currently the MX-18.2 ecosystem is missing a simple solution for sending and receiving files within a LAN which would be both easy to set up and generally acceptable :
- The Avahi-based Giver project has been abandoned, and the project's website has been deleted (see https://code.google.com/archive/p/giver/). Not in MX-18.2's (Debian's) repos anyway.
- Dukto hasn't received any updates in four years, and disrespects the users' privacy (cf. viewtopic.php?p=419924#p419924 for the latter).
- Transfer On LAN hasn't received any updates in six years, and and the project's website has been deleted (see https://code.google.com/archive/p/transfer-on-lan/). Not in MX-18.2's (Debian's) repos anyway.
- NitroShare hasn't received updates in more than three years, and when testing it, I couldn't install it on an extremely standard Thinkpad running MS Windows 10. Besides, its graphical representation was grotesque. Low version number.
Hence I'd love to see LAN Share in the MX Test Repo. LAN Share seems to be the only solution currently available that could be both functional and generally acceptable. It works on Linux-based systems and on MS-Windows-based systems, and has been recommended by OMGUbuntu!:
... no third-party servers, no cloud services, and no complicated protocol arrangements involved.
Simply install the app on each computer you want to use, use the “Send” menu to select the file(s) or folder(s) you want to send, and select the ‘receiver’ computer from the list.
The only hard requirement is that both computers are on the same local network or Wi-Fi connection.
(...) Part of why I like this app enough to write about it is the simple, straight-forward interface. (...) What I really appreciate is that files can be transferred between machines running different operating systems.
(https://www.omgubuntu.co.uk/2018/05/tra ... fi-network)
Description:
LAN Share is a cross platform local area network file transfer application, built using Qt GUI framework. It can be used to transfer a whole folder, one or more files, large or small immediatelly without any additional configuration.
Features
* Send one or more files
* Send folder
* Send to multiple receiver at the same time
* Cancel, pause and resume operations while transfering
Usage
* Computer has to be connected to a local area network (wired or wireless)
* Run the application in both sender and receiver
* Send the file/folder by, select Send (files or folder) then -> select receiver in the 'Select Receiver' dialog, finally click 'Send'
* File/folder would automatically received by the receiver
License
* GPLv3
(https://github.com/abdularis/LAN-Share)
The version number of the most current version is 1.2.1, so this looks like a serious, non-beta version project that could be worth being tested thoroughly.
Source code is here: https://github.com/abdularis/LAN-Share/ ... 2.1.tar.gz. There's a debianization example available here: https://github.com/abdularis/LAN-Share/ ... _amd64.deb. The Windows version installs and starts without issues.
Greetings, and thanks in advance for looking into this, Joe
