Según "man init" parece que MX viene con Systemd?? (solucionado)
Hola,
Al parecer no hay una opcion para correr otro init que no sea systemd, ¿hice algo mal?.
Saludos.
Saludos.
Quad Core Intel Core i5-8265U
Inspiron 3583
Model: 0WHCP7 UEFI: Dell v: 1.5.1
MX-23
Desktop: Xfce 4.18.2
Inspiron 3583
MX-23
Re: No hay como cambiar el init, viene con Systemd.
inxi -Fxz
pstree
keos@mx1:~
$ inxi -Fxz
System: Host: mx1 Kernel: 4.7.0-0.bpo.1-amd64 x86_64 (64 bit gcc: 4.9.2)
Desktop: Xfce 4.12.2 (Gtk 2.24.25) Distro: MX-16_x64 Metamorphosis 12 December 2016
Machine: Device: laptop System: TOSHIBA product: Satellite L855D v: PSKG2U-06N020
Mobo: TOSHIBA model: Portable PC v: MP UEFI [Legacy]: Insyde v: 6.40 date: 01/14/2013
CPU: Dual core AMD A8-4500M APU with Radeon HD Graphics (-HT-MCP-) cache: 4096 KB
flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm) bmips: 7585
clock speeds: max: 1900 MHz 1: 1700 MHz 2: 1800 MHz 3: 1600 MHz 4: 1600 MHz
Graphics: Card: Advanced Micro Devices [AMD/ATI] Trinity [Radeon HD 7640G] bus-ID: 00:01.0
Display Server: X.Org 1.16.4 drivers: ati,radeon (unloaded: modesetting,fbdev,vesa)
Resolution: 1366x768@60.00hz
GLX Renderer: Gallium 0.4 on AMD ARUBA (DRM 2.45.0 / 4.7.0-0.bpo.1-amd64, LLVM 3.8.1)
GLX Version: 3.0 Mesa 12.0.3 Direct Rendering: Yes
Audio: Card-1 Advanced Micro Devices [AMD] FCH Azalia Controller
driver: snd_hda_intel bus-ID: 00:14.2
Card-2 Advanced Micro Devices [AMD/ATI] Trinity HDMI Audio Controller
driver: snd_hda_intel bus-ID: 00:01.1
Sound: Advanced Linux Sound Architecture v: k4.7.0-0.bpo.1-amd64
Network: Card-1: Qualcomm Atheros AR8162 Fast Ethernet driver: alx port: 3000 bus-ID: 01:00.0
Card-2: Realtek RTL8188CE 802.11b/g/n WiFi Adapter
driver: rtl8192ce port: 2000 bus-ID: 02:00.0
Drives: HDD Total Size: 640.1GB (1.0% used)
ID-1: /dev/sda model: TOSHIBA_MQ01ABD0 size: 640.1GB
Partition: ID-1: / size: 97G used: 4.8G (6%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 1.15GB used: 0.00GB (0%) fs: swap dev: /dev/sda2
Sensors: System Temperatures: cpu: 44.4C mobo: N/A gpu: 42.0
Fan Speeds (in rpm): cpu: N/A
Info: Processes: 192 Uptime: 4 min Memory: 405.2/3421.3MB
Init: SysVinit runlevel: 5 Gcc sys: 4.9.2 Client: Shell (bash 4.3.301) inxi: 2.3.8
keos@mx1:~
keos@mx1:~
$ pstree
init─┬─ModemManager─┬─{gdbus}
│ └─{gmain}
├─NetworkManager─┬─dhclient
│ ├─{gdbus}
│ └─{gmain}
├─acpi_fakekeyd
├─acpid
├─anacron───sh───run-parts───apt───sleep
├─at-spi-bus-laun─┬─dbus-daemon
│ ├─{dconf worker}
│ ├─{gdbus}
│ └─{gmain}
├─at-spi2-registr───{gdbus}
├─atd
├─avahi-daemon───avahi-daemon
├─bluetoothd
├─cgmanager
├─cron
├─cups-browsed
