[Solved] Help with Synaptic "Could not download all repository indexes"?
rej
Post by rej » Sun Jun 10, 2018 12:24 pm
Synaptic Reload Failure notification "Could not download all repository indexes"
I have several devices running MX17.1 and AntiX17.1 and getting this notification on both. Network connection is good.
Never saw this before.
Found this post:
viewtopic.php?f=108&t=37535&p=355243&hi ... es#p355243
"Re: Could not download all repository indexes
#6 Post by jdmeaux1952 » Fri Jan 16, 2015 10:50 am
After a reboot, the same problem accord. I was able to get the MX-Tools, and used the Check Apt GPG to correct this. Problem solved."
I could not find "Check Apt GPG".
Any help with this would be much appreciated.
Thank you.
Re: Help with Synaptic "Could not download all repository indexes"?
Post by anticapitalista » Sun Jun 10, 2018 12:29 pm
Maybe it is because the antiX repo is down.
kmathern
Post by kmathern » Sun Jun 10, 2018 12:53 pm
I've noticed some problems the last 3 or 4 days with the antix.daveserver.info repos on my MX-16.1 install.
Fetched 242 kB in 19s (12.5 kB/s)
W: Failed to fetch http://antix.daveserver.info/jessie/dists/jessie/Release.gpg  Unable to connect to antix.daveserver.info:http:
W: Failed to fetch http://antix.daveserver.info/jessie/dists/jessie/main/i18n/Translation-en_US  Unable to connect to antix.daveserver.info:http:
W: Failed to fetch http://antix.daveserver.info/jessie/dists/jessie/main/i18n/Translation-en  Unable to connect to antix.daveserver.info:http:
W: Failed to fetch http://antix.daveserver.info/jessie/dists/jessie/main/i18n/Translation-fr  Unable to connect to antix.daveserver.info:http:
W: Failed to fetch http://antix.daveserver.info/jessie/dists/jessie/main/i18n/Translation-es  Unable to connect to antix.daveserver.info:http:
W: Failed to fetch http://antix.daveserver.info/jessie/dists/jessie/main/binary-amd64/Packages  Unable to connect to antix.daveserver.info:http:
W: Failed to fetch http://antix.daveserver.info/jessie/dists/jessie/main/binary-i386/Packages  Unable to connect to antix.daveserver.info:http:
E: Some index files failed to download. They have been ignored, or old ones used instead.
Currently the mirrors, such as: deb http://iso.mxrepo.com/antix/jessie/ jessie main, (for MX-17 replace 'jessie' with 'stretch'), load okay, but eventually they might not be be able to get synced correctly if they can't access the antix.daveserver.info repos, which are the upstream rsync source for the antiX mirrors.
rej
Post by rej » Mon Jun 11, 2018 12:50 pm
Thank you.
I appears to be working now.
