Add Program to Panel
I just took the leap from Mepis 11 to MX 15 KDE. How do i add a program to the bottom panel, specifically Thunderbird. I like to put my most used programs there instead of using the KDE (Lancelot) launcher.
Re: Add Program to Panel
Solved! I just found the "old" KDE launcher menu! It's a widget!
Good for you. Thanks BTW for posting this in the correct forum!
I'll keep playing with it, but being based on KDE makes it a lot easier for me to learn! Thanks!
Keep in mind that Stevo had an excellent KDE remix available.
The other way is to find the .desktop launcher file for the program in /usr/share/applications, then drag and drop it onto the quicklaunch part of the panel (you'll see a "target" spot).
I probably should thank Stevo! I'm using his MX15-x64_KDE version.
