Give MX Tools a "New Look"
Any background image or other artwork submissions must include copyright information and explicit permission of the image's original creator to use the image. This includes a direct post of the image or links to a compiled image archive.
manyroads
#1 Post by manyroads »
I thought people might enjoy seeing the new MX Tools look I developed. I added a bunch of new icons. The screenshot may be seen here:
https://www.dropbox.com/s/1yrdmvxlmf25s ... s.png?dl=0
If anyone wants the iconset... I'm happy to offer it. All icons are in the public domain.
manyroads
Re: Give MX Tools a "New Look"
#2 Post by manyroads »
Here's a how-to change your icons Tutorial:
If you want to edit your MX Tools (panel) and replace the icons, here is what you do:
Open Thunar (or similar) as Root. And do the following:
--- you can use your file manager (as Root) to go to /usr/share/applications/ or
--- use the following cli.
pkexec thunar /usr/share/applications/
Once you see the folder just examine the artifacts and identify those with icons you want to change.
To change an icon simply right-click on the application icon and select "Properties". When the Properties screen opens, you will see the current icon next to "Name:" Click on the icon and a new window will open (Select an Icon). Use the two items "Select icon from:" and "Search icon:"
see image
Go to the new icon folder I provided (mega Link is provided below) or find other icons you prefer.
--- Highlight the "new icon" you want to use by mouse-click.
--- Then select OK.
--- You'll be sent back to the Properties Window.
That's it.
Enjoy.
https://mega.nz/#F!Y8swnCDR!I0_ayBIV9pbMDk8ujXeehw
#3 Post by Jerry3904 »
Good looking stuff, thanks for posting.
manyroads
#4 Post by manyroads »
Jerry3904 wrote: Mon Apr 15, 2019 10:08 am Good looking stuff, thanks for posting.
You are welcome @Jerry3904.
I have noticed that many of the icons in MX are very small (too small?) for use on HD screens; they don't render well. :lipsrsealed: Sometime it might make sense to collect either svg images or larger pngs for use system-wide. I am happy to help with that. :bagoverhead: As an aside, there are now quite a few excellent artists placing nice looking icons on Pixabay.com
Return to “MX Art”
