MX-16 KDE task bar SOLVED
Help on all MX Re-spins
eemaestro
#1 Post by eemaestro »
I have been trying to change the background color and font color on the KDE taskbar or launch bar or panel-- the GUI effect with the big K. I know there's a way because I did it on the MX_16 Live DVD. But I can't seem to find it now.
Re: MX-16 KDE task bar
#2 Post by Jerry3904 »
KDE >> Modified
#3 Post by Stevo »
The look of the panel is part of a KDE theme, so can be changed by changing the theme. You can also mix and match elements of your installed themes to create and save a customized one--panel background is one of the elements. I don't know about customizing the font color, though--you may have to get into editing a theme configuration file there.
eemaestro
#4 Post by eemaestro »
Thank you, Stevo. That helped somewhat.
Return to “MX Respins”
