Package update issue with python-ldb
Jlinuxnew
#1 Post by Jlinuxnew »
I am running MX linux (64-bit install) on laptop. Usually software updates on this system have been seamless, but I've walked myself into a minor inconvenience at best and possibly a tricky situation that I don't want to figure out alone.
Please help, the situation may involve just a package that is broken (python-ldb) or it also at this point because of some other maneuvers could involve turning back on the correct repositories!!! Oops.
When I go to install the package that is what it says,
Reading package lists...
Building dependency tree...
Reading state information...
You might want to run 'apt --fix-broken install' to correct these.
 python-ldb : Depends: libldb1 (= 2:1.1.27-1+b1) but 2:1.1.27-1+deb9u1 is to be installed
E: Unmet dependencies. Try 'apt --fix-broken install' with no packages (or specify a solution).
Then if I remember correctly I go to run that and some more error occuring there. So what could be it causing the package to appear unremovable and also not upgradable at the same time?
Actually a "funny" thing this occurs at the same time I completely destroyed my windows partition on the same laptop, but I am 100% that it has nothing to do with this. At least I hope not. I believe there is something in the chain of dependencies now as well because of the packages depending on this python library. Not sure which of these packages none of them seem to be showing any obvious signs of problem. I would ignore the problem but I don't like the consistent warnings and error messages from the package manager.
How would I proceed to diagnose the package manager's claims that this package is broken if it may or may not really be?
Here's the output to the above command if I try to use apt --fix-broken-install...
root@JRlinux1:/var/log/apt# apt --fix-broken install
Reading package lists... Done
Correcting dependencies... Done
The following packages were automatically installed and are no longer required:
  libgegl-0.3-0 libllvm3.9
Use 'sudo apt autoremove' to remove them.
The following additional packages will be installed:
  python-ldb
  python-ldb
1 upgraded, 0 newly installed, 0 to remove and 1 not upgraded.
6 not fully installed or removed.
Need to get 0 B/34.8 kB of archives.
After this operation, 1,024 B disk space will be freed.
Do you want to continue? [Y/n]
(Reading database ... 346216 files and directories currently installed.)
Preparing to unpack .../python-ldb_2%3a1.1.27-1+deb9u1_amd64.deb ...
  File "/usr/bin/pyclean", line 63
    except (IOError, OSError), e:
SyntaxError: invalid syntax
dpkg: warning: subprocess old pre-removal script returned error exit status 1
dpkg: trying script from the new package instead ...
dpkg: error processing archive /var/cache/apt/archives/python-ldb_2%3a1.1.27-1+deb9u1_amd64.deb (--unpack):
 subprocess new pre-removal script returned error exit status 1
Traceback (most recent call last):
  File "/usr/bin/pycompile", line 35, in <module>
    from debpython.version import SUPPORTED, debsorted, vrepr, \
  File "/usr/share/python/debpython/version.py", line 24, in <module>
    from ConfigParser import SafeConfigParser
ImportError: No module named 'ConfigParser'
dpkg: error while cleaning up:
 subprocess installed post-installation script returned error exit status 1
E: Sub-process /usr/bin/dpkg returned an error code (1)
It's also apparently enough problematic that it causes issues when trying to remove it along with dependants:
E: system-config-samba: subprocess installed pre-removal script returned error exit status 1
E: python-samba: subprocess installed pre-removal script returned error exit status 1
E: python-ldb: package is in a very bad inconsistent state; you should  reinstall it before attempting a removal
Apt install history.log file
https://pastebin.com/5RWuECfx
Re: Package update issue with python-ldb
#2 Post by timkb4cq »
Sometimes when you get a broken script like this you need to purge the packages (Completely Remove in Synaptic) and then install them again.
However there's another possibility here because this a a Python package.
ConfigParser was renamed in Python3. Could you have manually changed /usr/bin/python to point to a version 3.x python instead of 2.7? If so, change it back and the upgrade should go through. In MX-17/18 as in debian stretch, python points to 2.x python3 points to 3.x
Jlinuxnew
#3 Post by Jlinuxnew »
Fixed. You were right about the link, but how did you know that??!
Jlinuxnew
#4 Post by Jlinuxnew »
Oh dug, I see now
