[SOLVED] MX-17: Can't install showfoto - dependencies' problem
@all:
Just tried to install showfoto 4:5.7.0-1mx17+2, but I can't ("broken packages" problem). showfoto requires kipi-plugins-common, so maybe this issue is linked to the issue noticed in viewtopic.php?f=108&t=44229&p=437043.
Greetings, Joe
Greetings, Joe
Re: MX-17: Can't install showfoto - dependencies' problem
my guess is you have something installed from the test repo that is conflicting. All the items you've posted on lately seem to be OK on my travel usb stick. I do have kdenlive installed as well.MX-16_fan wrote:@all:
Greetings, Joe
So do you have a kde app installed from testrepo?
@dolphin_oracle:
So what do I do?
Greetings, Joe
Yes, Okular, for example, and probably others (I use a couple of KDE applications so frequently I don't even notice them to be KDE any more).dolphin_oracle wrote:(...) So do you have a kde app installed from testrepo?
So what do I do?
Greetings, Joe
looks to me like several of the mxtest repo kde apps have a depend on the international files that are higher than the version in the standard repo (or at least support files)
So if you have one of those installed, that is likely your overall "kde" app issue.
You may well be able to simply enable the test repo in synaptic and install what you want.
@dolphin_oracle:
Greetings, Joe
Same as here: viewtopic.php?p=437066#p437066: Already tried that, but there's no higher version of the kde-l10n-de available in the MX Test Repo.dolphin_oracle wrote:You may well be able to simply enable the test repo in synaptic and install what you want.
Greetings, Joe
can you post output of
sudo apt-get install kde-l10n-de
I think the problem is in the okular package from testrepo, or possibly one of the support files.
I suggest going with the okular from the regular repo.
@dolphin_oracle:
Greetings, Joe
There you are:dolphin_oracle wrote:can you post output of
Paketlisten werden gelesen... Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen.... Fertig
Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
kinit libbit-vector-perl libcarp-clan-perl libchm1 libconfig-general-perl libdate-calc-perl
libexporter-tiny-perl libextutils-depends-perl libextutils-pkgconfig-perl libfilesys-df-perl
libfont-ttf-perl libgoo-canvas-perl libgoocanvas-common libgoocanvas3 libgps22
libgtk2-ex-simple-list-perl libgtk2-imageview-perl libgtkimageview0 libimage-magick-perl
libimage-magick-q16-perl libio-string-perl libkf5activities5 libkf5calendarevents5 libkf5js5
libkf5jsapi5 libkf5kexiv2-15.0.0 libkf5khtml-data libkf5khtml5 libkf5plasma5 libkf5plasmaquick5
libkf5pty-data libkf5pty5 libkf5threadweaver5 liblist-moreutils-perl liblog-log4perl-perl
libokular5core7 libossp-uuid-perl libossp-uuid16 libpdf-api2-perl libproc-processtable-perl
libqca-qt5-2 libqmobipocket2 libqt5multimediawidgets5 libqt5positioning5 libqt5serialport5
libreadonly-perl libsane-perl libset-intspan-perl libshp2 libtiff-tools libtry-tiny-perl
libvisio-0.1-1 libvlccore8 libxcb-damage0 pkg-config plasma-framework
qml-module-org-kde-kirigami qml-module-org-kde-kquickcontrols
qml-module-org-kde-kquickcontrolsaddons qml-module-qt-labs-folderlistmodel
qml-module-qtgraphicaleffects qml-module-qtquick-controls qml-module-qtquick-layouts
qml-module-qtquick-window2 qml-module-qtquick2
Verwenden Sie »sudo apt autoremove«, um sie zu entfernen.
Vorgeschlagene Pakete:
kde-standard
Die folgenden Pakete werden ENTFERNT:
libastro1 libmarblewidget-qt5-28 marble marble-data marble-plugins marble-qt marble-qt-data
okular okular-extra-backends
Die folgenden NEUEN Pakete werden installiert:
kde-l10n-de
0 aktualisiert, 1 neu installiert, 9 zu entfernen und 29 nicht aktualisiert.
Es müssen 37,8 MB an Archiven heruntergeladen werden.
Nach dieser Operation werden 35,9 MB Plattenplatz freigegeben.
Möchten Sie fortfahren? [J/n]
Greetings, Joe
UPDATE:
Here's what I get when I try to install showfoto from the command line:
@Stevo: Is this of any help to resolve this?
Greetings, Joe
$ sudo apt-get install showfoto
Reading package lists... Done
Building dependency tree
The following packages have unmet dependencies:$ sudo apt-get install showfoto
showfoto : Depends: digikam-private-libs (= 4:5.7.0-1mx17+2) but it is not going to be installed
Depends: kipi-plugins (= 4:5.7.0-1mx17+2) but it is not going to be installed
Greetings, Joe
Showfoto is part of the Digikam set of packages, so you should be trying to install the test repo version to match the test repo Digikam.
