update meldung zu broadcom-sta-dkms 6.30.223.271-9.1~mx17+1
Kulmbacher
#1 Post by Kulmbacher »
Moins,
heute wurde mir der neuere broadcom angeboten, es erscheint eine Meldung:
full upgrade
Reading package lists... Done
Building dependency tree
Calculating upgrade... Done
   broadcom-sta-dkms (6.30.223.271-7mx17+2 => 6.30.223.271-9.1~mx17+1)
   mx-repo-manager (18.11.2 => 18.11.5)
2 upgraded, 0 newly installed, 0 to remove and 0 not upgraded.
Need to get 2,267 kB of archives.
After this operation, 2,048 B disk space will be freed.
Get:1 https://ftp.nluug.nl/os/Linux/distr/mxlinux/mx/repo stretch/non-free amd64 broadcom-sta-dkms all 6.30.223.271-9.1~mx17+1 [2,208 kB]
Get:2 https://ftp.nluug.nl/os/Linux/distr/mxlinux/mx/repo stretch/main amd64 mx-repo-manager amd64 18.11.5 [58.7 kB]
Fetched 2,267 kB in 5s (425 kB/s)
apt-listchanges: Reading changelogs...
(Reading database ... 362135 files and directories currently installed.)full upgrade
Preparing to unpack .../broadcom-sta-dkms_6.30.223.271-9.1~mx17+1_all.deb ...
-------- Uninstall Beginning --------
Module:  broadcom-sta
Version: 6.30.223.271
Kernel:  4.15.0-1-amd64 (x86_64)
Status: Before uninstall, this module version was ACTIVE on this kernel.
wl.ko:
 - Uninstallation
   - Deleting from: /lib/modules/4.15.0-1-amd64/updates/dkms/
 - Original module
   - No original module was found for this module on this kernel.
   - Use the dkms install command to reinstall any previous module version.
depmod...
Backing up initrd.img-4.15.0-1-amd64 to /boot/initrd.img-4.15.0-1-amd64.old-dkms
Making new initrd.img-4.15.0-1-amd64
(If next boot fails, revert to initrd.img-4.15.0-1-amd64.old-dkms image)
update-initramfs.....
DKMS: uninstall completed.
Kernel:  4.9.0-8-amd64 (x86_64)
wl.ko:
 - Uninstallation
   - Deleting from: /lib/modules/4.9.0-8-amd64/updates/dkms/
 - Original module
depmod...
Backing up initrd.img-4.9.0-8-amd64 to /boot/initrd.img-4.9.0-8-amd64.old-dkms
Making new initrd.img-4.9.0-8-amd64
(If next boot fails, revert to initrd.img-4.9.0-8-amd64.old-dkms image)
Deleting module version: 6.30.223.271
completely from the DKMS tree.
Done.
Unpacking broadcom-sta-dkms (6.30.223.271-9.1~mx17+1) over (6.30.223.271-7mx17+2) ...
Preparing to unpack .../mx-repo-manager_18.11.5_amd64.deb ...
Unpacking mx-repo-manager (18.11.5) over (18.11.2) ...
Setting up broadcom-sta-dkms (6.30.223.271-9.1~mx17+1) ...
Loading new broadcom-sta-6.30.223.271 DKMS files...
Building for 4.9.0-8-amd64
Building initial module for 4.9.0-8-amd64
Done.
wl:
Running module version sanity check.
 - Original module
   - No original module exists within this kernel
 - Installation
   - Installing to /lib/modules/4.9.0-8-amd64/updates/dkms/
depmod...
DKMS: install completed.
Processing triggers for mime-support (3.60) ...
Processing triggers for desktop-file-utils (0.23-1) ...
Setting up mx-repo-manager (18.11.5) ...
Processing triggers for hicolor-icon-theme (0.15-1) ...
full upgrade complete (or was canceled)
this terminal window can now be closed (press any key to close)
wl.ko:
 - Uninstallation
 - Original module
depmod...
wl.ko:
 - Uninstallation
 - Original module
depmod...
Done.
Done.
wl:
 - Original module
 - Installation
depmod...
Bedeutet für mich dann vom live usb stick zu booten.
Mit root im boot directory die initrd.img-4.9.0-8-amd64 löschen, und mit der initrd.img-4.9.0-8-amd64.old-dkms (umbenennen) ersetzen?
Merci
they called him, the fish!
tianlan
Re: update meldung zu broadcom-sta-dkms 6.30.223.271-9.1~mx17+1
#2 Post by tianlan »
Konntest du mit umbenennen und ersetzen deinen Rechner in Mx starten? Mir wurde auch empfohlen to revert to old-dkms. Aber wie?
Kulmbacher
#3 Post by Kulmbacher »
Ja, hat funktioniert.
Das "aber wie", steht eigentlich oben ... ;-)
tianlan
#4 Post by tianlan »
So wie oben habe ich es dann auch gemacht und es klappte auch.
#5 Post by fehlix »
falls die neue intrd nicht funktioniert, kannst du im grub menu das .old-dkms an den initrd-namen ranhängen,
und es startet dann wieder mit der vorigen intit-ram-disk. naja so würde ich es machen, wenn mir das mal passieren würde.
:puppy:
Return to “Deutsches Forum”
