  • Mepis support still here
  • MX-17.1 Final release info here
  • antiX-17 release info here
  • Read Forum Rules
MX 15 Repository: The fotoxx thread
mmikeinsantarosa
#1 Postby mmikeinsantarosa » Fri Oct 23, 2015 5:53 pm
We have the latest fotoxx-15.10 available for testing from the test repo.
Fotoxx is an all-in-one complex image editor and collection manage open source graphical software. It provides users with powerful tools for manipulating image files made with a digital camera.
Check out the fotoxx site for more info.
LT: Intel Core i7-6820HQ Kernel: 4.12.0-8.3-liquorix-amd64 x86_64 (64 bit)
mmikeinsantarosa
Re: MX 15 Repository: The fotoxx thread
#2 Postby mmikeinsantarosa » Sat Nov 07, 2015 6:39 pm
fotoxx-15.11 is now available for download from our test repo. Unfortunately, the sliders are still broken when built on a wheezy base so there won't be any new fotoxx for MX-14/MEPIS-12 until that's fixed.
Fotoxx 15.11 is released with the following changes:
Folders in gallery pages show counts for both contained sub-folder and images.
Pattern: pattern can imprint target image without changing image colors.
Adjust HSL: the amount of color change is proportional to the match with a selected target color, and this match range is adjustable.
Batch Convert: more flexibility in the formatting of output file names.
New: make a spherical image projection with variable radius of curvature.
Trim/Rotate: if an image is levelled using mouse drag, the trim rectangle is automatically maximized, removing the need to do this manually.
If an edit dialog is started and left/right image margins are present, the image is pushed to the right side so the dialog can be positioned over the expanded left margin and menu panel, minimizing the image area covered. This position is saved and restored the next time the dialog is used.
Saving to file type .bmp was removed, since all metadata is lost.
A new transition type was added to Slide Show: collapsing sphere.
Six other minor improvements and minor bug fixes were made.
- mike
mmikeinsantarosa
#3 Postby mmikeinsantarosa » Wed Jan 06, 2016 10:16 pm
The latest fotoxx-16.01 is now available for testing from the test repo
The fotoxx-16.0.1 changelog:
Edit Any Metadata and Batch Add/Change Metadata: better user interface:
mouse point and click to select metadata items from a list of likely items.
Panorama: a manual alignment option was added for images with no
clear features in the overlap area that can be used for auto-alignment.
Batch Convert: add an overlay image to output images (e.g. a credit line).
Slide Show: minor changes to improve user interface (details in User Guide).
Image right-shift is now a user option with no more back-and-forth motion.
Search Images: new option for text data matching: case-sensitive or not.
New user option: default gallery sort: file name, file mod date, photo date.
A new function for color saturation was added (separate from Retouch Combo).
Bugfix: Search Images for metadata was including some non-matching images.
Bugifx: possible crash in Select Area if 'extend to corner' option is selected.
Bugfix: Search Images using keyword tags failed for tags with uppercase letters.
Translation updates for Spanish, Catalan, Italian.
Check out the vendor's web site or the latest review at softpedia for more info - mike
mmikeinsantarosa
#4 Postby mmikeinsantarosa » Sat Mar 05, 2016 10:13 pm
The latest fotoxx-16.03 is available for download from the test repo.
* New upstream version
+ New: Blur Background: select one or more areas (foreground) that remain sharp
while the remaining areas (background) are blurred, optionally in proportion
to distance from foreground. Also useful for the classic Tilt-Shift effect.
+ New: Add Transparency: based on brightness, a chosen color, or the inverse.
+ Edit Metadata: Editing a series of images that need some of the same metadata
was made faster and easier with a button to recall previous data.
+ The image size limit for most edit functions was doubled to 250 megapixels
(not realistic for computers having less than 16 GB main memory).
+ Select Area: area edge distance calculation was made 2-3x faster.
+ Select Area: copy/paste retains both transparency and edge distance data.
+ Calibrate Printer Colors: the chart and the procedure were revised, and this
means you have to perform the calibration again (my apologies for this).
+ Bugfix: Mashup: warping overlay images no longer leaves black margins where
an image was pulled inward from the edge.
-mike
KernSpy
#5 Postby KernSpy » Fri Mar 11, 2016 7:25 pm
Been testing this version (16.030 of fotoxx and it seems to work fine. It actually shows up as "Photo Editor" under Graphics. When clicking on world-maps tool / icon, it shows a small box that points to the location to download / get tar balls for using the mapping & world maps part of the program. (fotoxx-maps package not installed).
Note: There is a small message box that appears on the screen when the program starts. It took me awhile to catch what it said, before it went off the screen. This is what it what mine says ..
 "top image directories:
"home/kernspy/Pictures
home/kernspy/desktop/my_pics
thumbnails directory:
home/kernspy/.fotoxx/thunmnails
imagefiles found: 18
index updates needed: 0
index updates: 0  thumbnails: 0  deleted: 0
COMPLETED
Startup the program and drop a photo on the window and you are ready to go. The tool buttons are vertically aligned on the left. Just clicking on one will show a menu with a list of options. I've edited, resized, renamed and saved photos without issue. I've tried out many of the special effects and the program is fun and easy to use. Now I've just got to get away from it for awhile. :smile:
Kern
Acer Aspire M3800, Intel Pentium dual-core E6600, Intel 4 Series Graphics, Intel Audio, 4 GB Ram, XFCE 4, MX15 Fusion. Lenovo G560 Laptop - 4G Ram, Dual-Pentium, MX15 Fusion.
mmikeinsantarosa
#6 Postby mmikeinsantarosa » Sat Apr 02, 2016 6:50 pm
fotoxx-16.03 has been moved to main. - mike
mmikeinsantarosa
#7 Postby mmikeinsantarosa » Thu May 26, 2016 9:07 pm
fotoxx-16.05.1 is now available for download from the test repo.
+ Portuguese language updated.
+ Bugfix: crash if Trim/Rotate initiated from the image popup menu.
Mike
mmikeinsantarosa
#8 Postby mmikeinsantarosa » Wed Jul 06, 2016 8:23 pm
fotoxx-16.07 is available for download from the test repo.
Latest Changes:
Libraw is used in place of Dcraw. Dcraw is no longer required for Fotoxx.
Search Images: there is more flexibility to search for metadata matching
one or more values, one or more substrings, or a range of numeric values.
The denoise method "flatten" was made faster and more effective.
New: Select Area Copy: select a hairy or ragged edge with fine control.
New: Select Area Find Gap: find the gap in a hand-drawn area outline.
Manage Albums: copy and paste from any gallery into an Album gallery
using parallel Fotoxx sessions (album creation and editing made easier).
New user option: set the main window background color.
Bugfix: crash when saving a select area that includes image bottom edge.
- mike
#9 Postby Stevo » Wed Jul 06, 2016 9:36 pm
Installs OK, but still pulls in dcraw. That can be dropped from the Depends, or replaced with libraw10, since it doesn't seem to add that automatically.
It looks like you could port over the fotoxx-maps package from here and list it as a Suggests: for fotoxx.
mmikeinsantarosa
#10 Postby mmikeinsantarosa » Wed Jul 06, 2016 9:59 pm
Stevo wrote:Installs OK, but still pulls in dcraw. That can be dropped from the Depends, or replaced with libraw10, since it doesn't seem to add that automatically.
All done in a +2 and headed up.
Who is online
Users browsing this forum: No registered users and 2 guests
