GPG errors - still! [Solved]
- TenderFoot
Ok what am I doing wrong? I've tried viewtopic.php?f=115&t=48051 which worked last time. Also viewtopic.php?f=131&t=49368. No joy.
MX16.
MX16.
Re: GPG errors - still!
Give more information like:
and post output of
inxi -Fxrz
sudo apt-get update
- TenderFoot
Thanks but seems an overkill of info but here we go!
$ inxi -Fxrz
System: Host: Toshiba Kernel: 4.7.0-0.bpo.1-amd64 x86_64 bits: 64 compiler: gcc v: 4.9.2
Desktop: Xfce 4.12.2 tk: Gtk 2.24.25 Distro: MX-16_x64 Metamorphosis 12 December 2016
Machine: Type: Laptop System: TOSHIBA product: Satellite L350 v: PSLD8E-00D008EN
serial: <filter>
Mobo: TOSHIBA model: Portable PC serial: <filter> BIOS: INSYDE v: 2.20
date: 12/09/2009
Battery: ID-1: BAT0 charge: 23.2 Wh condition: 23.2/44.4 Wh (52%) model: PA3536U-1BRS
status: Unknown
CPU: Topology: Dual Core model: Intel Pentium Dual T3200 bits: 64 type: MCP arch: Conroe
rev: 13 L2 cache: 1024 KiB
flags: lm nx pae sse sse2 sse3 ssse3 bogomips: 7980
Speed: 1000 MHz min/max: 1000/2000 MHz Core speeds (MHz): 1: 1000 2: 1333
Graphics: Card-1: Intel Mobile 4 Series Integrated Graphics driver: i915 v: kernel
bus ID: 00:02.0
Display: server: X.Org 1.16.4 driver: intel unloaded: fbdev,modesetting,vesa
resolution: 1440x900~60Hz
OpenGL: renderer: Mesa DRI Mobile Intel GM45 Express v: 2.1 Mesa 12.0.3
Audio: Card-1: Intel 82801I HD Audio driver: snd_hda_intel v: kernel bus ID: 00:1b.0
Sound Server: ALSA v: k4.7.0-0.bpo.1-amd64
Network: Card-1: Realtek RTL8101E/RTL8102E PCI Express Fast Ethernet driver: r8169
v: 2.3LK-NAPI port: 2000 bus ID: 02:00.0
Card-2: Realtek RTL8187B Wireless Adapter type: USB driver: rtl8187 bus ID: 8:4
Drives: HDD Total Size: 931.51 GiB used: 9.32 GiB (1.0%)
ID-1: /dev/sda vendor: Hitachi model: HGST HTS541010A9E680 size: 931.51 GiB
Partition: ID-1: / size: 14.29 GiB used: 9.32 GiB (65.2%) fs: ext4 dev: /dev/sda10
ID-2: swap-1 size: 4.88 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda9
Sensors: System Temperatures: cpu: 42.0 C mobo: N/A
1: deb http://nl.mxrepo.com/antix/jessie/ jessie main
No active apt repos in: /etc/apt/sources.list.d/debian-stable-updates.list
1: deb http://ftp.uk.debian.org/debian/ jessie main contrib non-free
2: deb http://security.debian.org/ jessie/updates main contrib non-free
1: deb http://nl.mxrepo.com/mx/repo/ mx15 main non-free
Active apt repos in: /etc/apt/sources.list.d/mx16.list
1: deb http://nl.mxrepo.com/mx/repo/ mx16 non-free main
No active apt repos in: /etc/apt/sources.list.d/opera.list
Info: Processes: 191 Uptime: 4h 01m Memory: 3.74 GiB used: 1.47 GiB (39.3%) Init: SysVinit
runlevel: 5 Compilers: gcc: 4.9.2 Shell: bash v: 4.3.30 inxi: 3.0.10
root@Toshiba:/home/chris# sudo apt-get update
Ign http://ftp.uk.debian.org jessie InRelease
Hit http://ftp.uk.debian.org jessie Release.gpg
Hit http://security.debian.org jessie/updates InRelease
Get:1 http://security.debian.org jessie/updates/main amd64 Packages [664 kB]
Get:2 http://security.debian.org jessie/updates/non-free amd64 Packages [4,556 B]
Hit http://security.debian.org jessie/updates/contrib amd64 Packages
