[Solved] Redshift doesn't start on startup.
betman
#1 Post by betman »
Greetings, everyone!
I can't get redshift to start upon logging in even though
sudo redshift -c ~/.config/redshift/redshift.conf
has been added to Settings -->Session and Startup --> Application Autostart
What am I missing? BTW, the first time after I put the code in autostart menu, redshift had started, but not afterwards.
zorzi
Re: Redshift doesn't start on startup.
#2 Post by zorzi »
Did you install gtk-redshift package ?
I don't have anything to configure. Just launching redshift by clicking on the app icon, then selecting "autostart" in the tray icon.
wulf
#3 Post by wulf »
Try configuring it manually. There should be a redshift.config file in the .config folder in your home directory. If you find your city/town on Google maps or Google earth, make a note of the coordinates in the decimal format and enter them to two decimal places in the redshift config file.
Example
Lat=34.66
Lon=-50.51
Also, make sure that location provider=manual
adjustment method=randr
You can also change colour temperature/brightness/gamma etc from within this file. Re-start Redshift, and your changes will be implemented.
#4 Post by dolphin_oracle »
Is the sudo necessary? I don't think you need it
philotux
#5 Post by philotux »
--deleted--
--reason: doubtful if the content was accurate--
betman
#6 Post by betman »
dolphin_oracle wrote: Sun Jan 20, 2019 10:11 am Is the sudo necessary? I don't think you need it
You're right! Thank you very much! "Look who is the culprit!" 'sudo'. Removed sudo and redshift's working as expected. Could you explain why sudo was causing the issue, please?
ckoul
Re: [Solved] Redshift doesn't start on startup.
#7 Post by ckoul »
sudo asks for your password (which never gets in the boot process)
betman
#8 Post by betman »
ckoul wrote: Tue Jan 22, 2019 7:15 am sudo asks for your password (which never gets in the boot process)
The auto-starting process starts everytime you logout and login, irrespective of whether the system has booted everytime or not. So booting has nothing to do with it. Although, I agree with the password asking fact.
Gerson
#9 Post by Gerson »
Sometimes you also need to install the package: geoclude-2.0
cosmicpotato
#10 Post by cosmicpotato »
For reference should be package: geoclue-2.0 for anybody else looking into this (yes i copy/pasted and scratched my head for a while!!!! :p )
