Forum users
--MX-23 release info here
kalternatives can break REMASTERcc
Help on all MX Re-spins
yop
#1 Post by yop »
KDE-MX users might be tempted to run
sudo kcmshell4 kalternatives
and set the XTERM to Konsole instead of xfce.wrapper.
A rude awakening will follow when you try to remaster , which will break. You either have to unchange the kalternative or change the
line 370 of /usr/local/bin/live-remaster from
           sleep 1
        done
to
            sleep 600         ## 600 sec hardcoded  works in konsole, else break in second loop
        done
the 600 sec value must be longer than your remaster usually takes to finish.
One still ends up with a workable linuxfs.tmp, however. rename it to linuxfs.new and reboot. all is fine.
a proper fix would be to test for the proper terminal in the remaster script, or at least call xfce-terminal directly.
lesson: the simple way works better. :fox:
Return to “MX Respins”