Get:3 http://nl.mxrepo.com mx16 InRelease [7,828 B]
Hit http://ftp.uk.debian.org jessie/main amd64 Packages
Hit http://ftp.uk.debian.org jessie/contrib amd64 Packages
Hit http://ftp.uk.debian.org jessie/non-free amd64 Packages
Get:4 http://security.debian.org jessie/updates/main i386 Packages [665 kB]
Hit http://ftp.uk.debian.org jessie/main i386 Packages
Hit http://ftp.uk.debian.org jessie/contrib i386 Packages
Get:5 http://nl.mxrepo.com jessie InRelease [20.6 kB]
Hit http://ftp.uk.debian.org jessie/non-free i386 Packages
Get:6 http://security.debian.org jessie/updates/non-free i386 Packages [4,549 B]
Ign http://nl.mxrepo.com mx16 InRelease
Get:7 http://security.debian.org jessie/updates/main Translation-en [335 kB]
Hit http://ftp.uk.debian.org jessie/contrib Translation-en
Hit http://ftp.uk.debian.org jessie/main Translation-en
Hit http://security.debian.org jessie/updates/contrib i386 Packages
Err http://nl.mxrepo.com jessie InRelease
Hit http://ftp.uk.debian.org jessie/non-free Translation-en
Get:8 http://security.debian.org jessie/updates/non-free Translation-en [11.8 kB]
Hit http://security.debian.org jessie/updates/contrib Translation-en
Get:9 http://nl.mxrepo.com mx15 InRelease [7,864 B]
Err http://nl.mxrepo.com mx15 InRelease
Ign http://nl.mxrepo.com mx16/non-free amd64 Packages/DiffIndex
Ign http://nl.mxrepo.com mx16/main amd64 Packages/DiffIndex
Ign http://nl.mxrepo.com mx16/non-free i386 Packages/DiffIndex
Ign http://nl.mxrepo.com mx16/main i386 Packages/DiffIndex
Ign http://nl.mxrepo.com mx16/main Translation-en_GB
Ign http://nl.mxrepo.com mx16/non-free Translation-en_GB
Hit http://nl.mxrepo.com mx16/non-free amd64 Packages
Hit http://nl.mxrepo.com mx16/main amd64 Packages
Hit http://nl.mxrepo.com mx16/non-free i386 Packages
Hit http://nl.mxrepo.com mx16/main i386 Packages
Fetched 36.3 kB in 6s (5,196 B/s)
W: GPG error: http://nl.mxrepo.com mx16 InRelease: The following signatures were invalid: KEYEXPIRED 1548008281 KEYEXPIRED 1548008281 KEYEXPIRED 1548008281
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://nl.mxrepo.com jessie InRelease: The following signatures were invalid: KEYEXPIRED 1552432420 KEYEXPIRED 1552432420 KEYEXPIRED 1552432420 KEYEXPIRED 1552432420 KEYEXPIRED 1552432420 KEYEXPIRED 1552432420 KEYEXPIRED 1552432420
W: An error occurred during the signature verification. The repository is not updated and the previous index files will be used. GPG error: http://nl.mxrepo.com mx15 InRelease: The following signatures were invalid: KEYEXPIRED 1548008281 KEYEXPIRED 1548008281 KEYEXPIRED 1548008281
W: Failed to fetch http://nl.mxrepo.com/antix/jessie/dists/jessie/InRelease
W: Failed to fetch http://nl.mxrepo.com/mx/repo/dists/mx15/InRelease
W: Some index files failed to download. They have been ignored, or old ones used instead.
E: Could not get lock /var/lib/dpkg/lock - open (11: Resource temporarily unavailable)
E: Unable to lock the administration directory (/var/lib/dpkg/), is another process using it?
Fetched 36.3 kB in 8s (4,231 B/s)
Reading package lists... Done
So you have imported the key but not available.
