I installed the openbox windows manager alongside xfce on my laptop.
Right after the installation Openbox is pretty spartan, so I decided to install themes from SalentOS.
SalentOS is an italian linux distro based on Debian Stretch and a fully customized openbox experience (themes+ softwares to configure openbox etc)
So I added the official repo of this distro to my configuration.
I don't know why but from the graphical MX package manager shows 4 entries for the same package and it warns me that it couldn't authenticate packages... anywyay I can install them.
I'm facing some problems, for example the MX package manager doesn't allow me to install "numix-openbox-salentos-themes" since
it tryes to overwrite "/usr/share/themes/Numix/xfce-notify-4.0/gtkrc" also present in the numix-gtk-theme 2.6.6-1 package
Depends: libvte-2.90-9 but it is not installable
Depends: libvte-dev, but it's not going to be installed (or something like that since I use MX in italian)
Depends: tk
.... and so on
1)these dependencies seem not present in the default MX repos, so I should probably get them from a Debian Stretch Repo
2)some of this dependency-packages are already installed but maybe I must match the versions (libvte-2.91 is installed on my system but the Salentos theme requires libvte-2.90-9)
I asking for your help to avoid mistakes.
Thank you in advance!
