Hello,
I've found nice program/script for CLI - Googler and installed it.
Unfortunately when I'm trying to search, I only get one message: No results.
I've tested Googler 2.9.0 from MXPI Stable Repo, Googler 3.7.1 from MXPI Debian Backports and 3.8 downloaded directly from:
https://github.com/jarun/googler#downlo ... ingle-file
Minimal requirment for Googler is Python 3.4 (I have 3.5.3 but I've installed additionally 3.7 from MX Test as well).
I've tried Googler on another MX installation (Googler 2.9.0) - the same "No results" message.
Could it be something with Google API as mentioned in Notes, point 2, citatation:
2. Google provides a search API which returns the results in JSON format. However, as per my understanding from the official docs, the API issues the queries against an existing instance of a custom search engine and is limited by 100 search queries per day for free. In addition, I have reservations in paying if they ever change their plan or restrict the API in other ways. So I refrained from coupling with Google plans & policies or exposing my trackable personal custom search API key and identifier for the public. I retained the browser-way of doing it by fetching html, which is a open and free specification.
https://github.com/jarun/googler#notes
Could you install Googler and run it - and can you search through and get any results (others then my 'No results')? Thank you.
Googler (CLI Google Search) - No results (at all)
MX-18 Continuum x86_64: laptop Dell Inspiron N7110, Intel Core i5-2410M @ 2.900GHz, 4GB RAM, Kernel: 4.19, DE: Xfce
Re: Googler (CLI Google Search) - No results (at all)
Well, I have some new observations about Googler script.
Googler (in MX) works with -N argument - News. It displays ok.
Generally, Googler downloads and creates temporary files in /tmp with HTML code, which can be run/opened eg. in Firefox after changing name/adding .html to the file.
The problem probably could be with parser (I suppose, I don't know for sure), which gets HTML code from temporary file and displays it.
I've installed ddgr (Duck Duck Go search in CLI) through pip3 install and it works ok (it is similar to Googler).
I'm not familiar with Python language, which is probably used for Googler, but I'll continue experiments with that script.
This is the area of script/code, which I think is responsible for my issue:
Maybe you will have some hints, how to solve it. Temporary files are in /tmp (but they have not got .html suffix), and the output is 'No results.'. This is for version 2.7 in MX 16.
For version 2.9 and MX 18 I can't find temporary files.
@require_keywords
def fetch(self):
"""Fetch a page and parse for results.
Results are stored in ``self.results``.
Raises
GoogleConnectionError
See Also
fetch_and_display
# This method also sets self._results_filtered and
# self._urltable.
page = self._conn.fetch_page(self._google_url.relative())
if logger.isEnabledFor(logging.DEBUG):
import tempfile
fd, tmpfile = tempfile.mkstemp(prefix='googler-response-', suffix='.html')
os.close(fd)
with open(tmpfile, 'w', encoding='utf-8') as fp:
fp.write(page)
logger.debug("Response body written to '%s'.", tmpfile)
parser = GoogleParser(page, news=self._google_url.news)
self.results = parser.results
self._autocorrected = parser.autocorrected
self._showing_results_for = parser.showing_results_for
self._results_filtered = parser.filtered
self._urltable = {}
for r in self.results:
self._urltable.update(r.urltable())
@require_keywords
def display_results(self, prelude='\n', json_output=False):
"""Display results stored in ``self.results``.
Parameters
See `fetch_and_display`.
if json_output:
# JSON output
import json
results_object = [r.jsonizable_object() for r in self.results]
print(json.dumps(results_object, indent=2, sort_keys=True, ensure_ascii=False))
else:
# Regular output
if not self.results:
print('No results.', file=sys.stderr)
else:
sys.stderr.write(prelude)
r.print()
You can install the 3.8 deb from Sid safely on MX, but it still shows "no results" with a normal search. I think we need to ask Debian users if they have the same problem.