Let's check it :
Let's check it :
apt-key list 1548008281
- TenderFoot
That's a lot of ouput - a sort of potted history of Mepis/MX!
root@Toshiba:/home/chris# apt-key list 1548008281
/etc/apt/trusted.gpg
pub 1024D/1A77B3E9 2005-10-29 [expired: 2011-01-22]
uid Warren Woodford (MEPIS Maintainers) <dev@mepis.org>
pub 1024D/437D05B5 2004-09-12
uid Ubuntu Archive Automatic Signing Key <ftpmaster@ubuntu.com>
sub 2048g/79164387 2004-09-12
pub 1024D/0C5A2783 2006-11-23
uid The Medibuntu Team <medibuntu@sos-sts.com>
sub 2048g/16C7105A 2006-11-23
pub 1024D/FBB75451 2004-12-30
uid Ubuntu CD Image Automatic Signing Key <cdimage@ubuntu.com>
pub 1024D/1F41B907 1999-10-03
uid Christian Marillat <marillat@debian.org>
uid Christian Marillat <marillat@free.fr>
sub 1536g/C28DCC42 1999-10-03
sub 1024D/5D3877A7 2002-08-26
pub 1024D/F80994F6 2007-02-07
uid Stefan Lippers-Hollmann (sidux.com) <s.l-h@gmx.de>
sub 4096g/A04679A8 2007-02-07
pub 1024D/927CCC73 2007-06-04
uid innotek GmbH (archive signing key) <info@innotek.de>
sub 2048g/F0C31E29 2007-06-04
pub 1024D/B8C0755A 2008-09-13
uid Adam Blackburn <compwiz18@gmail.com>
sub 2048g/CF3C3262 2008-09-13
pub 1024D/6DFBCBAE 2008-07-14
uid Sun Microsystems, Inc. (xVM VirtualBox archive signing key) <info@virtualbox.org>
sub 2048g/78A86EAF 2008-07-14
pub 1024D/A1704726 2008-09-14 [expired: 2010-09-14]
uid Hendrik Rittich <hendrik.rittich@gmx.de>
pub 1024D/2FB2CD80 2009-05-11
uid Steven Barrett <damentz@gmail.com>
sub 2048g/AF06A3FF 2009-05-11
pub 1024D/98AB5139 2010-05-18
uid Oracle Corporation (VirtualBox archive signing key) <info@virtualbox.org>
sub 2048g/281DDC4B 2010-05-18
pub 1024D/B9FBE3CE 2011-01-22
sub 1024g/5C010C44 2011-01-22
pub 1024D/15B0B570 2010-11-08
uid aurelien (Be Free!) <ice.cube@gmx.com>
sub 2048g/569EF615 2010-11-08
pub 1024D/8C00FC18 2010-12-08 [expired: 2012-12-07]
pub 2048R/FFF06A93 2010-03-31
uid Dedinčanov archív balíkov (Debian APT repositary) <dedincan@slavino.sk>
pub 1024R/3465FC9B 2012-03-11 [expired: 2013-03-11]
uid David deJong (Dave) <david@daveserver.info>
pub 2048R/FD08FE04 2012-04-14
uid antiX (this is for the antix repo) <antix@daveserver.info>
sub 2048R/DF2981C7 2012-04-14
pub 1024D/09F8ECEF 2009-12-11
uid aurele (Free your Gnu !) <ice.cube@gmx.com>
sub 2048g/BD7C22FA 2009-12-11
pub 2048D/3B07EE13 2013-05-25
uid MEPIS Community Repository (CR Signing key) <repo@teharris.net>
sub 2048g/92871A87 2013-05-25
pub 1024D/6CE33D20 2010-09-20 [expired: 2015-02-06]
uid home:gottcode OBS Project <home:gottcode@build.opensuse.org>
pub 2048D/14E225A0 2014-01-21 [expired: 2019-01-20]
uid MX Community Repository <repo@teharris.net>
pub 4096R/A5C7FF72 2017-04-11 [expires: 2019-09-28]
uid Opera Software Archive Automatic Signing Key 2017 <packager@opera.com>
sub 4096R/2E8D6BE2 2017-04-11 [expires: 2019-09-28]
/etc/apt/trusted.gpg.d/debian-archive-jessie-automatic.gpg
pub 4096R/2B90D010 2014-11-21 [expires: 2022-11-19]
uid Debian Archive Automatic Signing Key (8/jessie) <ftpmaster@debian.org>
/etc/apt/trusted.gpg.d/debian-archive-jessie-security-automatic.gpg
pub 4096R/C857C906 2014-11-21 [expires: 2022-11-19]
uid Debian Security Archive Automatic Signing Key (8/jessie) <ftpmaster@debian.org>
/etc/apt/trusted.gpg.d/debian-archive-jessie-stable.gpg
pub 4096R/518E17E1 2013-08-17 [expires: 2021-08-15]
uid Jessie Stable Release Key <debian-release@lists.debian.org>
/etc/apt/trusted.gpg.d/debian-archive-stretch-automatic.gpg
