When I look at PulseAudio Manager > Devices, I sometimes see parameters listed but at other times, nothing is listed for sinks and sources.
When I inspect Kmix > Audio Setup > Audio and Video Settings - KDE Control Module > Audio Playback > Music, I sometimes see devices listed and other times see nothing listed.
I know that once when I was asked by a box if I wanted KDE to remember the various sound devices, I clicked on "No" and that caused some bad change. But then I did something and now sometimes see various sound devices listed.
I don't know if plugging in my headphones (so that I can use the VoIP at Gmail) into the port at the back of my desktop tower is somehow causing changes. In a day, I might switch a few times between plugged-in headphones and plugged-in computer speakers but this never caused any troubles in the past.
I'd be appreciative if someone here can offer some guidance.
My hardware and sound/audio info outputs from these commands:
Sound info found on Tues. 12 Jan. 2016:
# amixer
ALSA lib pulse.c:243:(pulse_connect) PulseAudio: Unable to connect: Access denied
amixer: Mixer attach default error: Connection refused
# arecord -l
**** List of CAPTURE Hardware Devices ****
card 0: Intel [HDA Intel], device 0: ALC662 rev1 Analog [ALC662 rev1 Analog]
Subdevices: 0/1
Subdevice #0: subdevice #0
card 0: Intel [HDA Intel], device 2: ALC662 rev1 Alt Analog [ALC662 rev1 Alt Analog]
Subdevices: 1/1
# arecord -L
default
Playback/recording through the PulseAudio sound server
null
Discard all samples (playback) or generate zero samples (capture)
pulse
PulseAudio Sound Server
sysdefault:CARD=Intel
HDA Intel, ALC662 rev1 Analog
Default Audio Device
front:CARD=Intel,DEV=0
Front speakers
surround21:CARD=Intel,DEV=0
2.1 Surround output to Front and Subwoofer speakers
surround40:CARD=Intel,DEV=0
4.0 Surround output to Front and Rear speakers
surround41:CARD=Intel,DEV=0
4.1 Surround output to Front, Rear and Subwoofer speakers
surround50:CARD=Intel,DEV=0
5.0 Surround output to Front, Center and Rear speakers
surround51:CARD=Intel,DEV=0
5.1 Surround output to Front, Center, Rear and Subwoofer speakers
surround71:CARD=Intel,DEV=0
7.1 Surround output to Front, Center, Side, Rear and Woofer speakers
dmix:CARD=Intel,DEV=0
Direct sample mixing device
dmix:CARD=Intel,DEV=2
HDA Intel, ALC662 rev1 Alt Analog
dsnoop:CARD=Intel,DEV=0
Direct sample snooping device
dsnoop:CARD=Intel,DEV=2
hw:CARD=Intel,DEV=0
Direct hardware device without any conversions
hw:CARD=Intel,DEV=2
plughw:CARD=Intel,DEV=0
Hardware device with all software conversions
plughw:CARD=Intel,DEV=2
# cat /proc/asound/cards
0 [Intel ]: HDA-Intel - HDA Intel
HDA Intel at 0xd0500000 irq 28
# lspci | grep -i audio
00:1b.0 Audio device: Intel Corporation NM10/ICH7 Family High Definition Audio Controller (rev 01)
# hwinfo --sound
11: PCI 1b.0: 0403 Audio device
[Created at pci.328]
Unique ID: u1Nb.etibfPtzI26
SysFS ID: /devices/pci0000:00/0000:00:1b.0
SysFS BusID: 0000:00:1b.0
Hardware Class: sound
Model: "Intel NM10/ICH7 Family High Definition Audio Controller"
Vendor: pci 0x8086 "Intel Corporation"
Device: pci 0x27d8 "NM10/ICH7 Family High Definition Audio Controller"
SubVendor: pci 0x8086 "Intel Corporation"
SubDevice: pci 0xd613
Revision: 0x01
Driver: "snd_hda_intel"
Driver Modules: "snd_hda_intel"
Memory Range: 0xd0500000-0xd0503fff (rw,non-prefetchable)
IRQ: 28 (926 events)
Module Alias: "pci:v00008086d000027D8sv00008086sd0000D613bc04sc03i00"
