1~mx15+1_i386.deb...
Estrazione di flatpak (0.8.9-0.1~mx15+1)...
Selezionato il pacchetto python-configobj non precedentemente selezionato.
Preparativi per estrarre .../python-configobj_5.0.6-1_all.deb...
Estrazione di python-configobj (5.0.6-1)...
Selezionato il pacchetto fskbsetting non precedentemente selezionato.
Preparativi per estrarre .../fskbsetting_0.5.3.1~mx15_all.deb...
Estrazione di fskbsetting (0.5.3.1~mx15)...
Preparativi per estrarre .../ghostscript-x_9.06~dfsg-2+deb8u10_i386.deb...
Estrazione di ghostscript-x (9.06~dfsg-2+deb8u10) su (9.06~dfsg-2+deb8u7)...
Preparativi per estrarre .../ghostscript_9.06~dfsg-2+deb8u10_i386.deb...
Estrazione di ghostscript (9.06~dfsg-2+deb8u10) su (9.06~dfsg-2+deb8u7)...
Preparativi per estrarre .../libgs9_9.06~dfsg-2+deb8u10_i386.deb...
Estrazione di libgs9 (9.06~dfsg-2+deb8u10) su (9.06~dfsg-2+deb8u7)...
Preparativi per estrarre .../libgs9-common_9.06~dfsg-2+deb8u10_all.deb...
Estrazione di libgs9-common (9.06~dfsg-2+deb8u10) su (9.06~dfsg-2+deb8u7)...
Preparativi per estrarre .../git-man_1%3a2.1.4-2.1+deb8u7_all.deb...
Estrazione di git-man (1:2.1.4-2.1+deb8u7) su (1:2.1.4-2.1+deb8u6)...
Preparativi per estrarre .../git_1%3a2.1.4-2.1+deb8u7_i386.deb...
Estrazione di git (1:2.1.4-2.1+deb8u7) su (1:2.1.4-2.1+deb8u6)...
Preparativi per estrarre .../imagemagick_8%3a6.8.9.9-5+deb8u14_i386.deb...
Estrazione di imagemagick (8:6.8.9.9-5+deb8u14) su (8:6.8.9.9-5+deb8u13)...
Preparativi per estrarre .../imagemagick-6.q16_8%3a6.8.9.9-5+deb8u14_i386.deb...
Estrazione di imagemagick-6.q16 (8:6.8.9.9-5+deb8u14) su (8:6.8.9.9-5+deb8u13)...
Preparativi per estrarre .../libimage-magick-q16-perl_8%3a6.8.9.9-5+deb8u14_i386.deb...
Estrazione di libimage-magick-q16-perl (8:6.8.9.9-5+deb8u14) su (8:6.8.9.9-5+deb8u13)...
Preparativi per estrarre .../libimage-magick-perl_8%3a6.8.9.9-5+deb8u14_all.deb...
Estrazione di libimage-magick-perl (8:6.8.9.9-5+deb8u14) su (8:6.8.9.9-5+deb8u13)...
Preparativi per estrarre .../libjs-jquery_1.11.3+dfsg-4~mx15+1_all.deb...
Estrazione di libjs-jquery (1.11.3+dfsg-4~mx15+1) su (1.7.2+dfsg-3.2)...
Preparativi per estrarre .../libjs-sphinxdoc_1.4.9-2~mx15+1_all.deb...
Estrazione di libjs-sphinxdoc (1.4.9-2~mx15+1) su (1.2.3+dfsg-1)...
Preparativi per estrarre .../liblcms2-utils_2.6-3+deb8u2_i386.deb...
Estrazione di liblcms2-utils (2.6-3+deb8u2) su (2.6-3+deb8u1)...
Preparativi per estrarre .../libxml2-utils_2.9.1+dfsg1-5+deb8u7_i386.deb...
Estrazione di libxml2-utils (2.9.1+dfsg1-5+deb8u7) su (2.9.1+dfsg1-5+deb8u6)...
Selezionato il pacchetto socat non precedentemente selezionato.
Preparativi per estrarre .../socat_1.7.2.4-2_i386.deb...
Estrazione di socat (1.7.2.4-2)...
Preparativi per estrarre .../mx-packageinstaller_18.10mx15_i386.deb...
Estrazione di mx-packageinstaller (18.10mx15) su (18.8.1)...
Preparativi per estrarre .../mx-repo-manager_18.9_i386.deb...
Estrazione di mx-repo-manager (18.9) su (18.8)...
Preparativi per estrarre .../mx-snapshot_18.9.1_i386.deb...
Estrazione di mx-snapshot (18.9.1) su (18.8.4)...
Preparativi per estrarre .../perlmagick_8%3a6.8.9.9-5+deb8u14_all.deb...
Estrazione di perlmagick (8:6.8.9.9-5+deb8u14) su (8:6.8.9.9-5+deb8u13)...
Preparativi per estrarre .../python-libxml2_2.9.1+dfsg1-5+deb8u7_i386.deb...
Estrazione di python-libxml2 (2.9.1+dfsg1-5+deb8u7) su (2.9.1+dfsg1-5+deb8u6)...
Preparativi per estrarre .../intel-microcode_3.20180807a.1~deb8u1_i386.deb...
Estrazione di intel-microcode (3.20180807a.1~deb8u1) su (3.20180703.2~deb8u1)...
Elaborazione dei trigger per man-db (2.7.0.2-5)...
Elaborazione dei trigger per menu (2.1.47)...
Elaborazione dei trigger per desktop-file-utils (0.22-1)...
Elaborazione dei trigger per mime-support (3.58)...
