[Solved] update-initramfs: wrong kernel
outlaw
#1 Post by outlaw »
I recently installed MX-18 and added the 4.9.91-antix.1-amd64-smp kernel
to eliminate an irq / vector error on startup.
A recent update (apt-get upgrade) generated a update-initramfs
update-initramfs: Generating /boot/initrd.img-4.19.0-1-amd64
The system is configured to use the 4.9.91-antix.1-amd64-smp kernel by default.
Why would update-initramfs use the 4.19.01 kernel? Should it not use the antix kernel?
I know I need to execute update-initramfs with the all kernel option, is this -a ?
Also should I create a new image (-c) or update (-u)
Thanks in advance for any advice / suggestions offered.
Tom
Naturally nuts no pharmaceuticals required
kmathern
Re: update-initramfs: wrong kernel
#2 Post by kmathern »
outlaw wrote: Sun Jan 20, 2019 2:52 pm I know I need to execute update-initramfs with the all kernel option, is this -a ?
To update the initrds of all installed kernels with the update-initramfs command, use -u together with -k all.
sudo update-initramfs -u -k all
baldyeti
#3 Post by baldyeti »
Does anyone know if there is a way to always have all initrd's rebuilt (make "-uk all" the default)
I mean when the package manager needs to invoke it, so the user does not have to think of building the extra ones.
skidoo
#4 Post by skidoo »
an update-initramfs bash alias could work (but, to me, would be contrary to "the principal of least surprise")
#5 Post by Stevo »
It should have rebuilt the initrd for the running kernel at least--are you certain that the 4.9 kernel process didn't just scroll off the bottom of the terminal? I've always seen it build for all installed kernels by default, so it's no surprise to see it build for the 4.19 kernel, too. You can uninstall it if you don't need it, though the vector irq warning is benign.
baldyeti
#6 Post by baldyeti »
I am pretty sure i had the same issue recently - I have the MX17 kernel 4.15 but almost always boot to the Debian 4.9 one, and recently i noticed only the initrd for 4.15 had been rebuilt ....
-rw-r--r--  1 root root 40404428 Dec  2 12:22 initrd.img-4.9.0-8-amd64
drwxr-xr-x  6 root root     4096 Jan  8 12:37 grub
-rw-r--r--  1 root root 47805755 Jan 19 23:26 initrd.img-4.15.0-1-amd64
kmathern
#7 Post by kmathern »
baldyeti wrote: Sun Jan 20, 2019 4:49 pm Does anyone know if there is a way to always have all initrd's rebuilt (make "-uk all" the default)
I haven't tried it, but the changing update_initramfs=* setting from 'yes' to 'all' in the /etc/initramfs-tools/update-initramfs.conf file might work.
# Configuration file for update-initramfs(8)
# update_initramfs [ yes | all | no ]
# Default is yes
# If set to all update-initramfs will update all initramfs
# If set to no disables any update to initramfs beside kernel upgrade
update_initramfs=yes all
# backup_initramfs [ yes | no ]
# Default is no
# If set to no leaves no .bak backup files.
backup_initramfs=no
baldyeti
#8 Post by baldyeti »
That rings a bell, kmathern, thanks. I vaguely remember having had to do that in the past. Or i got impatient and changed the value from 'all" to "yes", not sure ...
outlaw
#9 Post by outlaw »
My apologies for leaving this thread hanging after the problem was resolved, I forgot to mark the post as solved.
Thanks to all who replied to my post, it was kmathern suggest that solved the problem.
Tom
