Please upgrade “pdf-presenter-console v3.1.1“ to v4.0.7
nanoSYS
Post by nanoSYS » Wed Aug 23, 2017 10:43 am
Would it be possible to upgrade “pdf-presenter-console version 3.1.1“ (2012) to version 4.0.7 ?
https://pdfpc.github.io/
https://github.com/pdfpc/pdfpc
pdfpc has been developed by Jakob Westhoff, David Vilar, Robert Schroll, Andreas Bilke, Andy Barry, Phillip Berndt and others. It was previously available at https://github.com/davvil/pdfpc
pdfpc is a fork of Pdf Presenter Console by Jakob Westhoff, available at https://github.com/jakobwesthoff/Pdf-Presenter-Console
Thank you for your consideration on this matter.
Cheers!
Re: Please upgrade “pdf-presenter-console v3.1.1“ to v4.0.7
Post by Stevo » Wed Aug 23, 2017 6:04 pm
On it--have three builds going on at once--MX 15/16 32-bit, and MX 17 32&64 bit, courtesy of the pbuilder system. The first MX 15 64-bit build had no issues. I got the 4.0.7 sources from Debian testing.
Edit: here are the packages, if you want to try them before they hit the test repo: https://drive.google.com/open?id=0BxE7w ... VpPdlZvX0E
nanoSYS
Post by nanoSYS » Wed Aug 23, 2017 8:18 pm
Stevo, I gave it a thorough run on my MX16.1, 64 bit machine, with the MX15 64-bit build, all well! No glitches or bugs that I could detect.
Tried to install the MX17 64-bit built, but the gdebi status: “error:dependency not satisfiable...”
“To get a better feeling of pdfpc, install it, download the demo presentation (https://pdfpc.github.io/demo/pdfpc-demo.pdf) and start it with pdfpc"
I’m quite pleased to be able to use this program on MX for my pdf presentations now.
Thank you so very much !!
Post by Stevo » Wed Aug 23, 2017 8:32 pm
Yes, the MX 17 version was built on a Debian Stretch base, as will MX 17 itself, so a lot of MX 17 packages won't necessarily be backwards-compatible. That's just how these things work. All those packages are built from the same source code.
Post by richb » Wed Aug 23, 2017 8:39 pm
Please explain what you are calling MX 17. As far as I know it does not exist. If it is some pre build it can be a source of confusion, as it it is to me, for users who think it exists and is somewhere available.
Rich
SSD Production: MX 17.1
Post by Jerry3904 » Wed Aug 23, 2017 8:44 pm
He means the pre-alpha.
Post by richb » Wed Aug 23, 2017 8:54 pm
Thanks for clearing that up. I was unaware there was any significant work on a pre-alpha.
Rich
Post by Jerry3904 » Wed Aug 23, 2017 10:28 pm
Actually quite a bit
Post by Stevo » Wed Aug 23, 2017 11:13 pm
Yes, while I'm working on a package now, if it's not in Stretch already, I'll try and build versions on a Stretch base for MX 17. That way I won't forget it. And they could come in useful for those with a stretched MX 16.
Though many will probably need updates further up the road.
#10
Post by richb » Thu Aug 24, 2017 5:52 am
Jerry3904 wrote:Actually quite a bit
Out of the loop, I guess.
Rich
