-- Change in MX sources
-- antiX-17 release info here
Adding gnome-calculator version 3.10
qwertyblahblah
#1 Post by qwertyblahblah » Tue Jan 16, 2018 5:12 am
Is it possible to package version 3.10 of gnome-calculator for MX-17 testing? I don't like galculator, and I don't like the Gnome 3 titlebar and menu on the recent versions of gnome-calculator. I just want to stay with the pc calculator I find comfortable to use, since I first used Linux Mint. When I moved to MX-16 I was able to download and install the deb package from Jessie-based Ubuntu 14.04 here...
https://packages.ubuntu.com/trusty/gnome-calculator
Thanks
Last edited by qwertyblahblah on Wed Jan 17, 2018 6:35 am, edited 1 time in total.
paul1149
Re: MX-17 package request: gnome-calculator version 3.10
#2 Post by paul1149 » Tue Jan 16, 2018 9:23 am
In the meantime you can find it at http://snapshot.debian.org/package/gnom ... /3.10.2-1/
I just discovered, though, that gcalc doesn't have memory. Strange omission.
There's also SpeedCrunch, but again, no memory that I can see.
#3 Post by Jerry3904 » Tue Jan 16, 2018 9:34 am
It does in scientific mode, right?
paul1149
#4 Post by paul1149 » Tue Jan 16, 2018 9:39 am
I didn't see it, Jerry. Might have missed it. But Sci mode is too big for my normal usage. It does access the system clipboard, which is good in a pinch but not for persistent storage. I like its 'paper' display, and will use galculator as a backup when I need memory.
qwertyblahblah
#5 Post by qwertyblahblah » Tue Jan 16, 2018 12:00 pm
paul1149 wrote:In the meantime you can find it at http://snapshot.debian.org/package/gnom ... /3.10.2-1/
Woah, that snapshot archive looks handy! I don't know how I hadn't come across it before. But I'm confused, can I install it onto MX-17/Stretch? Is it backported to Stretch?
Saving calculations in memory like a real calculator should be sufficient, but another reason I don't like the current gcalc is that it retains display of all calculations you enter.
paul1149
#6 Post by paul1149 » Tue Jan 16, 2018 12:04 pm
It installed successfully here, on MX17 x64.
#7 Post by Stevo » Tue Jan 16, 2018 7:07 pm
There's no guarantee that an older GNOME 3 package like that is going to work on 3.22, especially with the way GNOME messes around with APIs. But if it works, more power to you!
paul1149
#8 Post by paul1149 » Tue Jan 16, 2018 7:10 pm
It seemed to work fine. I used it for a few minutes. But I like the newer version better, so I switched back.
qwertyblahblah
Adding gnome-calculator version 3.10?
#9 Post by qwertyblahblah » Wed Jan 17, 2018 6:34 am
Stevo wrote:There's no guarantee that an older GNOME 3 package like that is going to work on 3.22, especially with the way GNOME messes around with APIs. But if it works, more power to you!
Yeah the gcalctool 3.10.2_all deb installed 3.22. But the gnome-calculator 3.10.2 amd64 deb below installed fine. It was 3.10.3 I liked over this 3.10.2, but oh well it's close enough I'll live with it.
As the solution didn't have to be adding to MX feel free to move the thread.
paul1149
Re: Adding gnome-calculator version 3.10?
#10 Post by paul1149 » Wed Jan 17, 2018 9:12 am
qwertyblahblah wrote:It was 3.10.3 I liked over this 3.10.2, but oh well it's close enough I'll live with it.
Did you see the mother page? http://snapshot.debian.org/package/gnome-calculator/
Return to “Package Requests/Status - MX 17”
