[RISOLTO] MX-16 live CD with MXsnapshot
Salve, ho questo problema, sto provando MX-16 su VirtualBox.
Ho fatto delle modifiche e usato MX snapshot per creare un CD live.
Il CD live non funziona e nella schermata iniziale compare la scritta:
-mounting /live/aufs on /live/aufs-
-failed: no such device-
Perché si verifica questo?
Hello, I have this problem, I’m trying MX-16 on VirtualBox.
I have made some changes and used MX snapshot to create a CD live.
The CD live does not work and in splashscreen I can see the word:
Why this is it verified?
Re: MX-16 live CD with MXsnapshot
NUOVE INFO
Se faccio iso-snapshot-antix 0.1.5.1 da CD originale, snapshot funziona e crea CD live funzionante.
Dopo upgrade iso-snapshot-antix diventa 0.2.4 e cliccando su menu non succede niente, non viene crato nessun snapshot e non si apre nessuna finestra di dialogo.
Ritornare a 0.1.5.1 o usando altro snapshot il programma funziona ma il CD live non si apre e compare l'errore descritto sopra.
Recommend using MX-17. That is the latest release.
Samsung 860 500GB SSDs (2)
But MX-16.3 should not be more stable than MX-17 ???Paul.. wrote:Recommend using MX-17. That is the latest release.
No.ROGHIBAU wrote:But MX-16.3 should not be more stable than MX-17 ???Paul.. wrote:Recommend using MX-17. That is the latest release.
Who made this MX-16.3? Where did you get it from?ROGHIBAU wrote:But MX-16.3 should not be more stable than MX-17 ???Paul.. wrote:Recommend using MX-17. That is the latest release.
Same question here, a few hours ago :anticapitalista wrote:Who made this MX-16.3? Where did you get it from?ROGHIBAU wrote:But MX-16.3 should not be more stable than MX-17 ???Paul.. wrote:Recommend using MX-17. That is the latest release.
Why is MX17 younger than MX16.3 on this torrent tracker ?
> Desktop : AMD 64 bits (unknowned monocore model :P looking for an AM2+ 4cores Phenom) | RAM 4Go DDR2 | MX@daily updates, sudo apt dist-upgrade
> Laptop x2 : WIP obsolescence and "old" batteries prices have killed my project
He is confusing ANTIX 16.3 with
MX 16.1.
Don't know how, as they have distinct download sites.
But, to be clear, both AntiX 16.x AND MX 16.X derive from Debian 8.x codenamed Jessie,
While both AntiX 17 and MX 17 hail from Debian 9.x, codenamed Stretch.
MX 16.1.
that isn't MX. That's antiX. and that's because anti updated the 16 series antiX after the antiX 17 release.
If only people could read *sigh*