Elaborazione dei trigger per systemd (215-17+deb8u7)...
Elaborazione dei trigger per ufw (0.33-2)...
Elaborazione dei trigger per hicolor-icon-theme (0.13-1)...
Elaborazione dei trigger per dbus (1.8.22-0+deb8u1)...
Elaborazione dei trigger per libc-bin (2.19-18+deb8u10)...
Configurazione di libxml2:i386 (2.9.1+dfsg1-5+deb8u7)...
Configurazione di liblcms2-2:i386 (2.6-3+deb8u2)...
Configurazione di imagemagick-common (8:6.8.9.9-5+deb8u14)...
Configurazione di libmagickcore-6.q16-2:i386 (8:6.8.9.9-5+deb8u14)...
Configurazione di libmagickwand-6.q16-2:i386 (8:6.8.9.9-5+deb8u14)...
Configurazione di libcurl3:i386 (7.38.0-4+deb8u12)...
Configurazione di curl (7.38.0-4+deb8u12)...
Configurazione di libcurl3-gnutls:i386 (7.38.0-4+deb8u12)...
Configurazione di libpython2.7-minimal:i386 (2.7.9-2+deb8u2)...
Configurazione di python2.7-minimal (2.7.9-2+deb8u2)...
Configurazione di libpython2.7-stdlib:i386 (2.7.9-2+deb8u2)...
Configurazione di python2.7 (2.7.9-2+deb8u2)...
Configurazione di libpython2.7:i386 (2.7.9-2+deb8u2)...
Configurazione di libpython2.7-dev:i386 (2.7.9-2+deb8u2)...
Configurazione di python2.7-dev (2.7.9-2+deb8u2)...
Configurazione di libpython3.4-minimal:i386 (3.4.2-1+deb8u1)...
Configurazione di python3.4-minimal (3.4.2-1+deb8u1)...
Configurazione di libpython3.4-stdlib:i386 (3.4.2-1+deb8u1)...
Configurazione di python3.4 (3.4.2-1+deb8u1)...
Configurazione di libpython3.4:i386 (3.4.2-1+deb8u1)...
Configurazione di libseccomp2:i386 (2.1.1-1)...
Configurazione di openssh-client (1:6.7p1-5+deb8u7)...
Configurazione di openssh-sftp-server (1:6.7p1-5+deb8u7)...
Configurazione di openssh-server (1:6.7p1-5+deb8u7)...
[ ok ] Restarting OpenBSD Secure Shell server: sshd.
Configurazione di smplayer (18.9.0-0.1~mx15+1)...
Configurazione di smtube (18.9.0+2.1)...
Configurazione di bubblewrap (0.1.7-1mx15+1)...
Configurazione di dnsmasq-base (2.72-3+deb8u4)...
Configurazione di firefox (62.0.3~mozillabinaries-1mx15+1)...
Configurazione di firefox-l10n-xpi-it (62.0.3~mozillabinaries-1mx15+1)...
Configurazione di libostree-1-1:i386 (2016.15-3mx15+1)...
Configurazione di flatpak (0.8.9-0.1~mx15+1)...
Configurazione di python-configobj (5.0.6-1)...
Configurazione di fskbsetting (0.5.3.1~mx15)...
Configurazione di libgs9-common (9.06~dfsg-2+deb8u10)...
Configurazione di libgs9 (9.06~dfsg-2+deb8u10)...
Configurazione di ghostscript (9.06~dfsg-2+deb8u10)...
Configurazione di ghostscript-x (9.06~dfsg-2+deb8u10)...
Configurazione di git-man (1:2.1.4-2.1+deb8u7)...
Configurazione di git (1:2.1.4-2.1+deb8u7)...
Configurazione di imagemagick-6.q16 (8:6.8.9.9-5+deb8u14)...
Configurazione di imagemagick (8:6.8.9.9-5+deb8u14)...
Configurazione di libimage-magick-q16-perl (8:6.8.9.9-5+deb8u14)...
Configurazione di libimage-magick-perl (8:6.8.9.9-5+deb8u14)...
Configurazione di libjs-jquery (1.11.3+dfsg-4~mx15+1)...
Configurazione di libjs-sphinxdoc (1.4.9-2~mx15+1)...
Configurazione di liblcms2-utils (2.6-3+deb8u2)...
Configurazione di libxml2-utils (2.9.1+dfsg1-5+deb8u7)...
Configurazione di socat (1.7.2.4-2)...
Configurazione di perlmagick (8:6.8.9.9-5+deb8u14)...
Configurazione di python-libxml2 (2.9.1+dfsg1-5+deb8u7)...
Configurazione di intel-microcode (3.20180807a.1~deb8u1)...
update-initramfs: deferring update (trigger activated)
intel-microcode: microcode will be updated at next boot
Configurazione di mx-repo-manager (18.9)...
Configurazione di mx-snapshot (18.9.1)...
Configurazione di mx-packageinstaller (18.10mx15)...
Elaborazione dei trigger per initramfs-tools (0.120+deb8u3)...
update-initramfs: Generating /boot/initrd.img-3.16.0-4-686-pae
cryptsetup: WARNING: failed to detect canonical device of /dev/sda2
Per sicurezza questa è la schermata di gparted
Questa quella di avvio del grub
e queste di seguito per l'errore in avvio lasciando l'opzione di base per l'avvio
Adesso riesco ad avviare il sistema senza problemi solo se dal grub vado in opzioni avanzate e seleziono una qualsiasi delle voci relative ai kernel 586, gli altri, i 686 vanno tutti in errore.
Cosa è successo, e come risolvo?
