[SOLVED] Downgrade/upgrade Thunar
yonosoyesa
Post by yonosoyesa » Mon Jun 04, 2018 2:40 am
I love Thunar and its customs actions: I have to work with hundreds of files and I really need my custom actions constantly.
Thunar 1.6.12 has some bugs moving or working with hundreds of files: ghost files, batch renaming problems, no icon refreshing... they make me crazy. This is the only one reason I don't use MXLinux, that I miss a lot.
For me the last reliable Thunar was 1.6.3.
Mint Xfce 18.0 (the system that I'm using nowadays) includes their own Thunar version patched by Mint team (1.6.10-3mint1) that works properly. Later they upgraded to version 1.6.12 from Ubuntu and it started to fail (so I have Thunar upgrades blocked in my system).
Now the brand new Xubuntu 18.04 updates Thunar to 1.6.15. I tested it and it seems that this version of Thunar works properly again.
My question: Is there any way in MX 17 to downgrade Thunar to 1.6.3 or upgrade Thunar to 1.6.15?
I don't want to wait until MX 18 is out...
stsoh
Re: Downgrade/upgrade Thunar
Post by stsoh » Mon Jun 04, 2018 3:46 am
if u r a experience linux user, not a n00b.
u can upgrade 1.6.15 thru sid, i've upgraded long ago plus many betas to release.
be sure u know what u r doing, always have a snapshot backup if u dun want lose all. :happy:
Post by Jerry3904 » Mon Jun 04, 2018 6:16 am
Thanks for this post. I don't believe we've seen such problems reported here, though I have seen occasional comments on the Xfce Forum. We can certainly take a look at it and see what is possible.
Post by timkb4cq » Mon Jun 04, 2018 10:19 am
1.6.15 is in Buster and looks trivial to build for MX-17. Should have it up in Testing soon.
edit: It's up in the testing repo now.
One small oddity, to test I installed the debs with dpkg. thunar -V reported 1.6.15 but the Help -> About dialog still showed version 1.6.12 until after a logout/login. Thunar must leave something in memory after it closes...
yonosoyesa
Post by yonosoyesa » Tue Jun 05, 2018 6:21 am
Thanks a lot. At the moment it installed with no problems. In a few days I'll test it thoroughly. Expect feedback. :crossfingers:
Post by dolphin_oracle » Tue Jun 05, 2018 7:44 am
likely because thunar is running the desktop too, and doesn't change unless you login/logout or otherwise restart the desktop.
lenovo ThinkPad T530 - MX-18
yonosoyesa
Re: [SOLVED] Downgrade/upgrade Thunar
Post by yonosoyesa » Sat Jun 09, 2018 4:38 pm
Thunar 1.6.15 (from testing repo) tested: Works like a charm. Now I can work with MXLinux again. Wonderful!
Thank you very much. :number1:
Post by Stevo » Sat Jun 09, 2018 4:49 pm
We don't recommend that a user add upstream repos to a stable install, especially when the package is as easily backported as Thunar. That should be the very last resort.
I have the sources from a PPA for Thunar 1.8, but haven't opened them up yet. It might require xfce 4.13...
Post by asqwerth » Sun Jun 10, 2018 3:54 am
Thunar 1.8 needs xfce 4.13 upwards, according to the bottom of this page: https://andreldm.com/2018/06/06/thunar- ... lease.html
While moving to Gtk+ 3 it was necessary to replace parts of the Thunar Plugin API (thunarx). It means that to update to Thunar 1.8.0 one should also update all installed thunar-plugins and xfdesktop to their latest versions, see the compability matrix for more details.
The compatibility matrix linked to also indicates Thunar from 1.7 onwards needs 4.13+
#10
Post by timkb4cq » Sun Jun 10, 2018 8:25 pm
Thunar 1.6.15 also fixes a hanging problem I've had copying folders over from a samba share.
Ordinarily I would move this to main since it fixes two bugs - but since it's an integral part of the desktop I would appreciate a little more testing first to make sure there are no reversions or other problems.
