Description
Darktable manages your digital negatives in a database and lets you view them through a zoomable lighttable. it also enables you to develop raw images and enhance them.
It tries to fill the gap between the many excellent existing free raw converters and image management tools (such as ufraw or f-spot). The user interface is built around efficient caching of image metadata and mipmaps, all stored in a database. the user will always be able to interact, even if the full resolution image is not yet loaded.
All editing is fully non-destructive and only operates on cached image buffers for display. the full image is only converted during export. The frontend is written in gtk+/cairo, the database uses sqlite3, raw image loading is done using rawspeed, high-dynamic range, and standard image formats such as jpeg are also supported. The core operates completely on floating point values, so darktable can not only be used for photography but also for scientifically acquired images or output of renderers (high dynamic range).
MX 17 Repository: The Darktable Thread
For digital photography enthusiasts, we now have Darktable 2.4.0 in the MX 17 64-bit test repository, backported from Debian Sid. Note that, following Debian, we only have a 64-bit version, as they disabled 32-bit builds because of the developers dropping support for it and the builds turning out to be very crash-prone.
Re: MX 17 Repository: The Darktable Thread
Thank you ! :)
Would it be possible to also have darktable 2.4.x on MX16 ? I have several problems with MX17... but not related with darktable.
Updated to 2.6.2 in the test repo.
New Features
Update colorbalance french translation
Bugfixes
Fix SSE bug in filmic introduced in #2025
Fix issue when looking for input color profile (backward compatibility)
Add missing Czech translation file
Fix possible halo issue in local contrast module.
Fix contextual help link to point to new HTML manual for 2.6 series.
Changed Dependencies
None.
Camera support, compared to 2.6.1
Base Support
DSC-RX100M6
Phase One P30 (fixed)
Olympus OM-D E-M10 (enhanced)
Nikon D7500 (enhanced)
White Balance Presets
Nikon D500
Olympus E-PL8
Noise Profiles
Sony SLT-A35
Nikon Z6
Translations
Catalan
Czech
Dutch
Finnish
French
German
Norwegian bokmål
Polish
Russian
Slovenian
Spanish
New Features
Bugfixes
None.
Base Support
DSC-RX100M6
Nikon D500
Olympus E-PL8
Noise Profiles
Sony SLT-A35
Nikon Z6
Translations
Catalan
Czech
Dutch
Finnish
French
German
Norwegian bokmål
Polish
Russian
Slovenian
Spanish
FWIW - I've been a long time user of darktable and I know something about how that software works.
I've been using 2.6.2, from the Test Repo, for a couple of weeks (having only recently realized how easy it is to use software from the Test Repo) and it seems to be working a real treat and would vote (should my vote be worth anything) for it to be promoted to the main MX repo.
AsusTek PRIME B450-Plus
Samsung SSD 860 EVO 500GB
DDR4 3200MHz CL16 2x8GB
Thanks for the report!