├─cupsd
├─3*[dbus-daemon]
├─2*[dbus-launch]
├─gconfd-2
├─6*[getty]
├─gpg-agent
├─gvfs-afc-volume─┬─{gdbus}
│ └─{gvfs-afc-volume}
├─gvfs-goa-volume───{gdbus}
├─gvfs-gphoto2-vo───{gdbus}
├─gvfs-mtp-volume───{gdbus}
├─gvfs-udisks2-vo─┬─{gdbus}
│ └─{gmain}
├─gvfsd───{gdbus}
├─gvfsd-fuse─┬─{gdbus}
│ ├─{gvfs-fuse-sub}
│ └─2*[{gvfsd-fuse}]
├─haveged
├─lightdm─┬─Xorg───{Xorg}
│ ├─lightdm─┬─sh─┬─ssh-agent
│ │ │ └─xfce4-session───xfce4-session─┬─Thunar
│ │ │ ├─applet.py───{gmain}
│ │ │ ├─nm-applet─┬─{dconf worker}
│ │ │ │ └─{gdbus}
│ │ │ ├─polkit-gnome-au───{gdbus}
│ │ │ ├─usb-unmounter-s───yad───yad───{gdbu+
│ │ │ ├─xfce4-clipman─┬─{gdbus}
│ │ │ │ └─{gmain}
│ │ │ ├─xfce4-panel─┬─oosplash─┬─soffice.bi+
│ │ │ │ │ ├─{osl_execu+
│ │ │ │ │ └─{rtl_cache+
│ │ │ │ ├─palemoon─┬─8*[{Analys+
│ │ │ │ │ ├─{BgHangMan+
│ │ │ │ │ ├─{Cache I/O+
│ │ │ │ │ ├─{Cache2 I/+
│ │ │ │ │ ├─{Cert Veri+
│ │ │ │ │ ├─{Composito+
│ │ │ │ │ ├─{DNS Resol+
│ │ │ │ │ ├─2*[{DOM Wo+
│ │ │ │ │ ├─{Goanna_IO+
│ │ │ │ │ ├─{HTML5 Par+
│ │ │ │ │ ├─{Hang Moni+
│ │ │ │ │ ├─{IPDL Back+
│ │ │ │ │ ├─{ImageBrid+
│ │ │ │ │ ├─{ImageIO}
│ │ │ │ │ ├─{JS Watchd+
│ │ │ │ │ ├─{Link Moni+
│ │ │ │ │ ├─{MediaMana+
│ │ │ │ │ ├─{Proxy R~o+
│ │ │ │ │ ├─{Socket Th+
│ │ │ │ │ ├─{Timer}
│ │ │ │ │ ├─{dconf wor+
│ │ │ │ │ ├─{gdbus}
│ │ │ │ │ ├─{gmain}
│ │ │ │ │ ├─{localStor+
│ │ │ │ │ ├─{mozStorag+
│ │ │ │ │ └─{palemoon}
│ │ │ │ ├─panel-1-xfce4-o
│ │ │ │ ├─panel-17-screen───{gd+
│ │ │ │ ├─panel-20-whiske─┬─{gd+
│ │ │ │ │ └─{gm+
│ │ │ │ ├─panel-5-actions
│ │ │ │ ├─panel-6-systray
│ │ │ │ ├─{gdbus}
│ │ │ │ └─{gmain}
│ │ │ ├─xfdesktop─┬─{gdbus}
│ │ │ │ └─{gmain}
│ │ │ ├─xfwm4───{threaded-ml}
│ │ │ ├─xscreensaver
│ │ │ ├─{gdbus}
│ │ │ └─{gmain}
│ │ ├─{gdbus}
│ │ └─{gmain}
│ ├─{gdbus}
│ └─{gmain}
├─nmbd
├─ntpd
├─polkitd─┬─{gdbus}
│ └─{gmain}
├─pulseaudio─┬─{alsa-sink-ALC26}
│ ├─{alsa-sink-HDMI }
│ └─{alsa-source-ALC}
├─python
├─rpc.idmapd
├─rpc.statd
├─rpcbind
├─rsyslogd─┬─{in:imklog}
│ ├─{in:imuxsock}
│ └─{rs:main Q:Reg}
├─smbd───smbd
├─sshd
├─systemd-logind
├─udevd
├─udisksd─┬─{cleanup}
│ ├─{gdbus}
│ ├─{gmain}
│ └─{probing-thread}
├─upowerd─┬─{gdbus}
│ └─{gmain}
├─volumeicon─┬─{gdbus}
│ └─{threaded-ml}
├─wpa_supplicant
├─xfce4-notifyd───{gdbus}
├─xfce4-power-man───{gdbus}
├─xfce4-terminal─┬─bash───pstree
│ ├─gnome-pty-helpe
│ ├─{gdbus}
│ └─{gmain}
├─xfconfd
└─xfsettingsd─┬─{gdbus}
└─{gmain}
keos@mx1:~
$ man init
keos@mx1:~
Cuando pongo el comando recomendado (man init) para saber que sistema de inicio esta instalado …
SYSTEMD(1) systemd SYSTEMD(1)
NAME
systemd, init - systemd system and service manager
SYNOPSIS
systemd [OPTIONS...]
