[Solved] How to Automount Partitions in MX
vamsi
Post by vamsi » Thu Jun 07, 2018 7:15 am
Recently i connected my cpu two hdd's via a cable now i want to mount all the partitions automatically i.e, 1HDD and 2 HDD partitions is there a way i messed with fstab file but didn't worked
$ sudo blkid
/dev/sda1: UUID="f9c818a6-7038-4dd2-aad1-263fa527f73e" TYPE="swap" PARTLABEL="Linux swap" PARTUUID="e02dfbea-cded-4dd4-b4fa-cff99f24d732"
/dev/sda2: LABEL="rootMX17" UUID="fb5af156-c9ae-4963-b0a8-6039d78bbfce" TYPE="ext4" PARTLABEL="Basic data partition" PARTUUID="688b1d1b-3922-43e2-bca4-ad0946987134"
/dev/sda3: UUID="fae678df-f8dc-4f0a-87f5-8307d3398098" TYPE="ext4" PARTUUID="6bb94577-37eb-4f6d-ae10-76d1d0f04255"
/dev/sda4: LABEL="Android-x86" UUID="033e8fc7-4cfe-9454-bc59-df7329ca862d" TYPE="ext4" PARTLABEL="Android" PARTUUID="f5c8bce3-3e4f-4c9c-9a80-6224465ec94d"
/dev/sda5: UUID="2DF8F85A1147CE35" TYPE="ntfs" PTTYPE="dos" PARTLABEL="My Files" PARTUUID="e4c620ce-fb83-4d65-aded-7b35a189e476"
/dev/sdb1: UUID="82FE6E3EFE6E2A9D" TYPE="ntfs" PARTUUID="d8a7d8a7-01"
/dev/sdb5: LABEL="KULAKARNI" UUID="60BCAD92BCAD62F0" TYPE="ntfs" PARTUUID="d8a7d8a7-05"
/dev/sdb6: LABEL="PRASAD" UUID="C234C36C34C36251" TYPE="ntfs" PARTUUID="d8a7d8a7-06"
/dev/sdb7: LABEL="VAMSI" UUID="44ECE53FECE52C3C" TYPE="ntfs" PARTUUID="d8a7d8a7-07"
/dev/zram1: UUID="6cf5e869-ed7c-403d-b7b7-58646b81081f" TYPE="swap"
# /etc/fstab: static file system information.
# <file system> <mount point>   <type>  <options>       <dump>  <pass>
#Entry for /dev/sda2 :
UUID=fb5af156-c9ae-4963-b0a8-6039d78bbfce	/	ext4	defaults	1	1
#Entry for /dev/sdb5 :
UUID=60BCAD92BCAD62F0	/media/cherubim/60BCAD92BCAD62F0	ntfs-3g	defaults,locale=en_US.UTF-8	0	0
#Entry for /dev/sdb1 :
UUID=82FE6E3EFE6E2A9D	/media/cherubim/82FE6E3EFE6E2A9D	ntfs	defaults	0	0
#Entry for /dev/sdb6 :
UUID=C234C36C34C36251	/media/cherubim/C234C36C34C36251	ntfs-3g	defaults,locale=en_US.UTF-8	0	0
#Entry for /dev/sda4 :
UUID=033e8fc7-4cfe-9454-bc59-df7329ca862d	/media/Android_x86	ext4	defaults	0	0
#Entry for /dev/sda5 :
UUID=2DF8F85A1147CE35	/media/cherubim/2DF8F85A1147CE35	ntfs-3g	defaults	0	0
#Entry for /dev/sda3 :
UUID=fae678df-f8dc-4f0a-87f5-8307d3398098	/media/sda3	ext4	defaults	0	0
#Entry for /dev/sda1 :
UUID=f9c818a6-7038-4dd2-aad1-263fa527f73e	swap	swap	defaults	0	0
Thanks
Re: How to Automount Partitions in MX
Post by dolphin_oracle » Thu Jun 07, 2018 7:54 am
use the "auto" option in fstab.
UUID=60BCAD92BCAD62F0	/media/cherubim/60BCAD92BCAD62F0	ntfs-3g	defaults,auto,locale=en_US.UTF-8	0	0
lenovo ThinkPad T530 - MX-18
vamsi
Post by vamsi » Thu Jun 07, 2018 8:19 am
Thanks i edited like this
UUID=2DF8F85A1147CE35		/media/sda5	ntfs-3g	defaults,auto	0	0
/dev/sda5	/media/cherubim	ntfs-3g	defaults,locale=en_US.UTF-8	0	0
Every partitions mount after starting but i was not able to create a folder in any partition and not able to paste anything what may be the reason
Thanks..
Post by dolphin_oracle » Thu Jun 07, 2018 8:31 am
Thanks..
probably the top level of the partition is owned by root. this is how tools like gparted or gnome-disks format with ext4. I generally create subfolders and then give my user permissions on those folders.
ntfs-3g is a little different. you can spoof the user privileges. in my screenshot below (ignore the red circle, this is an old screenshot), I use UID and GID variables to tell the ntfs-3g driver what user I want to "own" the filesystem.
stsoh
Post by stsoh » Thu Jun 07, 2018 8:31 am
try this:
ntfs-3g	uid=1000,gid=1000,fmask=0137,dmask=0027,locale=en_US.UTF-8	0	0
vamsi
Post by vamsi » Thu Jun 07, 2018 11:42 am
here is fstab file i did this and rebooted and gere is the screenshot
and i was not able to create folder also.. :frown: :frown:
thanks..
Post by dolphin_oracle » Thu Jun 07, 2018 11:43 am
is your user id 1000?
what is
id
run as regular user giving for output?
vamsi
Post by vamsi » Thu Jun 07, 2018 12:04 pm
what is
id
Here is the output
$ id
uid=1000(cherubim) gid=1000(cherubim) groups=1000(cherubim),7(lp),20(dialout),24(cdrom),25(floppy),27(sudo),29(audio),30(dip),44(video),46(plugdev),100(users),108(netdev),116(lpadmin),119(scanner)
stsoh
Post by stsoh » Thu Jun 07, 2018 1:38 pm
try this:
what was the result when/if u use the above???
if it is still lock, logic say tat u r not recognized user by the system.
/media/sda5??? maybe your uuid is invalid.
try this:
check n confirm uuid,
blkid
#10
Post by dolphin_oracle » Thu Jun 07, 2018 9:39 pm
a couple of points I want to clear up.
1. did the automount part work?
2. if that is a windows partition, are you sure windows is totally shutdown? by default it can use a hybrid sleep/shutdown that can leave the ntfs partition locked to other processes.
