Bbswitch doesn't turn off gpu after optirun
palevandro
#1 Post by palevandro »
I'm having a problem with optirun, I'm running a python script using the command
optirun python my_script.py
After script execution, the Nvidia didn't turn off, my laptop still using the Nvidia card.
Is there any way to manually turn off GPU after optirun without reboot or restart my laptop?
Here is my system information
System:    Host: ducpv Kernel: 4.19.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
           Desktop: Xfce 4.12.3 Distro: MX-18.2_x64 Continuum Feb 9  2019
Machine:   Type: Laptop System: Notebook product: W35xSTQ_370ST v: N/A serial: <filter>
           Mobo: Notebook model: W35xSTQ_370ST serial: <filter> BIOS: Prema Mod v: 1.03.02PM v2
           date: 03/12/2014
Battery:   ID-1: BAT0 charge: 74.1 Wh condition: 74.1/77.0 Wh (96%) model: NOTEBOOK BAT
           status: Full
CPU:       Topology: Quad Core model: Intel Core i7-4700MQ bits: 64 type: MT MCP arch: Haswell
           rev: 3 L2 cache: 6144 KiB
           flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38311
           Speed: 3248 MHz min/max: 800/3400 MHz Core speeds (MHz): 1: 3256 2: 3184 3: 2914
           4: 2791 5: 2819 6: 2844 7: 3343 8: 3239
Graphics:  Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: CLEVO/KAPOK
           driver: i915 v: kernel bus ID: 00:02.0
           Device-2: NVIDIA GK106M [GeForce GTX 765M] driver: N/A bus ID: 01:00.0
           resolution: 1920x1080~60Hz
           OpenGL: renderer: Mesa DRI Intel Haswell Mobile v: 4.5 Mesa 18.2.6 direct render: Yes
Audio:     Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: CLEVO/KAPOK
           driver: snd_hda_intel v: kernel bus ID: 00:03.0
           Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: CLEVO/KAPOK
           driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Network:   Device-1: Realtek RTL8723AE PCIe Wireless Network Adapter driver: rtl8723ae v: kernel
           port: d000 bus ID: 03:00.0
           Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: CLEVO/KAPOK
           driver: r8169 v: kernel port: c000 bus ID: 04:00.2
           IF-ID-1: docker0 state: down mac: <filter>
Drives:    Local Storage: total: 1.13 TiB used: 677.29 GiB (58.6%)
           ID-1: /dev/sda vendor: Western Digital model: WD10JPVX-22JC3T0 size: 931.51 GiB
           ID-2: /dev/sdb vendor: Kingston model: SH103S3240G size: 223.57 GiB
Partition: ID-1: / size: 217.06 GiB used: 59.42 GiB (27.4%) fs: ext4 dev: /dev/sdb1
           ID-2: swap-1 size: 2.00 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sdb2
Sensors:   System Temperatures: cpu: 66.0 C mobo: N/A
           1: deb http://la.mxrepo.com/antix/stretch stretch main
           1: deb http://ftp.ru.debian.org/debian/ stretch-updates main contrib non-free
           1: deb http://ftp.ru.debian.org/debian/ stretch main contrib non-free
           Active apt repos in: /etc/apt/sources.list.d/docker.list
           1: deb [arch=amd64] https://download.docker.com/linux/debian stretch stable
           1: deb http://mirror.truenetwork.ru/mxlinux/mx/repo/ stretch main non-free
           1: deb https://deb.opera.com/opera-stable/ stable non-free #Opera Browser (final releases)
           Active apt repos in: /etc/apt/sources.list.d/skype-stable.list
           1: deb [arch=amd64] https://repo.skype.com/deb stable main
           Active apt repos in: /etc/apt/sources.list.d/vscode.list
           1: deb [arch=amd64] http://packages.microsoft.com/repos/vscode stable main
Info:      Processes: 265 Uptime: 3h 36m Memory: 15.59 GiB used: 3.52 GiB (22.6%) Init: SysVinit
           runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.33
Re: Bbswitch doesn't turn off gpu after optirun
#2 Post by timkb4cq »
Bbswitch can't disable a video card whose kernel module is still loaded.
Have you tried running
sudo rmmod nvidia
before the bbswitch command?
palevandro
#3 Post by palevandro »
Thank you, I figured it out that if I run another script with optirun but with some errors in the code.
That could help turn off the NVIDIA and back to Intel card.
#4 Post by Stevo »
The Arch wiki recommends
sudo tee /proc/acpi/bbswitch <<<OFF
which would work on my MSI back when Bumblebee was broken on it and I needed to turn off the GPU.
