(solved) Switch to Libreoffice 5 from Debian repo ?
zorzi
Post by zorzi » Sun Jun 03, 2018 9:27 am
Hello,
Is there a way to replace MX default Libreoffice 6 with Libreoffice 5 from Debian repos ?
Desktop: HP Pavilion a6435 (Athlon64 2x 2,6Ghz, Radeon R7-240, Ram 4 Go, HD 500 Go) / MX Linux 17
Re: Switch to Libreoffice 5 from Debian repo ?
Post by fehlix » Sun Jun 03, 2018 10:05 am
Well, you might convince the apt-package manager like this:
## apt-repfereces: /etc/apt/preferences.d/debian-liberoffice.pref
## this will make apt to prefer debian's provided libreoffce
Package: libreoffice* fonts-opensymbol gir1.2-lokdocview* python3-uno uno-libs3 ure
Pin: release o=Debian,a=stable,n=stretch
Pin-Priority: 1001
to "downgrade" to debian libroffice version 5.2, if you have still installed libre office
just do an upgrade with the MX-Update or manually:
# sudo apt-get update && sudo apt-get dist-upgrade
To newly install libreoffce either use MX-package Installer (MXPI)
or this line-example for locale fr_FR:
# sudo apt-get update && sudo apt-get install libreoffice-calc libreoffice-draw libreoffice-impress libreoffice-math libreoffice-writer libreoffice-l10n-fr libreoffice-help-fr
To go back to MX-provided libreoffice either remove /etc/apt/preferences.d/debian-liberoffice.pref
or comment out with '#"-hash comment sign the Package and Pin-lines.
:snail:
--fehlix
Post by Jerry3904 » Sun Jun 03, 2018 10:19 am
There is an easier way. Users Manual, Section 5 concerns Software Management, and this question is handled in 5.3.2
Alt-F1
Ctrl-F
downgrade
Post by fehlix » Sun Jun 03, 2018 10:36 am
Alt-F1
Ctrl-F
downgrade
Well, your answer is an answert to a "how to hold specific-package version" question!
The downgrad recommendation within the manual does not include upgrades,
e.g. security upgrades), as you hold a specific version!
It does also not provide answer of all the packages needed for LO in this example! You would need
to "hold" all packages related to LO! Otherwise you got a mixture of package version for LO
and dpotentially a lot of error messages.
I assume the manual need to be fine tuned a bit to reflect hold vs. replace source of packages!
:puppy:
--fehlix
Post by Jerry3904 » Sun Jun 03, 2018 11:02 am
There's always room for improvement! The Manual does not attempt to cover everything, as it states in the Introduction.
If op selects the metapackage libreoffice I believe everything will be downgraded.
Post by fehlix » Sun Jun 03, 2018 11:21 am
Yes some room there...Nop, will not work:
:snail:
--fehlix
Post by dolphin_oracle » Sun Jun 03, 2018 11:52 am
libreoffice is a little more complicated than your average app, because its broken down into so many pieces.
if you want to drop it down, you can remove libreoffice-common, which will remove just about all the rest of the pieces. Then weed out anything left (maybe help files or dictionaries).
then apt-get autoremove to clear out some libs.
sudo apt-get install -t stable libreoffice
will install libreoffice 5 from debian stable
then place this file in /etc/apt/preferences.d/libreoffice-pin which will force libreoffice to only update from the debian stable repo.
Pin:  release a=stable
Pin-Priority: 600
Package:  ure
Pin-Priority: 600
Last edited by dolphin_oracle on Sun Jun 03, 2018 1:04 pm, edited 1 time in total.
lenovo ThinkPad T530 - MX-18
zorzi
Post by zorzi » Sun Jun 03, 2018 11:54 am
Pin-Priority: 1001
:snail:
--fehlix
That worked perfectly. Many thanks.
Post by dolphin_oracle » Sun Jun 03, 2018 12:02 pm
then
will install libreoffice 5 from debian stable.
Pin-Priority: 600
Package:  ure
Pin-Priority: 600
edit*** just read fehlix's post...whoops :happy: well, essentially the same thing, slightly different methodology.
zorzi
#10
Post by zorzi » Sun Jun 03, 2018 12:04 pm
then
Pin-Priority: 600
Package:  ure
Pin-Priority: 600
Yes, both pinning methods work. Thanks.
