Problem with pdfshuffler
Hello,l have a problem with pdfshuffler,when i want to save the file changes(rotate one of this pdf file) throw me this error unsupported operand type(s) for +: 'IndirectObject' and 'int' but when there is only one page in the pdf file everything works fine when there are more like them in the picture it throws error.
How to resolve this problem?
https://www.dodaj.rs/images/Screenshot.png
Mod note: Image changed to link. Be mindful of image limits: viewtopic.php?f=133&t=48374
Re: Problem with pdfshuffler
Please run MX Tools/Quick System Info, then right-click paste into a reply. (Quick System Info automatically copies the information to the clipboard and formats it properly for the forum so all you have to do is paste it.) Thanks.
Host: torg Kernel: 4.19.0-5-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
Desktop: Xfce 4.12.3 Distro: MX-18.3_x64 Continuum May 26 2019
Type: Laptop System: LENOVO product: 20137 v: Lenovo G585 serial: <filter>
Mobo: LENOVO model: Lenovo G585 v: INVALID serial: <filter>
UEFI [Legacy]: LENOVO v: 6CCN18WW(V1.05) date: 07/18/2012
ID-1: BAT1 charge: 41.8 Wh condition: 41.8/47.5 Wh (88%)
model: SONY PABAS0241231 status: Full
Topology: Dual Core model: AMD E1-1200 APU with Radeon HD Graphics
bits: 64 type: MCP arch: Bobcat L2 cache: 512 KiB
flags: lm nx pae sse sse2 sse3 sse4a ssse3 svm bogomips: 5589
Speed: 778 MHz min/max: 777/1400 MHz Core speeds (MHz): 1: 778 2: 1205
Device-1: AMD Wrestler [Radeon HD 7310] vendor: Lenovo driver: radeon
v: kernel bus ID: 00:01.0
Display: x11 server: X.Org 1.19.2 driver: ati,radeon
unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
OpenGL: renderer: AMD PALM (DRM 2.50.0 / 4.19.0-5-amd64 LLVM 7.0.0)
v: 3.3 Mesa 18.2.6 direct render: Yes
Device-1: AMD Wrestler HDMI Audio vendor: Lenovo driver: snd_hda_intel
v: kernel bus ID: 00:01.1
Device-2: AMD FCH Azalia vendor: Lenovo driver: snd_hda_intel v: kernel
bus ID: 00:14.2
Sound Server: ALSA v: k4.19.0-5-amd64
Device-1: Realtek RTL8101/2/6E PCI Express Fast/Gigabit Ethernet
vendor: Lenovo driver: r8169 v: kernel port: 2000 bus ID: 02:00.0
Device-2: Qualcomm Atheros AR9485 Wireless Network Adapter vendor: Lenovo
driver: ath9k v: kernel port: 2000 bus ID: 06:00.0
Device-3: Atheros AR3012 Bluetooth 4.0 type: USB driver: btusb
bus ID: 5-3:2
Local Storage: total: 298.09 GiB used: 131.74 GiB (44.2%)
ID-1: /dev/sda vendor: HGST (Hitachi) model: HTS545032A7E380
ID-1: / size: 290.41 GiB used: 131.74 GiB (45.4%) fs: ext4 dev: /dev/sda1
ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda2
System Temperatures: cpu: 66.5 C mobo: N/A gpu: radeon temp: 67 C
1: deb http://la.mxrepo.com/antix/stretch stretch main
Processes: 185 Uptime: 1h 58m Memory: 3.46 GiB used: 1.23 GiB (35.6%)
inxi: 3.0.33
Report copied to system clipboard
Press any key to close
Interesting. I use this app all the time for business--couldn't get along without it--and have never had an error.
No prob here either ... after you make whatever changes needed to the pdf, Save As, give it a name and destination ... see what gives?!
Please edit your post using the pencil icon to wrap the information inside of code tags. Example: [code]log file contents, configuration file contents and terminal text go here[/code]
to make it look like this, which is a lot easier to read for large amounts of text:
1. It really stands out as being separate from the text that you're typing due to the different background and font colors
2. It also puts it inside of its own little frame with its own scrollbars, making it easier to navigate.
Sorry for that,l edit post.
Thanks for editing it. It's much easier to read now.
I don't see any issues with your repositories or your system, but in your other thread
viewtopic.php?f=108&t=51716&p=517215#p517215
you were asking about removing a bunch of programs. Perhaps when you removed one of those it also removed a shared library that pdfshuffler needs. Try removing then reinstalling pdfshuffler and see if that fixes it.
Another thing it could be is a bad or corrupted pdf file. Try it with a different one and see if it has the same problem. You can open LibreOffice Writer, then go to https://lipsum.com/ and generate 20 paragraphs of Lorem Ipsum text then copy and paste it into your Writer document, then in the File dropdown menu choose Export as... and export it as a .pdf file which will be several pages long, then see if you can select more than one page in pdfshuffler and rotate them.
I haven't had the particular problem but I have had a number of similar problems with pdfshuffler. I use it probably 30 times a week, mainly compiling multiple pdf files into one, with various deletions and shuffles. I have a persistent error with files I receive from one Mac user - a multi-page pdf text file and a single page graphics pdf. pdfshuffler fails to save the output. A few years ago, I purchased MasterpdfEditor, which combines these files with no problem.
I still use pdfshuffler as my main tool because of its simplicity and speed.
