All packages were updated to the current versions in the main repos, plus I upgraded LibreOffice to version 5 via the Package Installer. I found that removing /etc/skel/.config/Trolltech.conf fixes the appearance problems that were appearing in KDE with any other style than Oxygen. Qt 5 apps in xfce still look good (looks like the oxygen style, which I have KDE using), so it seems they don't need that .conf file if KDE is installed.
Still to do for the next one: Remove Shotwell, not really needed since Digikam's installed. Decide if I really want both Firefox and Pale Moon installed. Anyway, the ISO is still just over 1.3 GB, even with those duplicate purpose applications installed, as well as the great MX 15 xfce4 desktop and my attempt at a functional (though generic-appearing) KDE desktop.
Link: http://mxrepo.com/snapshots/MX15-x64_KD ... eb2016.iso
md5sum: c83d59e83acec7f781c21e4d4ce826d7
Edit: switch to snapshots repo link.
Unofficial MX 15-64 KDE snapshot
Re: Uploaded updated snapshot of my 64-bit xfce+KDE "respin"
Can we find a way to give your remaster a generic name (as I do with the Manual link at mxum.html) so that the remaster webpage does not have to be redone every time you upgrade?
That sounds like a very good idea; I'm open to suggestions. Is that implemented for Adrian's snapshots?
Edit: Do you mean just refer to it as "MX 15 KDE"? I've no problems doing that.
Re: MX 15 KDE February snapshot
--Adrian's snapshots are stored in a single directory on mxrepo.com, so all the snapshot links just point to the directory and the user picks out the most recent one.
--Each new version of the User Manual is given the same name, mxum.html, when it is uploaded to the directory on mepiscommunity.org and the preceding one is removed, so the link on the Manuals tab always works.
I'm not sure what would work best for you, though mxrepo.com seems like a good place to start.
I'll send the link to Tim and see if he can add the ISO to the repo.Jerry3904 wrote:--Adrian's snapshots are stored in a single directory on mxrepo.com, so all the snapshot links just point to the directory and the user picks out the most recent one.
Which repo? We don't want it mirrored, do we? I would suggest a new directory "remasters" if Tim thinks that would work.
It's working fine.
Deserves a little bit of polish. Only looked at kde and found a lot of old stuff in klipper. And lancelot has /home/steve and some recently used documents. Could be more stuff hiding in there.
Only tested live, the traces of the developer probably disappear when you install and create a new user.
Henry
Henry
That history must have been copied into /etc/skel when I copied the ~/.kde folder into it so my customizations would be installed. I don't think there's anything important in my history there, it's probably extremely boring, in fact. I'll see if I can remove those, though.
Any thoughts about the appearance? I stuck with the good old generic Oxygen style and icons, but I was itching to use one of the Kvantum styles (installed by default). Dark or light?
I think it looks good as it is. A nice balance between tradition and new stuff. Beautiful wallpaper.
Henry
Henry
I'm also using the "adjustable clock" widget in the taskbar instead of the standard digital clock--it allows for more tinkering with the appearance, IMO.
