MX 17 Repository: The sweethome3d Thread
mmikeinsantarosa
#1 Post by mmikeinsantarosa »
sweethome3d-5.7 is now available for download from the test repository. This is mostly a bug fix but quite a few since our last one here (5.4).
Version 5.7, January 25, 2018
Added a preview component to file choosers used to select an image under Windows and Linux.
Managed user defined furniture properties added to catalogs read by Sweet Home 3D and read/saved by Furniture Library Editor.
Fixed the visibility of horizontally rotated objects at upper levels.
Fixed the size in the plan of a copied-pasted object which is horizontally rotated.
Fixed a bug that prevented to group unresizable furniture or read a SH3D file saved with a previous version which contained such objects.
Fixed the display of furniture catalog and furniture list when scrolling under Mac OS X 10.13 with Java 6.
Fixed Window menu management under Mac OS X with Java 8.
Replaced JRE 8u152 by JRE 8u162 in Sweet Home 3D installers bundled with Java.
Converted CVS repository on SourceForge.net to SVN (sorry for the dead links to sweethome3d.cvs.sf.net server that this change implies).
Other minor bugs fixes and enhancements.
Version 5.6, October 25, 2017
Fixed a bug that prevented to export to CSV format.
Fixed the size of furniture in subgroups when their parent group is resized.
Fixed wrongly computed threshold of doors larger than the side of a room.
Improved printing performances under Mac OS X with Java 8u152.
Replaced JRE 8u144 by JRE 8u152 in Sweet Home 3D installers bundled with Java.
I also rebuilt the texture & furniture editors and the new furniture library and those are also in test.
- mike
Re: MX 17 Repository: The sweethome3d Thread
#2 Post by asqwerth »
What a cool program! I never knew this existed.
mmikeinsantarosa
#3 Post by mmikeinsantarosa »
asqwerth wrote:What a cool program! I never knew this existed.
Yeah, there are tons of tutorials on youtube.
Here's their home page and they have a fairly active forum.
Eadwine Rose
#4 Post by Eadwine Rose »
Too bad I cannot get the online version to work. Not in Chrome and not in Firefox.
But no biggie as I don't use it. Besides that should go in a different forum ;)
mmikeinsantarosa
#5 Post by mmikeinsantarosa »
Eadwine Rose wrote:Too bad I cannot get the online version to work. Not in Chrome and not in Firefox.
Eadwine, I'm not sure what you mean here? 5.7 is in the MX17 repo and I sent the set for MX 15/16 up earlier this morning.
5.7 is the latest.
Eadwine Rose
#6 Post by Eadwine Rose »
I mean the ONLINE version. The site says: Use Sweet Home 3D Online or download.
I was going to take a looksee online, since that might be useful elsewhere :) But the java in both browsers won't kick in. But that is a question for elsewhere on this forum, not this thread :)
Oh wait.. "Sweet Home 3D Online may run under Windows with Internet Explorer and under Mac OS X 10.7 to 10.13 with Safari.
It requires JavaScript and Java 5 or superior (Java SE 6 update 10 or superior preferred)."
I turned on the IE10 ieonchrome extension and it works in there. Just ignore the failure blahblah message.
mmikeinsantarosa
#7 Post by mmikeinsantarosa »
Eadwine Rose wrote:I mean the ONLINE version. The site says: Use Sweet Home 3D Online or download.
Good to know!
#8 Post by Stevo »
I thought Firefox and Chrome don't support the Java browser plugins any longer. That's weird if it works. Maybe it's just using Javascript.
Eadwine Rose
#9 Post by Eadwine Rose »
It does if you use ieonchrome in Chrome, like I said, and use IE10. :) It doesn't work otherwise.
srq2625
#10 Post by srq2625 »
Version 6.1 was released 22JAN2019 (6.1.2 on 01FEB2019) and there are A LOT of features improved/updated/fixed/created when compared to 5.7 (see this page --> http://www.sweethome3d.com/history.jsp):
Added the ability to rotate and slide openings and light spots.
Added a mannequin which can be articulated.
Replaced the 24 3D models contributed under LAL license in the default catalog by new models under GNU GPL / CC-BY license.
Updated rotating and sliding parts in the 3D model of doors, windows and furniture to support new rotation and translation capabilities.
Added price management with currency choice and optional sales tax in preferences pane, new Price and Sales tax % fields in furniture modification pane, total prices displayed below the home furniture list and new columns to display price information in this list.
Added the ability to calculate math expressions in numeric fields.
Added Plan > Flip horizontally and Plan > Flip vertically menu items.
Added support for multi line and text alignment in text modification pane.
Added X offset and Y offset spinner in texture modification pane to shift textures.
Enabled multi selection of materials in materials modification pane to change them by group.
Added Dash offset spinner in polyline modification pane to shift the pattern of dashed polylines.
Allowed polylines to be displayed in the 3D view.
Added an option in 3D view modification pane to view background image in 3D view at ground level.
Added Plan > Make level the only viewable one and Plan > Make all levels viewable menu items.
Displayed level menu items in a separate contextual menu bound to level tabs.
Managed Ctrl modifier (alt or option under macOS) to resize the selected piece of furniture only along its width or its depth.
Added a new indicator in the middle of the selected wall to easily change its curve.
Displayed wall arc length in the tool tip associated to Arc extent field in wall modification pane.
Allowed sloping walls to have a minimum height equal to 0 on one end.
Added 2.40:1 image ratio and updated video formats.
Saved column widths of the furniture list to restore them at home opening.
Made underground objects of a group individually dig the ground in the 3D view.
Increased Z-buffer depth to 24 bit when supported, to simplify the management of the front and back limits of the frustrum in the 3D view.
Ensured equirectangular images are correctly mapped in the 3D view when used as sky texture.
Forced CSV export encoding to UTF-8 on all systems and added com.eteks.sweethome3d.CSVEncoding system property to set the encoding to another value for backward compatibility.
Checked SH3D files start by ZIP magic number after a file is saved to warn users for rare fail cases.
Fixed angle of grouped furniture according to the angle of leading selected piece.
Fixed furniture and texture libraries loading under Java 10.
Improved HiDPI screens detection with Java 8/10 under Windows / Linux / macOS to automatically scale the user interface.
Updated Java 3D version to 1.6.1 to support HiDPI screens under Java 10.
Optimized 3D walls update after the move of a door or a window.
Added sunjce_provider.jar library to installation programs to allow access to web sites with https.
Added architecture 32/64 bit radio buttons in Windows installer and selected 32 bit by default under Windows 10 64 bit.
Added support for ARM64 architecture in Windows installer.
Upgraded Inno Setup to its Unicode version to support more easily non Latin languages in Windows installer.
Bundled macOS installer with Oracle Java 8 and added an other installer based on Apple Java 6 for Mac OS X 10.6/10.7 users.
Replaced JRE 8u162 by JRE 8u181 in Sweet Home 3D installers bundled with Java.
Can I make a request for 6.1.2 be included in the test repo?
AsusTek PRIME B450-Plus
Samsung SSD 860 EVO 500GB
DDR4 3200MHz CL16 2x8GB
Locked
