(solved) maria db problems
Be OK
Post by Be OK » Fri Jun 08, 2018 2:21 pm
Using mx packet installer i installed mariadb server metapack . One problem is din`t ask for root password.
So following this link " https://www.digitalocean.com/community/ ... t-password "
I try the commands . sudo systemctl stop mariadb give Failed to get D-Bus connection: Unknown error -1
sudo mysqld_safe --skip-grant-tables --skip-networking & give $ 180608 20:19:47 mysqld_safe Logging to syslog.
180608 20:19:47 mysqld_safe A mysqld process already exists
So how to solve this ?
Re: maria db problems
Post by fehlix » Fri Jun 08, 2018 2:49 pm
You might try one of those:
# sudo service mysql help
Usage: /etc/init.d/mysql start|stop|restart|reload|force-reload|status|bootstrap
E.g. mariaDB status after install looks like this:
# sudo service mysql status
[info] /usr/bin/mysqladmin  Ver 9.1 Distrib 10.1.26-MariaDB, for debian-linux-gnu on x86_64
Copyright (c) 2000, 2017, Oracle, MariaDB Corporation Ab and others.
Server version		10.1.26-MariaDB-0+deb9u1
Protocol version	10
Connection		Localhost via UNIX socket
UNIX socket		/var/run/mysqld/mysqld.sock
Uptime:			2 min 47 sec
Threads: 1  Questions: 471  Slow queries: 0  Opens: 198  Flush tables: 2  Open tables: 27  Queries per second avg: 2.820.
:puppy:
--fehlix
Be OK
Post by Be OK » Sat Jun 09, 2018 4:24 am
Ok that commands work " [info] /usr/bin/mysqladmin Ver 9.1 Distrib 10.0.32-MariaDB "
Got any books that work as printed ? Got "getting started with mariadb" but that does not work,like "sudo mysql -u root "give ERROR 1045 (28000): Access denied for user 'root'@'localhost' (using password: NO) :bawling: :(
Still no idea how to set user root pasword :bagoverhead:
Post by fehlix » Sat Jun 09, 2018 8:31 am
... how to set user root pasword
Try this: set a new mysql-root-password
# sudo mysqladmin -u root password “change_my_root_password_here”
EDIT: better restart mysql-db :
# sudo service mysql restart
Connect to mysql with mysql-root user:
# sudo mysql -u root -p
Be OK
Post by Be OK » Sat Jun 09, 2018 11:30 am
Sadly $
 sudo mysqladmin -u root password mxlinux
mysqladmin: connect to server at 'localhost' failed
error: 'Access denied for user 'root'@'localhost' (using password: NO)'
No not work , i forgot using mx 16.
Post by fehlix » Sat Jun 09, 2018 11:45 am
Please provide outputs within the [code][/code]-tags. Presse above "</>" - icon
for better readability.
Be OK
Post by Be OK » Sat Jun 09, 2018 12:03 pm
Hope this is what you mean.
Post by fehlix » Sat Jun 09, 2018 1:06 pm
Yes, it*s much more better to read.
Let's try again. I'm on MX17.1.
Better restart mysql first:
$ sudo service mysql restart
[ ok ] Stopping MariaDB database server: mysqld.
[ ok ] Starting MariaDB database server: mysqld.
Now try this instead to give mysql-root a password:
If you have not yet changed the default empty
mysql-root password, you might just press enter
and than retype the new password twice.
fehlix@mx171:~/Desktop
$ sudo mysqladmin -u root -p password
Enter password:
New password:
Confirm new password:
Now connect to mysql/mariadb:
$ sudo mysql -u root -p
Enter password:
Welcome to the MariaDB monitor.  Commands end with ; or \g.
Your MariaDB connection id is 34
Server version: 10.1.26-MariaDB-0+deb9u1 Debian 9.1
Type 'help;' or '\h' for help. Type '\c' to clear the current input statement.
Be OK
Post by Be OK » Sat Jun 09, 2018 1:17 pm
First fehlix thanks for your time, the restart worked.
sudo mysqladmin -u root -p password       Enter password:
resulted in
#10
Post by fehlix » Sat Jun 09, 2018 4:50 pm
Just re-done this on MX16.1:
Purge existing maria-db
# sudo apt-get purge mariadb*
Reinstall mariadb do this from the terminal command-line
First always do update and upgrade:
Update package-list
# sudo apt-get update
upgrade packages:
# sudo apt-get dist-upgrade
Now reinstall mariadb:
# sudo apt-get install mariadb-server
You will get asked to set a new mariadb-root password. Please enter a new password
You shoud now connect as normal linux-user (no sudo needed)
mysql --user=root --password
mysqladmin --user=root --password
$ mysql --user=root --password
Enter password:
Your MariaDB connection id is 53
Server version: 10.0.32-MariaDB-0+deb8u1 (Debian)
MariaDB [(none)]>