init [OPTIONS...] {COMMAND}
DESCRIPTION
systemd is a system and service manager for Linux operating systems. When run as first
process on boot (as PID 1), it acts as init system that brings up and maintains userspace
services.
For compatibility with SysV, if systemd is called as init and a PID that is not 1, it will
execute telinit and pass all command line arguments unmodified. That means init and
telinit are mostly equivalent when invoked from normal login sessions. See telinit(8) for
more information.
When run as system instance, systemd interprets the configuration file system.conf,
otherwise user.conf. See systemd-system.conf(5) for more information.
OPTIONS
The following options are understood:
--test
Manual page init(1) line 1 (press h for help or q to quit)
Inspiron 3583
MX-23
Inspiron 3583
MX-23
MX Linux viene con sysvinit --no tiene systemd activado.
Al inicio, escoge un kernel que no dice systemd.
Desde el manual: Debido a que el uso de systemd como administrador de sistemas y servicios ha sido controvertido, queremos ser claros sobre su función en MX Linux. Systemd se incluye de forma predeterminada pero no está habilitada. Puede escanear su sistema MX y descubrir archivos con nombres systemd *, pero los que simplemente proporcionan un gancho de compatibilidad / punto de entrada cuando sea necesario. MX Linux utiliza systemd-shim, que emula las funciones systemd que se requieren para ejecutar los helpers sin utilizar realmente el servicio init. Esto significa que SvsVinit sigue siendo el predeterminado init, pero MX Linux puede usar paquetes Debian que tienen dependencias systemd tales como CUPS. Este enfoque también permite al usuario conservar la capacidad de elegir su init preferido.
I wonder if keos might have manually edited grub like benutzer did in this topic here: viewtopic.php?p=407976#p407976
Google's English to Spanish translation:
Me pregunto si keos podría haber editado manualmente grub como benutzer hizo en este tema aquí: viewtopic.php?p=407976#p407976
Hola keos,
Los desarrolladores han laborado bastante para eliminar systemd.
Hay unas vestigios solamente para compatibilidad pero systemd
no esta ejecutando nativamente. Para ver systemd tuviste de haber
modificado el grub.
Y nota, escogiendo un kernel apto para systemd no iniciar con systemd
--tendra que instalar systemd usted mismo para que esa funcionar.
Entonces, puedes explicar que fue que hiciste para ver systemd?
modificado el grub.
Hola a todos,
Esto es todo un rollo para mi, no he hecho nada extraordinario, solo instale el sistema, y en ingles, porque no puedo loguearme y abrirlo en espanol (f2)
-- el primer kernel que aparece (metamorfosis) es el unico que abre y puedo loguearme, el otro kernel que le sigue no me deja loguearme ...
--entiendo que algunos paquetes esten con systemd como dicen, pero no entiendo porque el init tiene a systemd
Por favor, diganme que debo hacer, que cuidados debo tener en mente para una nueva reinstalacion del sistema.
Saludos.
Saludos.
Inspiron 3583
MX-23
Inspiron 3583
MX-23
No necesitas hacer nada. Una instalación estándar no utiliza systemd como se indica earleir. ¿Tienes otros problemas?
Luego entonces, si me parece entender, la instalacion que tengo es standar y no trae a systemd como init pero cuando aplico los comandos requeridos demuestran todo lo contrario ... eso sí que es un problema para mi pobre comprensión . Gracias.
Saludos.
Saludos.
Inspiron 3583
MX-23
Inspiron 3583
MX-23
