  • Mepis support still here
  • MX-16.1 release info here
  • antiX-17 release info here
    • Read Forum Rules
qpdfview hangs on some files
dr-kart
#1 Postby dr-kart » Fri Jan 12, 2018 8:31 am
Maybe it's related to https://lists.debian.org/debian-securit ... 00001.html
Maybe not. But my qpdfview hangs on some pdf files made by libreoffice from single paged test .doc file. (attached)
(!) Thing is that very file can be opened on amd cpu desktop. But hangs on intel cpu desktop.
Both run on same kernel and same nvidia 375 pack driver.
I tried to open that file in Manjaro's qpdfview - which is of 0.4.17 version (see attch.). And it does open it.
dr-kart
Re: qpdfview hangs on some files
#2 Postby dr-kart » Fri Jan 12, 2018 9:38 am
Managed to make screen of the issue
Killing app leaves only this
The X11 connection broke (error 1). Did the X11 server die?
Fornhamfred
#3 Postby Fornhamfred » Fri Jan 12, 2018 3:18 pm
Similar problem but does not hang but displays some pdf's with only lines. Have checked with evince and works perfectly.
PDF in previous post opens perfectly with qpdfview.
Utopia
#4 Postby Utopia » Fri Jan 12, 2018 4:34 pm
If you check the properties of the libre_export_version.pdf, you will find that the name of the author is in Cyrillic script.
Have seen pdf files hang when titles are in unsupported alphabets. This could be similar.
Henry
dr-kart
#5 Postby dr-kart » Fri Jan 12, 2018 5:35 pm
Another export test. This time I use desktopeditors (aka onlyoffice) to make pdf file.
Now it has no Cyrillic author in properties btw. And result has 1.7 pdf version.
qpdfview won't open it again.
Producer:       Ascensio System SIA Copyright (c) 2015
UserProperties: no
Suspects:       no
Form:           none
JavaScript:     no
Pages:          1
Encrypted:      no
Page size:      841.9 x 595.3 pts (A4)
Page rot:       0
File size:      46884 bytes
Optimized:      no
PDF version:    1.7
Gaer Boy
#6 Postby Gaer Boy » Fri Jan 12, 2018 6:21 pm
qpdfview opens both versions here with no problem. The desktopeditors version has the table on the right, while the .doc & libreoffice versions have the table on the left.
Phil
AsRock FM2A88X-ITX+, A8-6500, 8GB, 120GB Samsung SSD (GPT), 1TB HDD (MBR), MX-16
Lenovo Thinkpad X220, dual-core i5, 3MB, 320GB Hitachi HDD, Win7, MX-16.1
dr-kart
#7 Postby dr-kart » Fri Jan 12, 2018 6:42 pm
Gaer Boy wrote: The desktopeditors version has the table on the right, while the .doc & libreoffice versions have the table on the left
That is right. This is how my desktopeditors opens a .doc file. Just another riddle.
Gaer Boy wrote:qpdfview opens both versions here with no problem
What cpu do you have? Amd ?
Since I have issue with intel desktop. Amd cpu desktop opens here too.
Thank you.
#8 Postby dolphin_oracle » Fri Jan 12, 2018 7:05 pm
I can also open the files ok.
all intel hardware here.
eeepc 904ha antix 15 32 bit (streaming media player)
acer c720p chromebook - chromeos / MX15-64 (custom snapshot) live USB.
lenovo s21e - antiX-16 MX16(live-usb)
dr-kart
#9 Postby dr-kart » Fri Jan 12, 2018 7:33 pm
now I find myself baffled
paul1149
#10 Postby paul1149 » Fri Jan 12, 2018 9:27 pm
Maybe a dependency got borked? How about reinstalling qpdfview?
Who is online
Users browsing this forum: No registered users and 7 guests
