Couldn't find the right forum for this plea of help.. I'm unsuccessful after much effort trying to install Electrum wallet. Any help would be fantastic.
Host: BMF Kernel: 4.15.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
Desktop: Xfce 4.12.3 Distro: MX-18_x64 Continuum March 14 2018
Type: Desktop Mobo: ASRock model: Z77 Extreme4-M serial: <filter>
BIOS: American Megatrends v: P1.30 date: 07/13/2012
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
charge: Normal status: Discharging
Topology: Quad Core model: Intel Core i5-3570K bits: 64 type: MCP
arch: Ivy Bridge rev: 9 L2 cache: 6144 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 27201
Speed: 1890 MHz min/max: 1600/3800 MHz Core speeds (MHz): 1: 1600 2: 1600
3: 1600 4: 1601
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
vendor: ASRock driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.19.2 driver: intel resolution: 1440x900~60Hz
OpenGL: renderer: Mesa DRI Intel Ivybridge Desktop v: 4.2 Mesa 18.2.6
Device-1: Intel 7 Series/C216 Family High Definition Audio
vendor: ASRock Z77 Extreme4 driver: snd_hda_intel v: kernel
bus ID: 00:1b.0
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet
vendor: ASRock driver: r8169 v: 2.3LK-NAPI port: e000 bus ID: 02:00.0
Device-2: D-Link AirPlus G DWL-G122 Wireless Adapter(rev.B1) [Ralink
RT2571]
type: USB driver: rt2500usb bus ID: 1-1.5:3
Local Storage: total: 119.24 GiB used: 63.97 GiB (53.6%)
ID-1: /dev/sda vendor: OCZ model: VERTEX4 size: 119.24 GiB
ID-1: / size: 8.86 GiB used: 7.72 GiB (87.2%) fs: ext4 dev: /dev/sda1
ID-2: /home size: 97.15 GiB used: 56.24 GiB (57.9%) fs: ext4
dev: /dev/sda3
ID-3: swap-1 size: 1.97 GiB used: 0 KiB (0.0%) fs: swap dev: /dev/sda4
System Temperatures: cpu: 22.0 C mobo: N/A
1: deb http://la.mxrepo.com/antix/stretch/ stretch main
Processes: 246 Uptime: 1d 4h 38m Memory: 7.51 GiB used: 3.11 GiB (41.4%)
inxi: 3.0.29
mrpolite@BMF:~/Downloads/Electrum-3.3.4
$ sudo python3 -m pip install .[fast]
[sudo] password for mrpolite:
The directory '/home/mrpolite/.cache/pip/http' or its parent directory is not owned by the current user and the cache has been disabled. Please check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
The directory '/home/mrpolite/.cache/pip' or its parent directory is not owned by the current user and caching wheels has been disabled. check the permissions and owner of that directory. If executing pip with sudo, you may want sudo's -H flag.
Processing /home/mrpolite/Downloads/Electrum-3.3.4
Complete output from command python setup.py egg_info:
Error: Electrum requires Python version >= 3.6.1...
Command "python setup.py egg_info" failed with error code 1 in /var/tmp/pip-144in5f4-build/
$ sudo apt-get install python3-setuptools
Reading package lists... Done
Building dependency tree
python3-setuptools is already the newest version (33.1.1-1).
The following packages were automatically installed and are no longer required:
libllvm3.9 libva-wayland1
Use 'sudo apt autoremove' to remove them.
0 upgraded, 0 newly installed, 0 to remove and 37 not upgraded.
