Hello there!
I have USB DAC and Mic. and when I plug it in on already launched instance of MX-Linux the pulseaudio do not picks them up.
Simple solution is `killall pulseaudio` does the trick, and sound/mic working, but the volume indicator disappears from the system try.
How do I return my volume control back to try?
(solved) restarting pulseaudio - no volume indicator in sys try
Re: restarting pulseaudio - no volume indicator in sys try
hi...
Click the MX menu- Run program- type volumeicon on the text box and press enter. The icon should appear on your bar...
Leave some feedback if this solves your problem!
P.
P.
Hi!
Sorry, yes it solved problem.
Many thanks!!
Many thanks!!
Good, and welcome to the Forum!
Please return to your first post and add the word "SOLVED" to the subject line. Thanks.
Re: (solved) restarting pulseaudio - no volume indicator in sys try
PPC-- What does the volumeicon program do? It would be good to know, because it is useful to me, and if I knew what it did, it might help me understand the issue I am facing.
Why does the volume icon disappear? The same thing happens to me (Yoga 2 Pro, MX Linux 19.2, i7, dual boot with Windows 10), and if this is part of the MX design, I would like to know why... ;-)
