MX 17/18 Repository: The Ksnip Thread
mmikeinsantarosa
#1 Post by mmikeinsantarosa »
The latest ksnip-1.4.0 updated to qt5 is now available for download from the main repo.
For additional information about this release, check out the authors github.
Ksnip is a Qt based Linux screenshot tool inspired by the Window Snipping Tool.
Taking Screenshot of a custom rectangular area that can be drawn with mouse cursor.
Taking screenshot of the screen/monitor where the mouse cursor is currently located.
Taking screenshot of full screen, including all screens/monitors.
Taking screenshot of window that currently has focus.
Take screenshot with or without mouse cursor.
Customizable capture delay for all capture options.
Upload screenshots directly to imgur.com in anonymous or user mode.
Drawing on captured screenshot with two different tools, pen (opaque) and maker (semi-transparent).
Drawing two shapes ellipse and rectangle, with and without fill.
Drawing lines and arrows.
Customizable color and size (thickness) for all drawing tools.
Writing text on screenshots, with customizable font, size, color etc.
Numbering tool with customizable font and color.
Any drawing (or multiple selection) can be moved around without deleting it by simply dragging it to new location.
Ordering paint items (bring to front, send to back).
Cropping captured screensshot, including any drawing on the captured image.
Command line support, for taking screenshot and saving it to default location, filename and format.
Customizable default location, filename and format for saving new screenshots with wildcards for Year ($Y), Month ($M), Day ($D) and Time ($T).
Print screenshot or save is to pdf/ps.
Undo/Redo for paint and crop operations.
Smooth out free hand pen and marker lines (can be disabled in settings).
Drop shadow for paint items (can be disabled in settings).
And other configuration options.
Last edited by mmikeinsantarosa on Sun Feb 23, 2020 4:51 pm, edited 4 times in total.
Re: MX 17 Repository: The Ksnip Thread
#2 Post by asqwerth »
Version 1.4.0-alpha works on MX17b2 without compositing.
Yay!
#3 Post by asqwerth »
dporobic wrote:The missing include should have been fixed couple of days ago, I have replaced it with qtmath and added the include where any of the math functions is used, do you still see some build errors?
The 1.4.0 version is currently in active development and I'm pushing daily new commits, but I hope it will be done until next weekend and ready for release.
Oops, there is a new issue. I've reported it here: https://github.com/DamirPorobic/ksnip/issues/51
#4 Post by asqwerth »
There is an update to the 1.4-alpha that hopefully fixes the right shift issue I reported above. Could this be packaged in Test Repo for further testing?
Dev's comments:
I might have fixed the right shift issue by fixing another issue #52.
I'm bypassing the X11 window manager when using the rect area selection and it seems to be working now. There is still some testing from my side, but it would be nice someone else could test
https://github.com/DamirPorobic/ksnip/i ... -350548250
mmikeinsantarosa
#5 Post by mmikeinsantarosa »
asqwerth wrote:There is an update to the 1.4-alpha that hopefully fixes the right shift issue I reported above. Could this be packaged in Test Repo for further testing?
Dev's comments:
The 1.3.2 for MX 15/16 is done and the link sent to Tim. I'll check out the new 1.4 for MX17 next.
mmikeinsantarosa
#6 Post by mmikeinsantarosa »
The updated set for ksnip-1.4.0-alpha will go into MX 17 test with a +3 in the revision label. - mike
#7 Post by asqwerth »
Thanks, gonna test now.
mmikeinsantarosa
#8 Post by mmikeinsantarosa »
asqwerth wrote:Thanks, gonna test now.
neither new set has actually made it into our repos yet.
Here's a link to the one for MX 17 if you can't wait.
I tired them in a VM with composting off and they worked for me.
#9 Post by asqwerth »
It works, but I'm not sure I like that new X and Y cross hairs thingy for selecting area.
#10 Post by richb »
Working for me as well. And I do like the crosshairs. They can be suppressed in the options.
Locked
