With Frugal I can change and add things as I wish and it persists. Direct grub boot doesn't.
YMMV. I'm glad I tried them both. Now to see where to save some SSD space.
After completing the Frugal install, you'll need to reboot, and then look for the menuentry, that
you will find in the file grub.entry inside the folder /antiX-Frugal-4.15.0-1-amd64,
(the numbers will depend on your kernel). Copy the menuentry stanza in grub.entry
into /etc/grub.d/40_custom, just as with the other method.
Dolphin_Oracle's video explains how: https://www.youtube.com/watch?v=6ZGTBUW3bnA
Persistence menus should no longer present themselves, thanks to this post from anti:
Adding a corrected menuentry stanza above the first for completeness.#15 Post by anticapitalista » 08 May 2018, 17:26
If you don't want the menus to show up, remove the word menus from the grub entry.
Also, on my Intel box I had to also remove the word nomodeset.
You can't run persistence with fromiso
You can always add back any of the debugging code desired or needed.
Leaving the menuentry stanza, just below, as is. If you don't want to see the menus anymore
you can remove "menus" from set bootparams line. Mine wouldn't boot after that,
so as anti mentioned, on Intel mobo's probably need to remove "nomodeset"
[NOTE] Here is the final working stanza, for /etc/grub.d/40_custom, that works for booting MX-Workbench
via the grub2 menu with MX-17.1_x64, no persistence is possible.
Of course, you must change "set iso=" to the path to your iso location:
menuentry "MX-Workbench_18.3_x64.iso" {
echo Boot disk address is: $root
set iso="/CDs/Utils/MX-Workbench/MX-Workbench_18.3_x64.iso"
set bootparms="from=all quiet"
search -f $iso --set=root
echo ISO root is: $root
echo ISO is: $iso
echo Boot parms are: $bootparms
echo
loopback loop $iso
sleep -i -v 5
linux (loop)/antiX/vmlinuz fromiso=$iso $bootparms
initrd (loop)/antiX/initrd.gz
echo Booting $iso
menuentry "MX-Workbench_18.3_x64.iso -- with menus" {
set bootparms="from=all quiet menus nomodeset"
echo ISO is: $iso
echo
loopback loop $iso
sleep -i -v 15
echo Booting $iso
[/NOTE]1. It boots and runs. Have removed all persistence menus since persistence can not work when booted in this manner. Persistence will work when booted as a Frugal Install which I now feel is more desirable.
2. Don't forget to run "update-grub" after any changes to /etc/grub.d/40_custom.
3. My actual partitions on sda are as follows:
sda1 = /DATA/CDs/Utils/MX-Workbench/MX-Workbench_18.3_x64.iso
sda2 = /
In the set iso line, I had to remove /DATA from the beginning of the path to the iso
because the search finds the partition /DATA.
4. Suggestion: When the first stanza is working for you, copy it to a second stanza with a different name
and continue fiddling with the second one. ESC will always take you back to the grub menu if you see a problem while traversing the new stanzas in the grub menu. You can reduce the timeout from 15 seconds to whatever seems appropriate.
5. Genuine thanks to all who commented with suggestions. I didn't try them all
because anticapitalista's and Ed_P's suggestions brought success,
and they had showed how to use fromiso, as Jerry3904 mentioned.
6. There is good information in the other posts, in case you have problems getting some iso to boot
from the grub menu. I will certainly keep them in mind. Thanks to male, Jerry3904, ChrisUK
for suggestions and to Adrian for the MX Workbench
[ORIGINAL POST STARTS HERE]
I want to boot MX-Workbench from the iso on the SSD by means of the MX17.1 Grub2 boot menu. I found a few references that say it is possible. My problem is the actual contents of the stanza in /etc/grub.d/40_custom aren't working.
This is what I have on the SSD: {inxi -Fxzdlop at EOF}
1. Actual path to the ISO:
There are only 2 partitions on the disk:
sda2 = /
2. ## /etc/grub.d/40_custom stanzas...Trials 1..n
3. Saved all edits and executed update-grub and reboot...
## Trial 4:
menuentry “MX-Workbench_18.3_x64.iso” {
set isopath=/DATA/CDs/Utils/MX-Workbench
set isoname="MX-Workbench_18.3_x64.iso"
set isofile="${isopath}/${isoname}"
echo "Using ${isoname}..."
loopback loop $isofile
linux (loop)/vmlinuz boot=antiX findiso=${isofile}
initrd (loop)/initrd.gz
loopback loop (hd0,1)/$isofile
error: file `DATA/CDs/Utils/MX-Workbench/MX-Workbench_18.3_x64.iso' not found
error: disk `loop' not found
error: you need to load the kernel first
error: file `//DATA/CDs/Utils/MX-Workbench/MX-Workbench_18.3_x64.iso' not found
press any key to continue...
