  • Mepis support still here
  • MX-16.1 release info here
  • antiX-17 release info here
    • Read Forum Rules
MX 15/16 repository: The Kodi Thread
#1 Postby Stevo » Thu Oct 08, 2015 10:40 pm
Kodi-15.1 is now in the test repo.
Please let us know how it install and works if you give it a try!
Re: MX 15 repository: The Kodi Thread
#2 Postby Stevo » Wed Oct 21, 2015 4:09 pm
Updated to the newest 15.2 release.
So far, it will also build on M12/MX 14, but always crashes immediately (segfaults) for me. It may need a newer mesa library, like we have in the experimental repo, to run correctly, much like vlc-2.2 does.
nathan2423
#3 Postby nathan2423 » Wed Dec 30, 2015 11:11 pm
I am running MX-15 and I think I have the test repository enabled, but I don't see Kodi when I look for it in Synaptic. Am I doing something wrong? After looking at the manual I am thinking I am correct but maybe there is another repository? thanks
lucky9
#4 Postby lucky9 » Thu Dec 31, 2015 1:17 am
Check your Preferences/Distribution Tab. Set the preferred distribution to prefer MX. Reload. It should show up then. Be sure to change the preferences back
--Mark Twain
topcat
#5 Postby topcat » Thu Dec 31, 2015 10:48 am
I have been using MX-15 64bit Final for a few days now and with Kodi installed and it runs fine on my 2 machines. We've watched about 5 movies on it without a glitch.
I did not have to make any changes in synaptic repositories/preferences. Just searched for kodi and installed.
Thanks Stevo...
...topcat
Zotac ZBOX-ID91-U (desktop system)
SanDisk Extreme Pro 240GB SATA III SSD
G.SKILL 8GB DDR3 1600 (PC3 12800)
ZOTAC ZBOX nano ID62-U (media streamer)
Silicon Power Slim S60 120GB SATA III SSD
G.SKILL Ripjaws 4GB DDR3L 1600 (PC3L 12800)
#6 Postby Stevo » Thu Dec 31, 2015 4:45 pm
It's actually in the main repo now, since we moved most backported applications there before the final release.
Nathan, have you reloaded Synaptic since MX 15 was installed? That needs to be done to get the full package listing.
nathan2423
#7 Postby nathan2423 » Fri Jan 01, 2016 12:32 am
I am not sure what I was doing wrong but I do have it now. Thanks for all the replies!
nathan2423
#8 Postby nathan2423 » Fri Jan 01, 2016 1:00 am
Not only is it working, and very well, but I am finally able to get the USTVNOW plugin to work, out of the box, which I've never been able to do in the past. Thanks again!
#9 Postby Stevo » Mon Feb 22, 2016 10:28 pm
I've just sent Kodi 16.0 "Jarvis Mark XVI" to Tim for the test repository, so it should be showing up there soon. 15.2 graduated to the main repo some time ago.
(Is this some sort of Conky theme?)
There's a good write-up of the new features and fixes here: https://kodi.tv/kodi-16-0-jarvis-mark-xvi/
This was built by reusing upstream Debian's 16.0-rc3 debian folder, which was close enough to the final release to not need any changes.
As usual with packages in testing, we appreciate any feedback about the install and performance of the program, so it can graduate to the main repo. Thanks!
#10 Postby Stevo » Thu Apr 28, 2016 4:34 pm
Kodi bugfix release 16.1 is now in the test repository.
Fixes done in 16.1:
• Never cache addons directories
• Fix typo when calculating forced ratio size
• AndroidStorageProvider: Ignore /mnt/runtime and don’t call Exists all the way every some 500 ms as this will affect performance
• Set of fixes for DirectX rendering
• Fixed crash under JSON-RPC on iOS/OSX
• 20% performance gain on opening EPG guide window
• Add missing libgif.so to the Android package
• Fix Kodi freezing if no ADSP add-on is present
• EventServer security fix by only allowing localhost
• Fix possible lockup when entering EPG grid
• Fix possible problems with rendering on Windows
• Fix possible non working key presses after a key long press
• Don’t do a video chapter skip if there’s only one chapter
• Fix possible lock up by increasing timeout to let screensavers properly exit
• Fix render capture (bookmark images) on certain hardware with DXVA on Windows
• Fix problem in ZeroConfBrowser that could cause problems on exit
• Fix crash one OSX 10.7 when trying to resolve HDD names
• Fix possible crashes when using VAAPI and DXVA video rendering
• Fix song reported on playback of songs from cuesheet
Who is online
Users browsing this forum: No registered users and 2 guests