Driver Info #0:
Driver Status: snd_hda_intel is active
Driver Activation Cmd: "modprobe snd_hda_intel"
Config Status: cfg=new, avail=yes, need=no, active=unknown
# aplay -l
**** List of PLAYBACK Hardware Devices ****
Subdevices: 0/1
card 0: Intel [HDA Intel], device 1: ALC662 rev1 Digital [ALC662 rev1 Digital]
Subdevices: 0/1
# inxi -A
Audio: Card Intel NM10/ICH7 Family High Definition Audio Controller driver: snd_hda_intel
Sound: Advanced Linux Sound Architecture v: k4.2.0-0.bpo.1-amd64
# inxi -F
System: Host: mx15 Kernel: 4.2.0-0.bpo.1-amd64 x86_64 (64 bit) Desktop: KDE Plasma 4.14.2
Distro: MX-15_x64 Fusion 24 December 2015
Machine: System: DakTech product: Discovery8 v: 2009
Mobo: Intel model: DG41RQ v: AAE54511-202 serial: AZRQ91600GHK
Bios: Intel v: RQG4110H.86A.0010.2009.0408.1515 date: 04/08/2009
CPU: Dual core Intel Core2 Duo E8500 (-MCP-) cache: 6144 KB
clock speeds: max: 3163 MHz 1: 1998 MHz 2: 1998 MHz
Graphics: Card: Intel 4 Series Integrated Graphics Controller
Display Server: X.org 1.16.4 drivers: intel (unloaded: fbdev,vesa)
tty size: 180x66 Advanced Data: N/A for root
Network: Card: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller driver: r8169
IF: eth0 state: up speed: 1000 Mbps duplex: full mac: 00:1c:c0:ca:00:e1
Drives: HDD Total Size: 400.1GB (44.4% used) ID-1: /dev/sda model: ST3400832AS size: 400.1GB
Partition: ID-1: / size: 15G used: 5.4G (38%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 2.6G used: 847M (35%) fs: ext4 dev: /dev/sda6
ID-3: swap-1 size: 4.05GB used: 0.13GB (3%) fs: swap dev: /dev/sda5
Sensors: System Temperatures: cpu: 37.0C mobo: N/A
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 178 Uptime: 5:29 Memory: 2637.4/3918.5MB Client: Shell (bash) inxi: 2.2.31
From Audacity 2.0.6, Help > Audio Device Info:
Default recording device number: 5
Default playback device number: 5
Device ID: 0
Device name: HDA Intel: ALC662 rev1 Digital (hw:0,1)
Host name: ALSA
Recording channels: 0
Playback channels: 2
Low Recording Latency: -1.000000
Low Playback Latency: 0.005805
High Recording Latency: -1.000000
High Playback Latency: 0.034830
Supported Rates:
44100
48000
96000
Device ID: 1
Device name: HDA Intel: ALC662 rev1 Alt Analog (hw:0,2)
Host name: ALSA
Recording channels: 2
Playback channels: 0
Low Recording Latency: 0.005805
Low Playback Latency: -1.000000
High Recording Latency: 0.034830
High Playback Latency: -1.000000
Supported Rates:
Device ID: 2
Device name: iec958
Host name: ALSA
Supported Rates:
44100
48000
96000
Device ID: 3
Device name: spdif
Host name: ALSA
Supported Rates:
44100
48000
96000
Device ID: 4
Device name: pulse
Host name: ALSA
Recording channels: 32
Playback channels: 32
Low Recording Latency: 0.008707
Low Playback Latency: 0.008707
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Device ID: 5
Device name: default
Host name: ALSA
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Selected recording device: 5 - default
Selected playback device: 5 - default
Supported Rates:
8000
9600
11025
12000
15000
16000
22050
24000
32000
44100
48000
88200
96000
176400
192000
Available mixers:
Available recording sources:
0 - Front Mic:0
1 - Rear Mic:0
2 - Line:0
3 - Front Mic:1
4 - Rear Mic:1
5 - Line:1
Available playback volumes:
0 - Master:0
1 - PCM:0
2 - Front:0
3 - Front Mic:0
4 - Front Mic Boost:0
5 - Surround:0
6 - Center:0
7 - LFE:0
8 - Line:0
9 - Beep:0
10 - Rear Mic:0
11 - Rear Mic Boost:0
Recording volume is native
Playback volume is native