pub 4096R/F66AEC98 2017-05-22 [expires: 2025-05-20]
uid Debian Archive Automatic Signing Key (9/stretch) <ftpmaster@debian.org>
sub 4096R/B7D453EC 2017-05-22 [expires: 2025-05-20]
/etc/apt/trusted.gpg.d/debian-archive-stretch-security-automatic.gpg
pub 4096R/8AE22BA9 2017-05-22 [expires: 2025-05-20]
uid Debian Security Archive Automatic Signing Key (9/stretch) <ftpmaster@debian.org>
sub 4096R/331F7F50 2017-05-22 [expires: 2025-05-20]
/etc/apt/trusted.gpg.d/debian-archive-stretch-stable.gpg
pub 4096R/1A7B6500 2017-05-20 [expires: 2025-05-18]
uid Debian Stable Release Key (9/stretch) <debian-release@lists.debian.org>
/etc/apt/trusted.gpg.d/debian-archive-wheezy-automatic.gpg
pub 4096R/46925553 2012-04-27 [expires: 2020-04-25]
uid Debian Archive Automatic Signing Key (7.0/wheezy) <ftpmaster@debian.org>
/etc/apt/trusted.gpg.d/debian-archive-wheezy-stable.gpg
pub 4096R/65FFB764 2012-05-08 [expires: 2019-05-07]
uid Wheezy Stable Release Key <debian-release@lists.debian.org>
/etc/apt/trusted.gpg.d/pkg-mozilla-archive-keyring.gpg
pub 4096R/06C4AE2A 2010-11-20 [expires: 2019-11-13]
uid Debian Mozilla team APT archive <pkg-mozilla-maintainers@lists.alioth.debian.org>
The two gpg-signing keys mentioned with the thread MX15/16 signing keys are those,
listed by those command
which gives this output:
So of you have those imported already not clear, why you still get an expired key error.
apt-key list 452F0C20 14E225A0
pub dsa2048 2014-01-21 [SCA] [expires: 2021-01-20]
C8CF 3513 60C3 7394 5178 8AE5 81E7 7EAF 14E2 25A0
uid [ unknown] MX Community Repository <repo@teharris.net>
pub rsa2048 2013-03-13 [SC] [expires: 2021-05-01]
ED57 48AC 0E57 5DD2 49A5 6B84 DB36 CDF3 452F 0C20
uid [ unknown] antiX (antix repo) <repo@antixlinux.com>
sub rsa2048 2013-03-13 [E] [expires: 2021-05-01]
Looks like you need import those two keys again cannot see those keys.TenderFoot wrote: ↑Fri Apr 12, 2019 8:00 pm That's a lot of ouput - a sort of potted history of Mepis/MX!
Here a short variation
with this you'll get the first one:
and now run again:
You might still get an expired key error. Now let's import the other one.
and run again
Check you have both keys:
HTH
wget -q http://teharris.net/mx15repo.asc -O- | sudo apt-key add -
sudo apt-get update
sudo apt-get -y install antix-archive-keyring
sudo apt-get update
- TenderFoot
Thanks a lot - that's done the trick! Reloaded without error.
Why was mine in such a mess?
BTW after the last apt-get update
Given the situation it seemed wise to choose "Y"!Configuration file '/etc/apt/trusted.gpg.d/antix-archive-keyring.gpg'
==> Deleted (by you or by a script) since installation.
==> Package distributor has shipped an updated version.
What would you like to do about it ? Your options are:
Y or I : install the package maintainer's version
N or O : keep your currently-installed version
D : show the differences between the versions
Z : start a shell to examine the situation
The default action is to keep your current version.
*** antix-archive-keyring.gpg (Y/I/N/O/D/Z) [default=N] ? Y
Installing new version of config file /etc/apt/trusted.gpg.d/antix-archive-keyring.gpg ...
Yes. Not sure why it has to be provided as a config-file, instead as a normal "replace this file" update.TenderFoot wrote: ↑Fri Apr 12, 2019 8:58 pmGiven the situation it seemed wise to choose "Y"!Configuration file '/etc/apt/trusted.gpg.d/antix-archive-keyring.gpg'
For config-file apt tries to be polite and tend to ask...
