Knowing your APT history
dreamer
Post by dreamer » Wed May 30, 2018 7:47 pm
I create this thread as a proper continuation of the off topic discussion that happened in this thread:
viewtopic.php?f=104&t=45307
My understanding is this: Synaptic history is preserved (by Synaptic) and carries over to created snapshots. The APT history found in Apt Notifier (maybe even APT itself) is not carried over to snapshots. That's why I had a January log in Synaptic but not in Apt Notifier (the date for the snapshot seems to match nicely with missing APT history).
I just verified this. /var/log/apt doesn't export history to new snapshots. It also compresses files after just one month (can that period be extended?).
Apt Notifier is good but the data needs to be copied to a text editor to be searchable.
This topic isn't a huge problem. I'm a little surprised that APT which is at the heart of many distros doesn't come with a Synaptic-style searchable history (I would have expected at least a command line version). Maybe this is one reason for the lasting popularity of Synaptic?
Re: Knowing your APT history
Post by richb » Wed May 30, 2018 7:52 pm
CTRL-S in Notifier history does a search.
var/cache/apt can be edited out of the exclusion file.
Rich
SSD Production: MX 17.1
skidoo
Post by skidoo » Wed May 30, 2018 11:20 pm
To customize the logfile handling (this is general linux stuff, not specific to MX nor debian) refer to the logrotate manpage
(and probably will be helpful to skim some online examples/tutorials).
/etc/logrotate.conf
dreamer
Post by dreamer » Thu May 31, 2018 2:23 pm
Ok, thanks. The combined knowledge of the MX Linux forum can probably solve any Linux/Debian/MX Linux related problem. :popcorn:
Is there a way to go to the next matching entry? I tried a few keys, but couldn't really make this search functionality usable.
/etc/logrotate.conf
I have looked at this. I think I have the info I need. Editing that file shouldn't be hard. What confused me is that "compress" was commented out (#) and it still compresses log (history) files. So I was thinking; maybe it's a bug, but probably not. This logrotate functionality feels like pure server or sysadmin stuff, which it probably is. It's possible to experiment with other commands given by the manpage like "nocompress".
My original logrotate.conf
# see "man logrotate" for details
# rotate log files weekly
weekly
# keep 4 weeks worth of backlogs
rotate 4
# create new (empty) log files after rotating old ones
create
# uncomment this if you want your log files compressed
#compress
# packages drop log rotation information into this directory
include /etc/logrotate.d
# no packages own wtmp, or btmp -- we'll rotate them here
/var/log/wtmp {
    missingok
    monthly
    create 0664 root utmp
    rotate 1
/var/log/btmp {
    missingok
    monthly
    create 0660 root utmp
    rotate 1
# system-specific logs may be configured here
skidoo
Post by skidoo » Thu May 31, 2018 4:46 pm
Okay, logrotate.conf just sets the default directives. Files present within the /etc/logrotate.d/ directory may contain overriding directives. Probably need to outcomment a compress directive within one of those (or change any found, and specify "nocompress" instead).
dreamer
Post by dreamer » Thu May 31, 2018 6:01 pm
I think the file in question is this one: /etc/logrotate.d/apt
It looks like this and maybe a little # sign in front of "compress" in the second paragraph might do the trick. We'll see... next month maybe... if this little logrotate program can keep its hands away from my logs. :crossfingers: Thank you for pointing me in the right direction. If I change "monthly" to "yearly" I can probably keep the history from an entire year in one file, which can be convenient.
/var/log/apt/term.log {
  rotate 12
  monthly
  compress
  missingok
  notifempty
/var/log/apt/history.log {
  rotate 12
  monthly
  compress
  missingok
  notifempty
kmathern
Post by kmathern » Sun Jun 03, 2018 10:36 am
For the APT history in MX Updater/apt-notifier, it actually greps the /var/log/dpkg* log files (/var/log/dpkg.log, /var/log/dpkg.log.1, /var/log/dpkg.log.2.gz, /var/log/dpkg.log.3.gz ...), not the /var/log/apt* logs.
If you're missing some of the APT history in snapshots you created, it might be that you excluded the /var/log/dpkg* logs from the snapshot, though it doesn't look to me like they're excluded by default https://github.com/MX-Linux/mx-snapshot ... clude.list.
dreamer
Post by dreamer » Sun Jun 03, 2018 4:49 pm
I was thinking about that, but I don't think it makes any difference. The logrotate program makes sure that these logs are just as hard to work with as the apt logs. I have changed my logrotate preferences. I guess uninstalling logrotate is also an option.
No, I use MX Snapshot with default settings for user accounts. My experience so far is that MX Updater history is missing from snapshots. This can probably be remedied by including that directory in the MX Snapshot configuration.
