$ sudo systemctl list-units
Failed to list units: No such method 'ListUnitsFiltered'
Is this as expected? I'm trying to get to the status of
systemd timers
systemctl list-units [Solved]
Re: systemctl list-units
MX 18 MX 19 - Manjaro
Did you in fact boot into systemd instead of the default sysV?
Also see the Our Positions section of
https://mxlinux.org/about-us/
OK, I get it now about systemd.
Given that where can I do the equivalent of "sudo crontab -l"
to show system cron jobs. It says "no crontab for root"
btw thank you for your replies
I might be misinterpreting what info you're looking for, but I think you want this:
Or install bum...
service --status-all
sudo apt install bum
Yes it is.pkmorrison wrote: ↑Mon Jul 15, 2019 9:51 am $ sudo systemctl list-units
Is this as expected? I'm trying to get to the status of systemd timers
If you boot with sysVinit, which is the default in Mx Linux, the existing systemd timers:
/etc/systemd/system/timers.target.wants/fstrim.timer
/etc/systemd/system/timers.target.wants/apt-daily-upgrade.timer
/etc/systemd/system/timers.target.wants/apt-daily.timer
/etc/systemd/system/timers.target.wants/anacron.timer
You might rather look in the corresponding ancacron entries used in sysVinit:
cat /etc/anacrontab
# /etc/anacrontab: configuration file for anacron
# See anacron(8) and anacrontab(5) for details.
SHELL=/bin/sh
PATH=/usr/local/sbin:/usr/local/bin:/sbin:/bin:/usr/sbin:/usr/bin
HOME=/root
LOGNAME=root
# These replace cron's entries
1 5 cron.daily run-parts --report /etc/cron.daily
7 10 cron.weekly run-parts --report /etc/cron.weekly
@monthly 15 cron.monthly run-parts --report /etc/cron.monthly
ls -1 /etc/cron*/*
/etc/cron.daily/0anacron
/etc/cron.daily/1-quick-live-update
/etc/cron.daily/2-apt-compat
/etc/cron.daily/apt-compat
/etc/cron.daily/aptitude
/etc/cron.daily/bsdmainutils
/etc/cron.daily/dpkg
/etc/cron.daily/logrotate
/etc/cron.daily/man-db
/etc/cron.daily/mlocate
/etc/cron.daily/ntp
/etc/cron.daily/opera-browser
/etc/cron.daily/passwd
/etc/cron.daily/vivaldi
/etc/cron.d/anacron
/etc/cron.monthly/0anacron
/etc/cron.monthly/vrms
/etc/cron.weekly/0anacron
/etc/cron.weekly/apt-xapian-index
/etc/cron.weekly/fstrim-mx
/etc/cron.weekly/man-db
Re: systemctl list-units [Solved]
Thank you all for your replies. I now get the bigger picture re systemd
and cron.
and cron.