## Trial 3:
set isofile=”DATA/CDs/Utils/MX-Workbench/MX-Workbench_18.3_x64.iso”
linux (loop)/antix/vmlinuz
initrd (loop)/antix/initrd.gz
boot
error: file `/"DATA/CDs/Utils/MX-Workbench/MX-Workbench_18.3_x64.iso” not found
## Trial #2:
# menuentry “MX-Workbench_18.3_x64.iso” {
set isofile=”/CDs/Utils/MX-Workbench/MX-Workbench_18.3_x64.iso”
set root=(hd0,2)
boot
## Trial #1:
invalid file name `"/CDs/Utils/MX-Workbench/MX-Workbench_18.3_x64.iso” not found
What am I doing wrong?
All pointers, code appreciated.
Thanks for your time.
root@mx171:/home/richard# inxi -Fxzdlop
System: Host: mx171 Kernel: 4.15.0-1-amd64 x86_64 bits: 64 compiler: gcc v: 6.3.0
Desktop: Xfce 4.12.3 tk: Gtk 2.24.31 Distro: MX-17.1_x64 Horizon March 14, 2018
Machine: Type: Laptop System: LENOVO product: 2347AY1 v: ThinkPad T430 serial: <filter>
Mobo: LENOVO model: 2347AY1 v: NO DPK serial: <filter> UEFI [Legacy]: LENOVO
v: G1ET73WW (2.09 ) date: 10/19/2012
Battery: ID-1: BAT0 charge: 22.9 Wh condition: 23.5/56.2 Wh (42%) model: SANYO 45N1001
status: Unknown
CPU: Topology: Dual Core model: Intel Core i5-3320M bits: 64 type: MT MCP arch: Ivy Bridge
rev: 9 L2 cache: 3072 KiB
flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 20752
Speed: 1202 MHz min/max: 1200/3300 MHz Core speeds (MHz): 1: 1197 2: 1197 3: 1197
4: 1200
Graphics: Card-1: Intel 3rd Gen Core processor Graphics driver: i915 v: kernel bus ID: 00:02.0
Display: x11 server: X.Org 1.19.2 driver: intel resolution: 1600x900~60Hz
OpenGL: renderer: Mesa DRI Intel Ivybridge Mobile v: 3.3 Mesa 13.0.6
Audio: Card-1: Intel 7 Series/C216 Family High Definition Audio driver: snd_hda_intel
v: kernel bus ID: 00:1b.0
Network: Card-1: Intel 82579LM Gigabit Network Connection driver: e1000e v: 3.2.6-k port: 5080
bus ID: 00:19.0
Card-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi v: kernel
bus ID: 03:00.0
Drives: HDD Total Size: 585.00 GiB used: 86.23 GiB (14.7%)
ID-1: /dev/sda model: Samsung_SSD_840 size: 119.24 GiB
ID-2: /dev/sdb type: USB model: Hard_Drive size: 465.76 GiB
Optical-1: /dev/sr0 vendor: Optiarc model: DVD RW AD-7740H rev: 1.S1
dev-links: cdrom,cdrw,dvd,dvdrw
Features: speed: 24 multisession: yes audio: yes dvd: yes
rw: cd-r,cd-rw,dvd-r,dvd-ram state: running
Partition: ID-1: / size: 20.54 GiB used: 13.88 GiB (67.6%) fs: ext4 dev: /dev/sda2 label: MX171
ID-2: /DATA size: 96.20 GiB used: 72.36 GiB (75.2%) fs: ext4 dev: /dev/sda1
label: DATA
Unmounted: ID-1: /dev/sdb1 size: 465.76 GiB fs: ntfs label: SONY uuid: 26C28F5FC28F31DB
Sensors: System Temperatures: cpu: 52.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3768
Info: Processes: 220 Uptime: 16m Memory: 7.48 GiB used: 712.1 MiB (9.3%) Init: SysVinit
runlevel: 5 Compilers: gcc: 6.3.0 Shell: bash v: 4.4.12 inxi: 3.0.06
